| WORKFLOW!! [message #39569] Wed, 30 November 2011 08:54 UTC |
I was wondering what is the correct way to work with your model, I know that modelers are using Netfabb, meshlab and Blender to correct and upload files for 3d printing. Is there a particular order? I had a model with lots of overlapping and intersecting geometry that was fixed rather rapidely by a modeler,is there a particular workflow?
Thanks.
| Re: WORKFLOW!! [message #39609 is a reply to message #39569 ] Wed, 30 November 2011 20:58 UTC |
as in most things there is not just one way to do things. some like to work in one way some in another.
there are really 3 fast and true rules
1. minimum wall distance as per the material that you are printing in and...
2. no 2 points, polygons, or lines may occupy the same space.
- you can have overlapping "shells" or "objects"
3. all shells or objects must be watertight.
please visit my blog at...
| Re: WORKFLOW!! [message #39610 is a reply to message #39609 ] Wed, 30 November 2011 21:03 UTC |
So intersecting is similar to inverted normals?
| Re: WORKFLOW!! [message #39611 is a reply to message #39610 ] Wed, 30 November 2011 21:31 UTC |
not really. inverted normals would indicate a non watertight shell. either way that isn't good.
what i meant by non intersecting points is... say you have 2 shells but they have 1 polygon in common... that will make the printer go -bleh!
| Re: WORKFLOW!! [message #39613 is a reply to message #39611 ] Wed, 30 November 2011 21:48 UTC |
Thanks, I will have to Google how to fix all this in Blender, I still I am not sure what is the difference between Meshlab and Netfabb in relation to uploading models to Shapeways.
| Re: WORKFLOW!! [message #39615 is a reply to message #39613 ] Wed, 30 November 2011 22:02 UTC |
they will fix ill developed models. there are ways to fix these things in blender without them.
| Re: WORKFLOW!! [message #39617 is a reply to message #39615 ] Wed, 30 November 2011 22:09 UTC |
I got a green model in Netfabb ( fixed model) but it was bad for shapeways.
