WSF wall thickness
WSF wall thickness [message #41327] Fri, 06 January 2012 20:40 UTC Go to next message
avatar briancw  is currently offline briancw
I've sure this question gets asked frequently but I did a search through the forum and their seemed to be a bit of inconsistancy between the guides for minimum wall thickness of swf. I'm building a fairl simple model comprised of all cubes (its like a minecraft creeper) and I'm not sure if I should go for 1mm, 1.5mm, or 2mm thickness. It's about 2 inches tall right now, but anything I could shave off in wall thickness I could add to its total size.
What thickness should I go for?
Re: WSF wall thickness [message #41333 is a reply to message #41327 ] Fri, 06 January 2012 21:00 UTC Go to previous messageGo to next message
I just found this while looking for a definitive answer for you. There's a nifty calculator on this page for you! http://www.shapeways.com/design-rules/wsf_bigparts
Re: WSF wall thickness [message #41335 is a reply to message #41327 ] Fri, 06 January 2012 21:28 UTC Go to previous messageGo to next message
Thank you very much. Response time: Incredible.
So according to that, my largest cube, which is roughly 38mm x 16mm could have a wall thickness under 1mm. I'd be okay with using 1mm then?
Re: WSF wall thickness [message #41337 is a reply to message #41327 ] Fri, 06 January 2012 22:09 UTC Go to previous messageGo to next message
If your longest side is 38mm you can go down to .7mm for WSF
Re: WSF wall thickness [message #41361 is a reply to message #41327 ] Sat, 07 January 2012 09:47 UTC Go to previous messageGo to next message
avatar ancientbuzzard  is currently offline ancientbuzzard
Youknowwho4eva
Not sure if it's just me, but is there a typo on the page you linked to?
...you should also add .006 millimeter ....
Shouldn't that be:
...you should also add 0.6 millimeter... ?
Not sure who's the best to notify on this, so could you pass it on for me if I'm right?
Andrew
Re: WSF wall thickness [message #41415 is a reply to message #41327 ] Sat, 07 January 2012 22:53 UTC Go to previous messageGo to next message
No, it's right. For every mm above 117 you should add .006mm of wall thickness. At 118mm long your walls should be at least .706 and so on.
Re: WSF wall thickness [message #41487 is a reply to message #41327 ] Mon, 09 January 2012 07:00 UTC Go to previous message
Youknowwho4eva
Thanks for that. I'd misunderstood the page. Just not used to working with such small measurements! Smile
Andrew
Previous Topic:Quick question on WSF polished
Next Topic:Results of a fast and detailed desktop printer
