Home » Community » Post Production Techniques » Copper nickel and gold plating
Copper nickel and gold plating [message #20182] Sat, 06 November 2010 22:18 UTC Go to next message
avatar baltimore  is currently offline baltimore
so i spent around $200 on a plating kit from caswell plating i got a 4 oz jar of 24k plating solution, 8 oz of copper and 8oz of nickel.
I've learned that I need to heavily polish the stainless steel to make it attach. I'm not happy with plating directly to gold, it looks ugly. It was suggested to me to do copper first, and then gold on the copper and i'll get a good result. Copper went on great. I haven't tried the nickel.
I'll update this later with more results. and pictures. my camera is charging so i cant take pics. i'll record video next time i do it though.
www.Custom3dStuff.com
Re: Copper nickel and gold plating [message #24787 is a reply to message #20182 ] Sat, 12 March 2011 00:41 UTC Go to previous messageGo to next message
avatar noesis  is currently offline noesis
Thinking about gold plating or gold leafing, any updates on your experiments? Any luck with gold?
Re: Copper nickel and gold plating [message #24789 is a reply to message #24787 ] Sat, 12 March 2011 00:46 UTC Go to previous messageGo to next message
Well, it works... kinda.
You need to polish really well and then nickel plate and then polish really well again and then gold plate, and then it works.
Copper works really easily but isn't so pretty.
Polishing a lot is the key to plating.
Paying shapeways to do it works really well though, and is worth your time.
Also the blackening solution at caswellplating.com works great too. It's just a dip, and it turns the surface of the metal black. rubbing it again with sandpaper makes it shiny. It's neat if you have a bumpy surface, turn it black, and then sand the high points down so they show up shiny. check the pic
https://lh3.googleusercontent.com/_iSF92uXnHLo/TW4yjN8sKFI/AAAAAAAAFac/vOqvIQfRni0/s800/IMG_20110301_205822.jpg
The darker one is darker than you see in the picture. it really makes it dark. Bad cellphone pic.
Re: Copper nickel and gold plating [message #24790 is a reply to message #24789 ] Sat, 12 March 2011 00:52 UTC Go to previous messageGo to next message
Hey that does look pretty cool! Must be how you did your green lantern ring right? I'm just looking for a cheap alternative to get a gold 'look' ordered a faux leafing kit for $12, I'll have to post results after I've tried it. Thanks for the update!
icon14.gif  Re: Copper nickel and gold plating [message #24791 is a reply to message #24790 ] Sat, 12 March 2011 00:55 UTC Go to previous messageGo to next message
http://www.yourprops.com/norm-4d7a830050159-Green+Lantern+%282011%29.jpeg
icon12.gif  Re: Copper nickel and gold plating [message #36913 is a reply to message #24791 ] Tue, 18 October 2011 20:35 UTC Go to previous message
avatar erckgillis  is currently offline erckgillis
Experienced Caswell plating guru... Rolling Eyes
While their materials and kits are great the solutions are very expensive. You can often find the same solutions at chemical supply houses online.
yes the shiny nickel or silver plate will help the gold shine and adhere firmly.
For a patina other than black try a Liver of Sulfur (Potassium Sulfate) and Ammonia heated to 110 deg F from this you can get colors like green, purple to gold from many materials and then protect the finish with a hard wax or clear coat.
I have not tried the spray on or pens for items as these are faux finishes and I give my customers real metals in silver, gold or other metal finishes.
Ed
Ed
ERCK Store
Previous Topic:Electroplating Plastic?
Next Topic:Silver soldering
