Home » Support » 3D Printing » Nuts n Bolts!
Nuts n Bolts! [message #37267] Mon, 24 October 2011 18:51 UTC Go to next message
avatar Perefim  is currently offline Perefim
Nuts & Bolts
For decorative purposes if the threads are at the correct angle, can and will they work properly to be functional to say finger tight if done in stainless steel?
CEO of F.E. Energy, LLC - http://www.fe-energy.com/
Re: Nuts n Bolts! [message #37280 is a reply to message #37267 ] Tue, 25 October 2011 01:02 UTC Go to previous messageGo to next message
guess also will need to know if it will work in gold plated, sterling silver and bronze antiqued also.
Re: Nuts n Bolts! [message #37309 is a reply to message #37280 ] Tue, 25 October 2011 13:41 UTC Go to previous messageGo to next message
Still looking for an answer to this question. Would be great to know.
Re: Nuts n Bolts! [message #37325 is a reply to message #37267 ] Tue, 25 October 2011 15:25 UTC Go to previous messageGo to next message
You'd have to work with the tolerances and accuracy of each material. I'd say for stainless you'd want to go fairly large with a very loose fit, as even it it printed exactly right the surface is rough, and the friction would be immense. (Same with any plated stainless, glossy finish would be better, but still lots of friction and you'll wear the surface). For silver, could be interesting. You could go smaller, as the tolerances are lower, and the accuracy is very good. But with silver, 2 pieces must be 2 models except for sets like ear rings, cufflinks and such so you'd have 2 handling fees.
Re: Nuts n Bolts! [message #37327 is a reply to message #37325 ] Tue, 25 October 2011 15:35 UTC Go to previous messageGo to next message
Ah gotcha, thank you much for the info and the reply, both greatly appreciated. I have a feeling it may be better to have some sort of placement slots for actual bolts and nuts rather. Thank you for the info!
Re: Nuts n Bolts! [message #37328 is a reply to message #37267 ] Tue, 25 October 2011 15:48 UTC Go to previous messageGo to next message
No problem, I saw your question yesterday, but decided to wait to see if anyone that may have experience would answer, but that didn't happen.
Re: Nuts n Bolts! [message #37330 is a reply to message #37328 ] Tue, 25 October 2011 16:48 UTC Go to previous messageGo to next message
Yeah, I had a feeling the idea had been tried before, and had felt I knew the answer, but experience always trumps an educated guess.
So going to go with safer route on this one.
Re: Nuts n Bolts! [message #37409 is a reply to message #37330 ] Wed, 26 October 2011 22:25 UTC Go to previous messageGo to next message
Hi there,
I work for ProMetal, the company that prints SS and glass. The physical properties of the SS material and the surface condition of printed parts make this a bad option. This would be true for most traditionally cast metal parts as well. We do a lot of tapping here in the shop. This works out well. The SS material requires fresh, sharp tooling and relatively low machine feeds and speeds but it takes a good thread. We mostly use stainless bolts and screws when needed.
-G
Leonardo da Vinci
Re: Nuts n Bolts! [message #37410 is a reply to message #37409 ] Thu, 27 October 2011 00:08 UTC Go to previous message
Good to know and much appreciated, I decided to go with part slots which would be fit to the head of the bolt and allow for it to inset to the part.
Plus the traditional bolts are cheap and keep the printing cost lower. However I do appreciate the additional information very helpful.
Previous Topic:Repairing in Netfabb Basic
Next Topic:Polished WSF
