Home » Community » 3D modeler needed » RedFish
RedFish [message #38232] Wed, 09 November 2011 13:33 UTC Go to next message
avatar RedFish  is currently offline RedFish
I've browsed the "Modelers For Hire" threads and viewed several impressive portfolios. i didn't find an example similar to my concept.
I did find a statement about working from sketches on napkins that fits the bill since what I have is little more than that.
The attached picture shows where my idea began. I want to back light the block letter text on the instrument bezel in my car.
The raised fonts have a profile of only 1/32" X 1/32". Overall thinkness that light would pass through is appox. .7/32"
The matte black field needs to be a shell or nearly complete incasement of approx. .003 in wall thickness. Crisp detail and smooth finish is a must. Areas such as the triangle in the A would need a perminent bond of black over white material.
Your input is greatly appreciated, Ben
[Updated on: Wed, 09 November 2011 14:56 UTC]
Re: RedFish [message #38237 is a reply to message #38232 ] Wed, 09 November 2011 14:04 UTC Go to previous messageGo to next message
What diameter are you looking for?
Re: RedFish [message #38238 is a reply to message #38237 ] Wed, 09 November 2011 14:55 UTC Go to previous messageGo to next message
the fields are rectangles. of different sizes.
Smallest is 3/16' X 13/16". Largest approx. 1" X 7".
Re: RedFish [message #38240 is a reply to message #38232 ] Wed, 09 November 2011 15:28 UTC Go to previous messageGo to next message
I moved this to 3d modeler needed so you'll get more responses.
Re: RedFish [message #38295 is a reply to message #38240 ] Thu, 10 November 2011 12:28 UTC Go to previous messageGo to next message
My post wasn't really worded correctly for this section .
Properties of the materials is my first concern.
i would like for this to be my front burner project for this winter but.. I need to know if what I want to do is considered possible before I invest time and money in modeling. Cutting samples from the bezel for a modeler to work off of will scrap a part that is quite valuable. Meanwhile other worthy projects lay idle.. Hope you understand. Thanks, Ben
Re: RedFish [message #38447 is a reply to message #38295 ] Sat, 12 November 2011 13:26 UTC Go to previous messageGo to next message
160 views without replies.is disapointing.
Re: RedFish [message #38454 is a reply to message #38447 ] Sat, 12 November 2011 16:49 UTC Go to previous messageGo to next message
0.003" = 0.0762mm none of the materials at shapeways are capable of walls this thin.
Can you backlight a material? yes FUD would work pretty good with LED backlighting.
Re: RedFish [message #38470 is a reply to message #38454 ] Sat, 12 November 2011 23:59 UTC Go to previous messageGo to next message
mctrivia wrote on Sat, 12 November 2011 16:49
My suggestion of .003 was my minimum desired.
Painting the black is a very difficult and time consuming chore when restoring the OEM bezels. Creating in 2 colors deletes that chore. Scratches through paint would allow the light to show through also.
So what is the minimum wall thickness ?
The material I'm most intrested in is acrylic photopolymer. Can black be dispenced over the transparent and is a perminant bond black to transparent created ?
Maybe the part should be printed upside down. Maybe a interlock shape incorperated to hold the black and transparent together.
LED is considered my last resort today. I hope to use fiber optics to transport light from a single source.
Thanks for the reply too.
[Updated on: Sun, 13 November 2011 14:20 UTC]
Re: RedFish [message #38489 is a reply to message #38470 ] Sun, 13 November 2011 16:16 UTC Go to previous messageGo to next message
http://www.shapeways.com/materials
fiberoptics can be used also. i just like leds since I can buy 0403 leds wich are tiney.
Re: RedFish [message #38492 is a reply to message #38489 ] Sun, 13 November 2011 16:50 UTC Go to previous messageGo to next message
mctrivia wrote on Sun, 13 November 2011 16:16
I've looked at the materials and examples. Haven't found answers to all of my questions concerning 2 color construction there.
[Updated on: Sun, 13 November 2011 16:51 UTC]
Plan B [message #38534 is a reply to message #38492 ] Mon, 14 November 2011 14:41 UTC Go to previous messageGo to next message
Ok folks, I just got a email reply from Shapeways saying that 2 colors of material in one part is not possible. Maybe i should have assumed that from the examples shown. I will not give up though.
Plan B is to model the black and string frame those areas that appear unattached such as the triangle in the block letter A the the middle of an O, etc..
The translucent white material would be poured ( most likely by hand ) as a second operation.
So who wants to design the 3D models for the black ?
[Updated on: Mon, 14 November 2011 14:42 UTC]
Re: Plan B [message #38545 is a reply to message #38534 ] Mon, 14 November 2011 17:13 UTC Go to previous messageGo to next message
Hi Redfish,
This project sounds really interesting and I can help you with the 3D design part. I will send you a PM with a few more details and maybe we can chat about the project sometime.
And feel free to check out my website and portfolio in the meantime!
Jake D
http://JakeDrews.Com
Aut Viam Inveniam Aut Faciam
Re: Plan B [message #38731 is a reply to message #38545 ] Thu, 17 November 2011 12:12 UTC Go to previous message
Reverting back to acrylic polymer poured to silicone molds to recreate the bezel's switch labels for this project.
I'll still need to design the back piece(s) with means of attaching the acrylic portion and ports for the fiber optic strands to enter with some means of retaining those so they cant be pulled out. 3D printing may be the " method to the madness " there. Time will tell. Wish me luck Smile.
Previous Topic:Fortune Cookie Protoype
Next Topic:Modeler needed to design string attachment mechanism
