Home » Community » Shapeways Shops » Integrating shapeways 3D view into my own webpage?
Integrating shapeways 3D view into my own webpage? [message #40089] Sun, 11 December 2011 03:02 UTC Go to next message
I want to port the entire shapeways 3D viewer code into my own page. Is this possible or allowed? Which section of the page code would I need?
I want to use specifically the one which appears to be several screenshots compiled together, and not the actual 3D model because I'm a bit worried that it's possible for someone to save the 3D model file.
Re: Integrating shapeways 3D view into my own webpage? [message #40358 is a reply to message #40089 ] Fri, 16 December 2011 15:41 UTC Go to previous messageGo to next message
avatar Michael Mueller  is currently offline Michael Mueller
I ve checked the source... I guess shapeways is using "3DNP"...
http://www.thoro.de/page/3dnp-introduction-en
Have fun!
Michael
Michael Mueller
www.pookas.de
Re: Integrating shapeways 3D view into my own webpage? [message #40727 is a reply to message #40358 ] Sun, 25 December 2011 08:52 UTC Go to previous messageGo to next message
It seems that embedding that in an iframe of proper size (equal to the size used on the shapeways page) can work:
http://www.shapeways.com/sw/static_html/3dnp.html?total=0180 &levels=5&startlevel=3&model=394291&version= 0
change the model number according to your model.
Woody64
[Updated on: Sun, 25 December 2011 10:48 UTC]
Re: Integrating shapeways 3D view into my own webpage? [message #40728 is a reply to message #40727 ] Sun, 25 December 2011 10:53 UTC Go to previous messageGo to next message
It seems also to be possible to access the frames inside this precalculated picture and to generate an animated gif.
index.php?t=getfile&id=12938&private=0
I was using the Linux convert tool to do this:
Some commands like that do the job
(for sure I've used some bash scripts to do that.)
The filename below is the jpg downloaded from the rotating shapeway's frame.
It's used as background image and a Javascript exchanges the view window thus generating the rotating effect.
The only pitty so far is that I don't know where the frames in the precompiles images (which have a size of 4x5 frames) exactly are.
Maybe somebody from shapeways could point that out - or somebody is willing to dive in.
  • Attachment: aa1.gif
    (Size: 586.16KB, Downloaded 167 time(s))
[Updated on: Sun, 25 December 2011 11:09 UTC]
Re: Integrating shapeways 3D view into my own webpage? [message #40729 is a reply to message #40728 ] Sun, 25 December 2011 12:00 UTC Go to previous messageGo to next message
Thanks for the info.
I was able to integrate with a fancybox iframe, but it looks like "version" changes numbers depending on how many updates you've done to your model, starting from version=0. one of my model was at version=3, and another was at version=1. iframe width and height is 482x357.
example here:
http://www.thomashuang.net/products/nps75/nps75.html
<a class="3diframe" href=" http://www.shapeways.com/sw/static_html/3dnp.html?total=0180 &levels=5&startlevel=3&model=387585&version= 3" title="3D view of Nomad Panohead +5"><img src="../../images/3d-button.jpg" alt="3D view of Nomad Panohead +5"/></a>
$(document).ready(function() {
$(".3diframe").fancybox({
'padding' : 0,
'width' : 482,
'height' : 357,
'autoDimensions' : true,
'autoScale' : true,
'scrolling' : 'auto',
'enableKeyboardNav' : false,
'mouseWheelNavigation' : false,
'margin' : 10,
'speedIn' : 150,
'speedOut' : 150,
'changeSpeed' : 150,
'type' : 'iframe',
'overlayColor' :'#000',
'overlayOpacity' : .8,
'cyclic' : true,
'titleShow' : false,
'showCloseButton' : false,
'titleFromAlt' : true,
<script src="../../Scripts/jquery.min.js" type="text/javascript"></script>
<script type="text/javascript" src="../../Scripts/fancybox/jquery.fancybox-1.3.4mod1.js"></script >
<link rel="stylesheet" href="../../Scripts/fancybox/jquery.fancybox-1.3.4.css" type="text/css" media="screen" />
Re: Integrating shapeways 3D view into my own webpage? [message #40730 is a reply to message #40729 ] Sun, 25 December 2011 16:40 UTC Go to previous message
Thanks, that could be helpful.
Would also be an advantage if we could address the main photo and the 3d view directly via shapeways so that a simple onliner can be used to integrate it in any page.
Woody64
Previous Topic:December Shop Owner Payments
Next Topic:Gibberish text when filling title and description
