| Re: Deer Brooch Clip pin success [message #33057 is a reply to message #33052 ] Mon, 22 August 2011 11:22 UTC |
Very nice...
| Re: Deer Brooch Clip pin success [message #33058 is a reply to message #33057 ] Mon, 22 August 2011 11:31 UTC |
Thanks Duann,
This is the first model we have ordered in WSF Polished. It's awesome! Such a nice finish.
Leigh
| Re: Deer Brooch Clip pin success [message #33080 is a reply to message #33052 ] Mon, 22 August 2011 16:45 UTC |
So it clicks on as opposed to being glued on... nice. I have about 100 of those brooch pins and this was one of my back-burner projects...
Glenn
| Re: Deer Brooch Clip pin success [message #33099 is a reply to message #33080 ] Mon, 22 August 2011 23:50 UTC |
Thanks Glenn,
I had this awful fear that a glued in clasp would come unstuck and fall out. I am happy with snap in also for the speed of assembly. I would defiantly recommend it.
Leigh
| Re: Deer Brooch Clip pin success [message #33414 is a reply to message #33379 ] Sat, 27 August 2011 01:31 UTC |
Thanks Ana, that's awesome!!
I plan to get it up for sale at some point. I will let you know.
Leigh
| Re: Deer Brooch Clip pin success [message #33507 is a reply to message #33475 ] Mon, 29 August 2011 14:37 UTC |
Leigh, if you decide you want it even more secure on the pin, you can use a soldering iron or wood burning tool to melt the plastic down a bit and 'rivet' it to the pin back.
Also, I'm having great success fusing WSF with a Thread Burner - if you find yourself in a situation where a design is too complex to print at one go, you can fuse rather than glue...
| Re: Deer Brooch Clip pin success [message #39314 is a reply to message #33518 ] Sun, 27 November 2011 06:03 UTC |
If you made the 3 dots of plastic a little longer and straight, you could just use a regular flat tipped soldering iron and push the rods down against the metal. They'd flatten out and make a nice, snug lock.
I would hope Shapeways would add this feature, because we can't really sell them directly if we have to do this ourselves.
| Re: Deer Brooch Clip pin success [message #39329 is a reply to message #33052 ] Sun, 27 November 2011 19:20 UTC |
@Museum of Small Things: Have you had a chance to test the longevity/strength of the clip-in solution? I'm very curious how well it stands up to repeated strain.
Donna
| Re: Deer Brooch Clip pin success [message #41508 is a reply to message #39329 ] Mon, 09 January 2012 13:49 UTC |
Hey Donna,
We have an example brooch we use to show people and it gets quite a tough work out. It is still solid with no signs of weakening yet. Melting the pins down though is a great idea.
Leigh
| Re: Deer Brooch Clip pin success [message #41512 is a reply to message #41508 ] Mon, 09 January 2012 14:46 UTC |
Leigh,
Thank you so much for the follow up! Like everyone else, I wonder how well some pieces/designs will hold up under 'real world' conditions. The tension snap fit was an absolutely brilliant idea BTW!
Donna
| Re: Deer Brooch Clip pin success [message #41523 is a reply to message #39314 ] Mon, 09 January 2012 17:48 UTC |
| Pherja wrote on Sun, 27 November 2011 06:03 | If you made the 3 dots of plastic a little longer and straight, you could just use a regular flat tipped soldering iron and push the rods down against the metal. They'd flatten out and make a nice, snug lock.
That sounds like a great idea; gluing AND melting the pins would make for an unmovable clasp...
I have a ton of these clasps at home and was wondering what to do with them!
Glenn
| Re: Deer Brooch Clip pin success [message #42018 is a reply to message #33052 ] Sun, 15 January 2012 22:36 UTC |
This is such a cute design! I love it!
It's also very nice you can finish it yourself with a standard pin
adorable 3D-printed jewelry
facebook.com/tinypurpletreehouse
tinyblueapartment.blogspot.nl/
