| Question on Gaps for Silver [message #36866] Tue, 18 October 2011 16:15 UTC |
So I have a very detailed small jewelry model that probably can't be printed anyways, but I get rejections that the gap between the details are too small. I haven't seen this mentioned anywhere in the design rules?
I have a really neat technique of filling in the grooves with my own enamel/resin blend so I'm curious what the limits are.
I thickened the details up quite a bit to be printable but I guess that leaves the gaps too small? Thanks for any help!
Attachment: 193334-3.jpg
(Size: 37.53KB, Downloaded 215 time(s))
| Re: Question on Gaps for Silver [message #36872 is a reply to message #36866 ] Tue, 18 October 2011 17:08 UTC |
The closest thing I see is that the distance between holes must be .6mm. I'm guessing this may be the number, but I'll see if I can't get you an official answer.
| Re: Question on Gaps for Silver [message #36878 is a reply to message #36866 ] Tue, 18 October 2011 17:29 UTC |
Thanks, YouKnowWho! I thought someone might have run into this before...
From an earlier rejection note, I think it's a problem with cleaning, not printing?
The silver Inca pendant I saw in the arrived forum section had some very small details and grooves.
Maybe my details are too deep? I figure I should sort out what I'm doing wrong before I keep tormenting whoever rejects models.
| Re: Question on Gaps for Silver [message #36882 is a reply to message #36866 ] Tue, 18 October 2011 17:57 UTC |
Ah maybe it has to do with the gap being smaller than the depth. It should be at least 1:1 if not wider than it is deep.
| Re: Question on Gaps for Silver [message #36893 is a reply to message #36866 ] Tue, 18 October 2011 18:33 UTC |
Ah, the 1:1 issue. Ok, so if my details were raised 1.5 mm, the gaps between details would also need to be 1.5mm?
| Re: Question on Gaps for Silver [message #36899 is a reply to message #36866 ] Tue, 18 October 2011 18:52 UTC |
exactly
| Re: Question on Gaps for Silver [message #36904 is a reply to message #36866 ] Tue, 18 October 2011 19:14 UTC |
Thanks YouKnowWho!!!! Glad there's always a shapie to answer my idiotic questions.
| Re: Question on Gaps for Silver [message #37121 is a reply to message #36905 ] Fri, 21 October 2011 15:54 UTC |
oooo good to know....
Ed
ERCK Store
