size problems (STL and WRL exports) [message #4228] Sat, 02 May 2009 18:41 UTC |
Hello!
really new here!
I'm uploading my first models and it seams that there is a problems with sizing.
My original models (3dsmax8) are in the scale of centimeters and mms, but I'm getting e-mails from Shapeways stating that they are to big.
For example a part that mesures 4 x 2,8 x 1,55 cm when exported, reads as:
58.1 x 108.5 x 154.5 cm (h x w x d).
Does someone had the same problem?
| Re: size problems (STL and WRL exports) [message #5092 is a reply to message #4228 ] Thu, 02 July 2009 01:10 UTC |
I have the exact same problem, have you found a solution?
Regards, Jack
| Re: size problems (STL and WRL exports) [message #5094 is a reply to message #5092 ] Thu, 02 July 2009 07:29 UTC |
Hello!
it seems exporting in .DAE and using generic units (not metric) works OK (in 3dstudioMax).
| Re: size problems (STL and WRL exports) [message #5271 is a reply to message #5094 ] Thu, 16 July 2009 18:38 UTC |
Thank you for the reply, I will try this out
Regards, Jack
