Home » Community » Post Production Techniques » Liver of Sulfur Patina
Liver of Sulfur Patina [message #36915] Tue, 18 October 2011 20:52 UTC Go to next message
My teacher only used LOS (Liver of Sulfur) or Potassium Sulfide (K2S) as her patina.
Some Electro techniques, bottled solutions or other chemical oxidizers just leave these materials black.
Her secret was a heated solution of 1 oz of K2S to 12 oz deionized water and a tablespoon of Ammonia (NH4). Other colors for Copper/Silver have other materials as she documents below...
This solution will start slow and then progress thru the colors from gold, to green, orange to purple then to iridescent black.
Dip quick, allow colors to diffuse then rinse quickly in deionized water. Wax or varnish to maintain oxidation and reduce tarnish.
Ed
index.php?t=getfile&id=11466&private=0
Reference: The Jeweler's Directory of Decorative Finishes, From Enameling and Engraving to Inlay and Granulation By Jinks McGrath
Patinating Copper (Brass and Bronze are copper alloys)
Deep Red Patina
1. Clean both sides of your metal under running water with a wet-and-dry paper towel.
2. Paste both sides with a flux paste – either borax flux, or a powder flux.
3. Heat the copper on one side until it glows orange. Turn it over and heat the
other side to the same color. Then quench it in water and pickle for a few minutes.
4. The copper should be a beautiful red-purple color. If it is not, simply repeat.
5. Gently polish or lightly oil the copper with either jade oil or soft beeswax.
Blue Patina
1. Fill a small saucer with household ammonia.
2. Cover the copper salt.
3. Dampen the salt with water or vinegar.
4. Place the copper and the saucer with the ammonia with in an airtight container.
5. Allow the copper to sit for several hours to several days. Remove when the desired coloration is reached.
Green-Blue Patina
1. Fill a sealable plastic container with either sawdust or tobacco.
2. Add enough of the following solution, one part vinegar to three parts household ammonia, to just dampen your sawdust.
3. Clean your copper by annealing, pickling, and running under water. Let dry.
4. Place the copper in the sawdust mixture and cover completely. Seal the container and leave for at least one hour to several days until the desire finish is reached.
Black Patina
1. Take a piece of Liver of Sulfur, about the size of your finger nail, and dissolve it in a cup or more of warm water.
2. Heat the piece of metal to be treated and then dip in the Liver of Sulfur solution.
3. Rinse in water after each dip until you reach your final desired color.
4. The piece may be sanded lightly and polished. Raised areas will show the original color of the metal, recessed areas will remained blackened.
5. Be sure to wear gloves and protective clothing when working with Liver of Sulfur. The fumes are dangerous and it should be used with good ventilation and covered right after use. It must not be allowed to come in contact with acids as a toxic gas is then rapidly evolved.
Patinating Silver
While Liver of Sulfur is usually used to form a black or gray patina on silver, there are a number of intermediate interference colors formed, especially if a weak solution is used. These include yellow, reddish brown, purple and blue. Some people recommend adding a small amount of household ammonia to the solution claiming it intensifies the lovely blue-green-red-purple interference colors one gets when using a dilute solution and slow approach. These pretty colors are not very stable over time because they continue to react with sulfur in the air and darken. You can sometimes 'save' them by spraying a lacquer over them. They may be retained if the surface is properly sealed. Acrylic resin is the recommended sealer for durability and resistance to darkening in light. Some jeweler's lacquers also work. Envirotex® works very well for this.
Using Liver of Sulfur on Silver
1.Take a piece of Liver of Sulfur, about the size of your finger nail, and dissolve it in a cup or more of warm water.
2.Heat the piece of metal to be treated and then dip in the Liver of Sulfur solution.
3.Rinse in water after each dip. While Liver of Sulfur is usually used to obtain gray and black colors on silver, there are a number of intermediate interference colors formed, especially if a weak solution is used. These include yellow, reddish brown, purple and blue. Some people recommend adding a small amount of household ammonia to the solution claiming it intensifies the lovely blue-green-red-purple interference colors one gets when using a dilute solution and slow approach. These pretty colors are not very stable over time because they continue to react with sulfur in the air and darken. You can sometimes 'save' them by spraying an appropriate lacquer over them. They may be retained if the surface is properly sealed. Acrylic resin is the recommended sealer for durability and resistance to darkening in light. Some jeweler's lacquers also work. Envirotex® works very well for this.
4.The piece may be sanded lightly and polished. Raised areas will show the original color of the metal, recessed areas will remained blackened.
5.Be sure to wear gloves and protective clothing when working with Liver of Sulfur. The fumes are dangerous and it should be used with good ventilation and covered right after use. It must not be allowed to come in contact with acids as a toxic gas is then rapidly evolved.
Ed
ERCK Store
Re: Liver of Sulfur Patina [message #36924 is a reply to message #36915 ] Tue, 18 October 2011 23:57 UTC Go to previous messageGo to next message
Fantastic,
Thanks, I will share on the blog.
Re: Liver of Sulfur Patina [message #39013 is a reply to message #36915 ] Mon, 21 November 2011 21:47 UTC Go to previous messageGo to next message
avatar volundr  is currently offline volundr
Thanks -- that's useful to know. I was wondering why my applications of liver of sulfur weren't working -- I think the metal needed to be hotter.
Re: Liver of Sulfur Patina [message #39400 is a reply to message #39013 ] Mon, 28 November 2011 19:04 UTC Go to previous message
avatar swbarrett  is currently offline swbarrett
Your metal doesn't actually need to be hot at all. I never heat mine, just heat the liver of sulfer solution (DO NOT BOIL IT). Liver of sulfer has a limited shelf life. Light and moisture will cause it to expire more quickly; the solid kind also has a shorter shelf life than the gel kind.
The reaction should begin almost instantly, if you're waiting around to see a change your LOS is expired.
Previous Topic:Chrome plating? Which is the best material?
Next Topic:Sealing WSF Dice
