inverted normals in rhino
inverted normals in rhino [message #4158] Wed, 29 April 2009 09:36 UTC Go to next message
avatar scott-tweeddale  is currently offline scott-tweeddale
im having trouble in rhino, shapeways is saying my models normals are inverted and as far as i can see it's not? can any one help?
Re: inverted normals in rhino [message #4159 is a reply to message #4158 ] Wed, 29 April 2009 09:56 UTC Go to previous messageGo to next message
Hi scott-tweeddale,
I took a look at your model. It had a lot of inverted normals. I took the liberty to fix it for you Laughing
Just upload it , order it and it's yours Nod
Ralph
Shapeways Director of Customer Service
Re: inverted normals in rhino [message #4162 is a reply to message #4158 ] Wed, 29 April 2009 10:20 UTC Go to previous messageGo to next message
Thanks for fixing. Out of interest how did you fix it?
Appreciate the help
Scott
Re: inverted normals in rhino [message #4164 is a reply to message #4162 ] Wed, 29 April 2009 10:27 UTC Go to previous messageGo to next message
Hi Scot,
I used the fixed wizard and removed all the inverted normals, and some bad shells. That's all Cool
Ralph
Re: inverted normals in rhino [message #4165 is a reply to message #4158 ] Wed, 29 April 2009 10:29 UTC Go to previous messageGo to next message
is that something in rhino at all or something you use at shapeways?
Re: inverted normals in rhino [message #4166 is a reply to message #4165 ] Wed, 29 April 2009 10:33 UTC Go to previous messageGo to next message
No, we, at Shapeways, use Magics
Re: inverted normals in rhino [message #4177 is a reply to message #4166 ] Wed, 29 April 2009 17:58 UTC Go to previous messageGo to next message
avatar AO  is currently offline AO
Hi Ralph,
I saw you fixed some files with magics.
Could you also fixe the dragonnecklace?
How did you fix the tank without destroying it?
Could you show the method with some screenprints?
Greetings AO
Re: inverted normals in rhino [message #4187 is a reply to message #4158 ] Thu, 30 April 2009 07:19 UTC Go to previous messageGo to next message
Hi
I'm still having problems working out normals in Rhino and i was wondering if it was possible for you to have a look at these files for me as well?
Any further help would be much appreciated
Scott
  • Attachment: hingeleg.stl
    (Size: 598.86KB, Downloaded 84 time(s))
Re: inverted normals in rhino [message #4188 is a reply to message #4158 ] Thu, 30 April 2009 07:20 UTC Go to previous messageGo to next message
these two aswell
  • Attachment: lense2.stl
    (Size: 4.04MB, Downloaded 132 time(s))
Re: inverted normals in rhino [message #4189 is a reply to message #4158 ] Thu, 30 April 2009 07:22 UTC Go to previous messageGo to next message
No Message Body
  • Attachment: lense3.stl
    (Size: 468.05KB, Downloaded 91 time(s))
Re: inverted normals in rhino [message #4193 is a reply to message #4189 ] Thu, 30 April 2009 12:55 UTC Go to previous messageGo to next message
avatar Gijs  is currently offline Gijs
Hi Scott,
not sure, but you're probably using the wrong mesh settings out of rhino. I just downloaded your lens2 and lens3 models,
They both contain open meshes which is not good for 3D printing
If you send the rhino model, I can see if it is a problem with the mesh settings or with the model itself, it could well be a combination of both. I guess that's the case, because lens2 had interfering mesh faces as well.
Gijs
www.studiogijs.nl
Re: inverted normals in rhino [message #4194 is a reply to message #4193 ] Thu, 30 April 2009 15:13 UTC Go to previous messageGo to next message
Hi
Thanks to everyone for their help, i've managed to sort it out and order it all, i had to re make it froms scratch
Thanks to everyone for help
Re: inverted normals in rhino [message #4213 is a reply to message #4194 ] Fri, 01 May 2009 08:12 UTC Go to previous messageGo to next message
Hi Scott,
I am glad you succeeded to upload your models!
Hi AO,
Just send the model to service@shapeways.com and we will take a look at it Cool
There is an Shrinkwrap option in Magics, which takes care of this.
I will make time for this next week. Maybe i can make a simple tutorial and put in on the support section
Ralph
Re: inverted normals in rhino [message #4221 is a reply to message #4213 ] Fri, 01 May 2009 20:42 UTC Go to previous message
Ralph,
The dragonnecklace is not mine but from murderslastcrow If I remember well.
I'm looking forward to your tutorial.
Cheers AO
Previous Topic:Aluminium profile with inverted normals
Next Topic:inverted normals
