| uploading from solidworks [message #36380] Tue, 11 October 2011 00:37 UTC |
used to be when i uploaded from solidworks, the first time i opened a model on shapeways it would make me check a box to agree with some stuff i've never read. it's no longer coming up, and it's also not allowing me to add the new files to my cart. so the solidworks plugin seems to have become useless.
| Re: uploading from solidworks [message #36383 is a reply to message #36380 ] Tue, 11 October 2011 02:16 UTC |
Hey Erica,
Have you upgraded to a new version of Solidworks? or made any changes? What version are you running?
I will see if there has been any changes to the API that could be making this happen.
Thanks for letting us know.
| Re: uploading from solidworks [message #36386 is a reply to message #36383 ] Tue, 11 October 2011 02:33 UTC |
The problem is shapeways change the interface to not require the click to accept the user agrement without removing that requirement from the API(which is what solid works uses to upload). I am not sure if anyone at shapeways knows how to do this any more but there is a bypass on a shop by shop bases that will remove the requirement to do this.
| Re: uploading from solidworks [message #36387 is a reply to message #36383 ] Tue, 11 October 2011 02:46 UTC |
no, i changed nothing. it's gotta be a problem with the new interface.
| Re: uploading from solidworks [message #36388 is a reply to message #36386 ] Tue, 11 October 2011 02:57 UTC |
Thanks Mctrivia,
I have flagged it and will see if we can fix it ASAP
| Re: uploading from solidworks [message #36389 is a reply to message #36388 ] Tue, 11 October 2011 02:59 UTC |
look for my shops in the database. propmodule and icc I had them both exempt from this system. May help find how to excempt others or everyone.
