| Inverted Normals with Autodesk Inventor [message #4066] Sun, 26 April 2009 19:03 UTC |
I am not sure how to check for Inverted Normals with Autodesk Inventor when I export my object to an STL file. Anyone have any idea's?
Attachment: Tank Side.stl
(Size: 618.93KB, Downloaded 99 time(s))
| Re: Inverted Normals with Autodesk Inventor [message #4072 is a reply to message #4066 ] Sun, 26 April 2009 21:16 UTC |
Liquidwulf,
You have some little problem on the edges.
Its maybe related to the way you've modeled your tank or
you've set the resolution of the stl to high.
See pdf. It should be easy to solve now.
Greetings AO
Attachment: tank.pdf
(Size: 377.64KB, Downloaded 114 time(s))
| Re: Inverted Normals with Autodesk Inventor [message #4076 is a reply to message #4072 ] Mon, 27 April 2009 00:40 UTC |
It seems that Inventor is garbage when trying to convert to .stl files. The problems do not exist in Inventor native, so I cannot fix them unfortunately, and AccuTrans 3d conversion software does not recognize Inventor files.
I tried converting from .stl to Collada with the AcuTrans 3d software, and shapeways kicked back an error saying my object was over 10 feet long, however the save as with options dialog says the object is only 5.5x3.9x1.0
Not sure what I will try next.
| Re: Inverted Normals with Autodesk Inventor [message #4078 is a reply to message #4076 ] Mon, 27 April 2009 10:30 UTC |
Liquidwulfe,
Did you make a high resolution. I model in solidworks, I also had problems until I saved with less resolution.
With a high resolution you create overlapping triangles.
That's also your problem.
Adding a radius to the edges might solve it too.
The size has to do with the units you model. mtrs, inch or mm. When you upload or convert you have to pay attention.
I'll fix the file for you.
Greetings AO
| Re: Inverted Normals with Autodesk Inventor [message #4079 is a reply to message #4076 ] Mon, 27 April 2009 10:48 UTC |
Liquidwulfe,
Here another pdf. I thought I could fix it.
But if I do that the red area's will disapear.
I think the red areas are double surfaces.
Delete them with a boolean operation or, maybe meshlab has a tool somewhere that delets double face as I remember well.
Greetings AO
Attachment: Tank2.pdf
(Size: 386.52KB, Downloaded 99 time(s))
| Re: Inverted Normals with Autodesk Inventor [message #4081 is a reply to message #4079 ] Mon, 27 April 2009 10:54 UTC |
Yea, I tried uploading to STL in every resolution available. I think the problem is with Autodesk Inventor's .stl export. Tonight I will be getting an .ipt to .3ds converter, where I can then convert it to Collada directly. I do appreciate the help tho!
