| Re: 3D Printed Multirotor Aircraft [message #41379 is a reply to message #41343 ] Sat, 07 January 2012 14:51 UTC |
Cool, looks good.
What is that board, something like an Arduino using an accelerometer?
Tom.
| Re: 3D Printed Multirotor Aircraft [message #41444 is a reply to message #41420 ] Sun, 08 January 2012 11:40 UTC |
Hi, thanks for that, looks like a good bit of kit.
I've bookmarked the site, looks good.
Tom.
| Re: 3D Printed Multirotor Aircraft [message #41473 is a reply to message #41444 ] Sun, 08 January 2012 21:25 UTC |
Thanks! I'll post an update and PM, when I'm ready to put it on sale. Should come in just under $100 for the kit. All that's needed to complete the kit is some mounting hardware and the electronics.
| Re: 3D Printed Multirotor Aircraft [message #41539 is a reply to message #41343 ] Mon, 09 January 2012 20:26 UTC |
this is what I've always dreamed to have I'd really like to see it flying. By the way, do you have any estimates as to how much the motors and electronics would cost?
| Re: 3D Printed Multirotor Aircraft [message #41566 is a reply to message #41554 ] Tue, 10 January 2012 02:06 UTC |
These are two different class of quads. The Parrot is very user friendly, but not an open system that can be reprogrammed. Good for indoor flying in close proximity to the phone. The phone is actually a limitation.
The Arducopter controller I recommended has onboard accelerometer, and gyros for stabilization, with built in electronic compass for heading lock. It's got GPS for defining autonomous mission waypoints, and barometer for high altitude hold. Two different class of quadcopter really. The firmware is open sourced, so you can tinker, if so inclined.
You can also go the low end route and get the KKmulti board, for $100 (or cheaper) and just have gyros.
From a frame point of view, I can add all the mount points for the Parrot Drone parts, and mount them on my frame, once the foam falls apart.
That's the beauty of using 3D printers!
| Re: 3D Printed Multirotor Aircraft [message #41635 is a reply to message #41566 ] Tue, 10 January 2012 20:57 UTC |
| rcshop wrote on Tue, 10 January 2012 02:06 | autonomous mission waypoints, and barometer for high altitude hold
wow.. now it sounds much cooler to me!!
