| simple task for someone [message #37431] Thu, 27 October 2011 04:25 UTC |
Hi Guys,
New to this forum, and looking for a 3D model of the Millennium Falcon to print, but this only needs to be a basic, low-poly model, as I want it at 1/2256 scale (about 2.4cm).
Happy to pay a few bucks, but I do think this is a fairly easy request.
At this size, it can be solid, making the whole back-plane nonsense a non issue.
| Re: simple task for someone [message #37497 is a reply to message #37464 ] Thu, 27 October 2011 23:01 UTC |
That's pretty much EXACTLY what I want.
Thanks heaps!!
How do I go about getting that printed?
| Re: simple task for someone [message #37537 is a reply to message #37497 ] Fri, 28 October 2011 16:21 UTC |
I have no idea of how this works.... I guess I can send you the obj file. but there is sort of a problem with scale, can't really understand how to get it 2.4cm long
anyways, attached the file to this post.
| Re: simple task for someone [message #37545 is a reply to message #37537 ] Fri, 28 October 2011 17:37 UTC |
tried loading in netfabb but it failed. Normally this is what I would use to rescale to a specific size.
| Re: simple task for someone [message #37547 is a reply to message #37545 ] Fri, 28 October 2011 18:16 UTC |
do you have any idea of why it failed?
| Re: simple task for someone [message #37549 is a reply to message #37547 ] Fri, 28 October 2011 18:48 UTC |
error in the file. other programs I have will open with warning but don't know how to scale in those programs.
| Re: simple task for someone [message #37550 is a reply to message #37549 ] Fri, 28 October 2011 18:54 UTC |
Here you go. Maniged to convert to STL, fix errors and resize to 2.4cm long.
lost most of the detail when correcting file it seems
Attachment: mf.stl
(Size: 128.99KB, Downloaded 22 time(s))
[Updated on: Fri, 28 October 2011 18:54 UTC] Follow me on twitter http://twitter.com/mctrivia or my blog at http://4ddice.blogspot.com/
| Re: simple task for someone [message #37551 is a reply to message #37550 ] Fri, 28 October 2011 18:57 UTC |
here is without fixing the errors. shapeways will probably fix to be correct but may not.
Just tried it. Works well:
http://www.shapeways.com/model/367575/mf.html?gid=ug
Not for sale as it is not my model. Will remove in a week,
Attachment: mf.stl
(Size: 262.88KB, Downloaded 20 time(s))
[Updated on: Fri, 28 October 2011 19:02 UTC] Follow me on twitter http://twitter.com/mctrivia or my blog at http://4ddice.blogspot.com/
| Re: simple task for someone [message #37562 is a reply to message #37552 ] Fri, 28 October 2011 20:49 UTC |
only thing I find odd is that I did scale it in 3ds max to be 2.4 cm, but that for some reason did not work when I tried to upload it....
| Re: simple task for someone [message #37578 is a reply to message #37431 ] Fri, 28 October 2011 23:36 UTC |
Wow, and I mean WOW, you guys are AWESOME!!
I will upload now, thanks so much!
| Re: simple task for someone [message #37665 is a reply to message #37562 ] Mon, 31 October 2011 13:38 UTC |
| invidos wrote on Fri, 28 October 2011 20:49 | only thing I find odd is that I did scale it in 3ds max to be 2.4 cm, but that for some reason did not work when I tried to upload it....
Well some how the model came out 24 cm (I had to scale it down to 10%)
