Commission: Blocks With Inscribed Alien Glyphs
Commission: Blocks With Inscribed Alien Glyphs [message #37937] Fri, 04 November 2011 15:08 UTC Go to next message
avatar rwwin  is currently offline rwwin
I'm a physical modeler that is dazzled by the possibilities of 3D printing but too busy to teach himself how to use the programs available. I am seeking a 3D sculptor to create eleven block filess for print.
Most of my projects are for tabletop wargaming and I create terrain with blocks cast from Hirst Arts molds. I am working on a model project that needs blocks inscribed with simulated alien glyphs. The actual shape of the glyphs is not important and the artist can use their own imagination as long as they follow the general rules I have listed.
I have attached a drawing with the basic outline of what I am looking for. The original was created in Microsoft Visio (vector graphic compatible) and I can send the file if it would be helpful. If the specifications I have requested are not compatible with shapeways printing process, please make suggestions as to what changes will make the plan work.
Please contact me with any questions, or if you are interested in the project, please respond with a proposed price, estimated length of time to create the files, terms of payment and disposition of rights.
You can contact me through the forum or directly through email at: rwwingate@comcast.net
If this project is successful, I plan on commissioning an additional 10-20 blocks of different shapes.
Thank you for looking,
Roger
EDIT: I had an error in the original drawing and have uploaded a corrected version.
[Updated on: Fri, 04 November 2011 16:48 UTC]
Re: Commission: Blocks With Inscribed Alien Glyphs [message #37939 is a reply to message #37937 ] Fri, 04 November 2011 15:18 UTC Go to previous messageGo to next message
email sent. Do you have a trutype font for the glyphs? Any meaning needed?
Re: Commission: Blocks With Inscribed Alien Glyphs [message #37940 is a reply to message #37939 ] Fri, 04 November 2011 15:34 UTC Go to previous messageGo to next message
As far as I know, there no font of this type exists.
To give some background, these glyphs are meant to simulate something similar to the glyphs from the Necron race of the Warhammer 40,000 universe by Games Workshop. I've attached a photo at the bottom of examples of the script.
As these are copyright material of Games Workshop, I'm looking for something that looks similar but doesn't infringe on the original.
I will look into how hard it might be to create a font.
http://i205.photobucket.com/albums/bb70/rwwingate/4781860499_1a0635e421.jpg
Re: Commission: Blocks With Inscribed Alien Glyphs [message #37942 is a reply to message #37937 ] Fri, 04 November 2011 15:55 UTC Go to previous messageGo to next message
no need for fonts you can use alpha as a brush
http://www.3Dizingof.com
Re: Commission: Blocks With Inscribed Alien Glyphs [message #37943 is a reply to message #37942 ] Fri, 04 November 2011 16:01 UTC Go to previous messageGo to next message
another option is I could laser cut a half inch sheet of plywood with the images provided would cost a lot less then getting 3D printed. Unless you were planning to get mass produced as injection molded pieces later on.
Never mind these blocks are really small.
1 of each block would be roughly 43cc in WSF that would cost you $60
So I guess it would cost less if you need more then 1 as it would cost $200+shipping for a 24x12" sheet which works out to 60 of each if my math is correct.
[Updated on: Fri, 04 November 2011 16:08 UTC]
Re: Commission: Blocks With Inscribed Alien Glyphs [message #37944 is a reply to message #37943 ] Fri, 04 November 2011 16:07 UTC Go to previous messageGo to next message
I would be open to laser cutting.
I plan to make a silicon mold of the masters, so the source material is unimportant as long as it is smooth enough to cast.
Could you use MDF instead of plywood? I wouldn't want to see the layers of the plywood.
Re: Commission: Blocks With Inscribed Alien Glyphs [message #37946 is a reply to message #37944 ] Fri, 04 November 2011 16:09 UTC Go to previous messageGo to next message
can laser cut pretty much any material even metal but metal is expensive. however the laser cut will not be deep on the inscribing so would not work as silicon master. It gets burned black not engraved deep.
[Updated on: Fri, 04 November 2011 16:10 UTC]
Re: Commission: Blocks With Inscribed Alien Glyphs [message #37947 is a reply to message #37937 ] Fri, 04 November 2011 16:16 UTC Go to previous messageGo to next message
if it's for casting make the blocks hollow - it will make them cheaper to print with white Detail material or better with FUD
Re: Commission: Blocks With Inscribed Alien Glyphs [message #37948 is a reply to message #37947 ] Fri, 04 November 2011 16:17 UTC Go to previous messageGo to next message
true enough, 3d printing small blocks will not be expensive.
Re: Commission: Blocks With Inscribed Alien Glyphs [message #37949 is a reply to message #37937 ] Fri, 04 November 2011 16:26 UTC Go to previous messageGo to next message
0.4" wide glyph lines & a 0.3125" line height ?
0.4" deep ?
Seriously ? http://cheesebuerger.de/images/smilie/konfus/a015.gif
WH40K is 28mm scale... 0.04" sounds better to me...
