Home » Community » 3D modeler needed » Dragon Sculpture/Pendant help
Dragon Sculpture/Pendant help [message #40667] Thu, 22 December 2011 22:37 UTC Go to next message
avatar Kebechett  is currently offline Kebechett
Hi there,
I'm trying to make a gift for a friend, but I'm not super experienced with 3d modeling. I have a "completed" sculpt, but Meshlab hates me, and I have no idea what the problems are with my mesh. I keep trying to run it through Meshlab, but it always crashes Sad
Would anyone here be able to help me out?
Re: Dragon Sculpture/Pendant help [message #40678 is a reply to message #40667 ] Fri, 23 December 2011 09:35 UTC Go to previous messageGo to next message
avatar christopherlowe  is currently offline christopherlowe
loaded it into blender and found that there are a whole bunch o doubles... 20k at least.
then i tested for manifolds and there are a bunch of those too...
i suggest going back to your originating program and try and fix these before going into meshlabs...
chris
please visit my blog at...
Re: Dragon Sculpture/Pendant help [message #40713 is a reply to message #40667 ] Sat, 24 December 2011 03:50 UTC Go to previous messageGo to next message
Always consider a model something you cut out and glued many small pieces of paper together, and filled with air. No air leaks! Just 1 outer connected surface.
Shapeways uses the model info sent to a machine process.Your model might render nice, but might be impossible to create.
The surface, while you can visualize it, has no thickness, so the faces/polygons that form it all have to be connected to make it manifold(water or air tight). Main point being it has to be sealed.
You can hollow it out to save cash, but that's another topic.
Doubles refer to vertices being at same Cartesian coordinates as other vertices forming exterior surfaces.Bad,bad. leads to printer errors.
With your modeling program, you just want to see all edges, faces,verts on the surface. Anything in its interior, in most cases will cause more problems.
Re: Dragon Sculpture/Pendant help [message #40725 is a reply to message #40667 ] Sun, 25 December 2011 03:46 UTC Go to previous messageGo to next message
avatar mikegust  is currently offline mikegust
I fixed Y file
remember IT IS SUPER SMALL 1.6mm
U need to scale it (remember minimum wall size for Y material)
U can pay me what U think is fair (I spend 1H fixing)
PayPal mikegust at yahoo dot com
good luck
mike
mike strychalski
Re: Dragon Sculpture/Pendant help [message #40726 is a reply to message #40667 ] Sun, 25 December 2011 03:59 UTC Go to previous message
Thanks everyone for all the help! Cre83D fixed it for me the other day. I'm slowly getting the hang of all of this, and have already started making more stuff without any issues. Smile
Previous Topic:need a 3d modeler for 1/18 scale g.i. Joe weapons and gear
Next Topic:Custom iPod case wanted
