Home » Community » Post Production Techniques » Colored Resin in Stainless
Colored Resin in Stainless [message #20379] Thu, 11 November 2010 17:11 UTC Go to next message
avatar designerica  is currently offline designerica
Seems to work pretty well. The biggest problems I confronted were due to my inexperience with resin. The resin sticks to the steel with no problem and thicker resin fills small holes to create a potentially stained-glass effect as on the far left (though I used opaque colors here- translucent resin on butterfly wings will be next).
index.php?t=getfile&id=5865&private=0
Re: Colored Resin in Stainless [message #20380 is a reply to message #20379 ] Thu, 11 November 2010 17:13 UTC Go to previous messageGo to next message
a better photo of the band
index.php?t=getfile&id=5866&private=0
  • Attachment: band.jpg
    (Size: 539.46KB, Downloaded 687 time(s))
Re: Colored Resin in Stainless [message #21579 is a reply to message #20379 ] Mon, 13 December 2010 04:25 UTC Go to previous messageGo to next message
Ohhh those are nice! I really like the orbit ring.
www.RayTomlinDesigns.com
Re: Colored Resin in Stainless [message #22787 is a reply to message #21579 ] Tue, 18 January 2011 21:30 UTC Go to previous messageGo to next message
avatar Batjeepster  is currently offline Batjeepster
What about air bubbles? are you having any trouble with that??/ If not what type of resin are you using?
Re: Colored Resin in Stainless [message #22793 is a reply to message #22787 ] Tue, 18 January 2011 23:01 UTC Go to previous messageGo to next message
colores epoxy resin. to minimize bubbles i use a thin resin and run it over with a heat gun after it's poured to raise any bubbles that have formed. you just have to keep the heat gun far enough away that it doesn't make waves in the resin. it's not such a problem if you don't embed anything in the resin.
Re: Colored Resin in Stainless [message #22973 is a reply to message #20379 ] Mon, 24 January 2011 18:16 UTC Go to previous messageGo to next message
Really nice. I've been waiting for a clear resin to be shipped to me forever... Going to use it to embed items.
Glenn
Re: Colored Resin in Stainless [message #38928 is a reply to message #22973 ] Sun, 20 November 2011 20:24 UTC Go to previous messageGo to next message
epoxy resin-filled stainless blanks that i finished by sanding with a wolf belt sander (the belt is 1" wide and powered by a flex shaft with a foot pedal). had to keep everything wet so the resin wouldn't melt. blew through the regular belts but i did get good results from them, just not for too long. i used a number of different grits to get a nice smooth finish. next run will be with better belts.
originally i was going to spray them to get a gloss coat but i decided i like the matte finish better.
index.php?t=getfile&id=12196&private=0
Re: Colored Resin in Stainless [message #38929 is a reply to message #38928 ] Sun, 20 November 2011 20:28 UTC Go to previous message
there's more images of other rings with the same treatment on my designerica facebook page. its too hard to upload them here one at a time.
www.facebook.com/designericany
Previous Topic:Plaster Master Molds from Prints
Next Topic:Pewter Cast in RTV Silicone