[Updated on: Fri, 04 November 2011 16:31 UTC]
Re: Commission: Blocks With Inscribed Alien Glyphs [message #37950 is a reply to message #37937 ] Fri, 04 November 2011 16:39 UTC Go to previous messageGo to next message
Sorry for the error.
Line height = .04"
Depth = .04"
I'll change the drawing in the original post.
Those dimensions are driven by what I can comfortably paint and ink, if that is not achievable with the printing process I can change the dimensions.
Re: Commission: Blocks With Inscribed Alien Glyphs [message #37951 is a reply to message #37950 ] Fri, 04 November 2011 16:40 UTC Go to previous messageGo to next message
.04" is 1mm this is very easily printable.
Re: Commission: Blocks With Inscribed Alien Glyphs [message #37954 is a reply to message #37937 ] Fri, 04 November 2011 17:14 UTC Go to previous messageGo to next message
I attach a rough cut STL file
one face is negative the opposite is positive - 1mm deep/high for rough evaluation (not cleaned)
If this is what you had in mind (with or without lines) msg me with your budget for this project, i might take it.
Re: Commission: Blocks With Inscribed Alien Glyphs [message #37956 is a reply to message #37954 ] Fri, 04 November 2011 17:26 UTC Go to previous messageGo to next message
dizingof wrote on Fri, 04 November 2011 17:14
I'm sorry for the lack of experience with this but I don't have a program that can open STL files.
Re: Commission: Blocks With Inscribed Alien Glyphs [message #37957 is a reply to message #37956 ] Fri, 04 November 2011 17:29 UTC Go to previous messageGo to next message
Netfabb light
Re: Commission: Blocks With Inscribed Alien Glyphs [message #37959 is a reply to message #37957 ] Fri, 04 November 2011 17:52 UTC Go to previous messageGo to next message
Can't await to see the painted battlefield. ^^
\edit
updated STL
positive & negative side, both with 1/10 draft
  • Attachment: blockH.stl
    (Size: 651.49KB, Downloaded 37 time(s))
[Updated on: Fri, 04 November 2011 19:36 UTC]
Re: Commission: Blocks With Inscribed Alien Glyphs [message #37990 is a reply to message #37937 ] Fri, 04 November 2011 23:54 UTC Go to previous messageGo to next message
Thanks to everyone who submitted offers and advice. I have set up an agreement with an artist and am moving forward. This was my first thread at this board and I want to say what a pleasant little corner of the internet this place is.
Thanks to all.
Roger
Re: Commission: Blocks With Inscribed Alien Glyphs [message #38930 is a reply to message #37990 ] Sun, 20 November 2011 21:50 UTC Go to previous messageGo to next message
avatar Asphalt  is currently offline Asphalt
I am interested in these glyph blocks as well. Have any models been produced or uploaded?
Re: Commission: Blocks With Inscribed Alien Glyphs [message #38931 is a reply to message #37937 ] Sun, 20 November 2011 22:38 UTC Go to previous messageGo to next message
Yes. Cre83d did a great job on the models and I had them printed. They arrived a few days ago and I have a silicone mold of the masters curing as we speak. I should be able to cast the mold by tomrrow.
Here's some background on my project as well as some shots of the printed blocks:
http://thecolorblindmodelpainter.blogspot.com/
Re: Commission: Blocks With Inscribed Alien Glyphs [message #38932 is a reply to message #38931 ] Sun, 20 November 2011 23:06 UTC Go to previous messageGo to next message
Are the models available for purchase here? Or will be an un-sandblasted set be available elsewhere?
Re: Commission: Blocks With Inscribed Alien Glyphs [message #38933 is a reply to message #37937 ] Sun, 20 November 2011 23:31 UTC Go to previous messageGo to next message
I don't know how to work the shapeways store to make the blocks available to the public for printing, but I'll see if I can figure it out.
If you're planning to use them as I am for plaster copies, I can sell you a copy of the mold for about the same price as a 3D print (assuming it works). Send me a PM and let me know what you're looking for.
Re: Commission: Blocks With Inscribed Alien Glyphs [message #38935 is a reply to message #38933 ] Mon, 21 November 2011 00:14 UTC Go to previous messageGo to next message
I am thinking both blocks and plates.
Re: Commission: Blocks With Inscribed Alien Glyphs [message #38943 is a reply to message #38933 ] Mon, 21 November 2011 08:23 UTC Go to previous messageGo to next message
rwwin wrote on Sun, 20 November 2011 23:31
There...
index.php?t=getfile&id=12201&private=0
Click the "change" link, choose "Display to the public" and "Offer for sale to others", and then click "Update".
(Next step would be to disable the materials which are senseless for the specific model (in this case like glass, ceramic silver etc.), but that's basicaly just to give the shop a tidy look.)
  • Attachment: L.jpg
    (Size: 34.17KB, Downloaded 231 time(s))
Re: Commission: Blocks With Inscribed Alien Glyphs [message #38959 is a reply to message #38943 ] Mon, 21 November 2011 14:06 UTC Go to previous message
Previous Topic:Cufflink in 3D Help!
Next Topic:Looking for SFB Omega octant ships
