Home » Support » 3D Printing » Help Support ! Problems with a pendant !
Help Support ! Problems with a pendant ! [message #39942] Wed, 07 December 2011 20:50 UTC Go to next message
avatar tarabyakko  is currently offline tarabyakko
Hello Shapeways support,
I am trying to create a pendant via the creator but can not get what I would like to have.
I have here attached a picture of it.
Is it possible to get it like this ?
And how much would it be in stainless steel and how much in silver ?
And how long would the manufacturing take ?
Thank you in advance !
Best,
Tara.
Re: Help Support ! Problems with a pendant ! [message #39946 is a reply to message #39942 ] Wed, 07 December 2011 22:11 UTC Go to previous messageGo to next message
Mhhh...
volume:
~ 6,36cm³ ...
price:
~ $158 in silver
~ $57 in stainless steel
delivery time:
~ 15 business days
(all information without guarantee ^^)
What's the distance between the dots over the 8cm side ?
Re: Help Support ! Problems with a pendant ! [message #39949 is a reply to message #39946 ] Thu, 08 December 2011 00:14 UTC Go to previous messageGo to next message
Quick sketch (in the attachment).
I made it thinner (3mm), and rounded the corners a bit.
There's just enough space for dots with a diametre of 1mm, and silver requires a 1:1 for embossing, so I made them flatter (1,5mm).
volume:
~ 3,6cm³
price:
~ $102 in silver
~ $35 in stainless steel
  • Attachment: L3.png
    (Size: 80.23KB, Downloaded 52 time(s))
Re: Help Support ! Problems with a pendant ! [message #39961 is a reply to message #39949 ] Thu, 08 December 2011 11:02 UTC Go to previous messageGo to next message
Thank you both of you !
Peter, the pendant looks great ! Can we get the braille dots maybe a tiny bit taller ? like 2-3 mm ? and make them not so large ? Maybe give a bit more space between the edges of the pendant and the braille points ? What would be the price with the braille points ? Thank you for your work !
Best,
Tara.
Re: Help Support ! Problems with a pendant ! [message #39962 is a reply to message #39949 ] Thu, 08 December 2011 11:12 UTC Go to previous messageGo to next message
Pfeiffer stylez,
The pendant looks great but I'd like to have the corners sharp if it is possible ? And can the braille dots be smoother and not so tall ? Will the pendant be strong enough if in silver and 3 mm ? Thank you for your work !
Re: Help Support ! Problems with a pendant ! [message #39966 is a reply to message #39962 ] Thu, 08 December 2011 13:23 UTC Go to previous messageGo to next message
Sharp corners are no problem.
0,7mm tall braille dots with 1 mm diameter and 1mm distance between the dots of one sign ?
The minimum detail level for silver is 0,3mm, but I suggest to use at least 0,5mm...
index.php?t=getfile&id=12556&private=0
Ring bands with 1mm wall thickness are sturdy enough to be wearable, so 3mm sounds good to me. Each additional millimeter thickness would increase the price by $24.
  • Attachment: L4.png
    (Size: 44.44KB, Downloaded 124 time(s))
[Updated on: Thu, 08 December 2011 13:24 UTC]
Re: Help Support ! Problems with a pendant ! [message #39967 is a reply to message #39966 ] Thu, 08 December 2011 13:25 UTC Go to previous message
I'm not sure about the four braille dots on the left. Are they for two or for three different signs ?
What's about the distance between each sign ?
index.php?t=getfile&id=12557&private=0
  • Attachment: L.jpg
    (Size: 27.60KB, Downloaded 118 time(s))
Previous Topic:Full validation before first purchase
Next Topic:Quality Differences in Silver
