| Motor adjustment via shapeways [message #38067] Sun, 06 November 2011 16:23 UTC |
Hi Shapeways & Forum,
My Model arrived!!!
But I have to start earlier:
That's my tiny motorcycle. I've got a problem with the adjustment of the motor idling speed, especially in this cold time of the year. Sometimes the motor dies shortly after the start, because the cold motor wants more fuel and rotations. And when the motor is warm, its rotation speed is too high, it doesn't sound good and it gets too hot while standing.
There's a screw to adjust the idling, but I can't even take a picture of it because it's so hidden. So I want a "remote control" for the speed idling. But how to do this?
Every time I drive, I see this "control center", which is printed by shapeways (I'm very happy with it). So I've started to create a device for the idling problem that could be printed by shapeways again.
First of all I disassembled the carburetor from the bike and took a look at the screw that screws me.
After that I've drawn the carburetor in CAD.
Then I've created a worm gear.
But where's the remote control?
I've found a flexible shaft at ebay, it's originally a speedometer shaft, it costs about 2 €. ( www.ebay.de/itm/Hercules-Tachowelle-VDO-Instrumente-500mm-Sc hwarz-/270842453140)
That's the actual design of the device.
Here's a section view.
The easiest step was the production (for me ), I've uploaded the STL-File and ordered it in polished WSF (if you're interested: http://shpws.me/3rJf)
to be continued
| Re: Motor adjustment via shapeways [message #38068 is a reply to message #38067 ] Sun, 06 November 2011 16:25 UTC |
I love to open the shapeways packages, I get always excited like a little child.
I'm very happy with the result.
After cleaning the parts with a Dremel I've painted them (I love to do unnecessary things).
The picture above shows the assembly. I've used M2 screws.
I was surprised by the smooth movability of the gear.
Now I have to cut the flexible shaft...
...and fix it with the driven worm.
The worm gear will drive a simple hexagonal bit.
That's the other side of the shaft with the rotary knob and its holder.
| Re: Motor adjustment via shapeways [message #38069 is a reply to message #38068 ] Sun, 06 November 2011 16:26 UTC |
Then it was time to connect the device with the carburetor.
The adjusting knob is installed near the handle bar of the bike.
(someday I will clean the bike)
Now I can easily adjust the motor idling.
Thank you Shapeways!
Regards, Martin
(I'm sorry, my English isn't the best)
| Re: Motor adjustment via shapeways [message #38070 is a reply to message #38067 ] Sun, 06 November 2011 17:27 UTC |
That's so impressive, I love it!
| Re: Motor adjustment via shapeways [message #38078 is a reply to message #38069 ] Sun, 06 November 2011 20:12 UTC |
Bei Shapeways gibt's ja inzwischen so einiges...
Naja, überwiegend wohl Schmuck und irgendwelchen mehr oder minder dekorativen Nippes...
Inzwischen ist das hier auch ein beliebter Spielplatz für Modellbauer allerlei Maßstäbe...
Wahrscheinlich spricht da der Maschinenbauer in mir,
aber DAS ist mit Abstand der beste (u.a. weil der sinvollste^^) Einsatz dieser 3D-Druck Technologie der mir hier bisher untergekommen ist.
Ich hoffe du bist auch noch in irgendwelchen Krad-Foren oder sowas aktiv, und publizierst (auch) da dein Projekt...
Jedenfalls werde ich, vorausgesetzt das da von deiner Seite aus kein Ausdruck den Missfallens in meinem Postfach landet, den Link zu diesem Thread nächste Woche an mindestens zwei Technikerschulen rundreichen.
PS
Ich schreib' das auf deutsch weil mir dafür auf englisch grad echt die Worte fehlen. ^^
| Re: Motor adjustment via shapeways [message #38080 is a reply to message #38078 ] Sun, 06 November 2011 21:34 UTC |
Wow!
Very impressive work. It's applications like this that get me truly excited with the future of 3D printing.
How does it hold up with the heat from the engine?
| Re: Motor adjustment via shapeways [message #38085 is a reply to message #38067 ] Mon, 07 November 2011 01:03 UTC |
This is so cool. Great work!
| Re: Motor adjustment via shapeways [message #38116 is a reply to message #38067 ] Mon, 07 November 2011 16:20 UTC |
Hello everyone, thank you very much for your kind words.
Hi pfeiffer stylez, thank you, very nice comment (how did you noticed I'm from Germany ). Of cause you can show this to others, I would be happy.
Hi 2SeeKU, you've asked about the heat: The motor itself produces oil temperatures about 100° to 110° C, but the carburetor gets not so hot, maybe 50 °C. I'f it's very cold, I get more problems to avoid a freezing of this part.
Hi stop4stuff, you're right, that's the choke. I have to pull it to get the engine started, but it doesn't solve my idling speed problem (the idling motor speed with enabled choke is much too high).
Martin
| Re: Motor adjustment via shapeways [message #38118 is a reply to message #38069 ] Mon, 07 November 2011 17:54 UTC |
| Mortimer wrote on Sun, 06 November 2011 16:26 | [After cleaning the parts with a Dremel I've painted them (I love to do unnecessary things).
Yep, that would seem to describe you!. Excellent job on finding a solution to your problem.
Glenn
