Home » Support » 3D Applications » 3ds Max texture export problem
icon9.gif  3ds Max texture export problem [message #35234] Tue, 27 September 2011 08:59 UTC Go to next message
avatar sevensheaven  is currently offline sevensheaven
Hi guys,
I've created a model (units: meters), baked a texture in it, and it looks correct in 3ds Max. But I can't get a reference to the accompanying texture to be included in a VRML97 export from 3ds Max. A texture reference is missing in the output file.
I've tried adding the texture reference manually to the VRML97 file with a text editor, but then Meshlab gave me errors about missing or too much parentheses, which I couldn't get fixed.
A Zip with the 3ds Max 2012 file and texture can be downloaded from here. Any help would be appreciated.
Many thanks in advance.
http://sevensheaven.nl — 3D modeling • 3D printing • animation • characters • icons • illustration • infographics • visualization
Re: 3ds Max texture export problem [message #35235 is a reply to message #35234 ] Tue, 27 September 2011 09:04 UTC Go to previous messageGo to next message
Did you try opening the VRML file in MeshLab before editing the file?
Re: 3ds Max texture export problem [message #35236 is a reply to message #35235 ] Tue, 27 September 2011 09:14 UTC Go to previous messageGo to next message
Hey Metin,
when you say 'baked in a texture', do you mean you UV-mapped it? Or did you do something else.
I'm not sure how 3DS Max works, but we require UV mapped textures.
Re: 3ds Max texture export problem [message #35237 is a reply to message #35236 ] Tue, 27 September 2011 09:24 UTC Go to previous messageGo to next message
Hi Bart,
Did something change?
http://www.shapeways.com/tutorials/exporting_to_vrml_and_x3d _for_color_printing says per face colouring can be uploaded which I experimented with last week - http://www.shapeways.com/model/335991/5e65eaedfe3a0d7faf588c 0043ad250d/colour_police_phone_box_vertex_face_colour.html?g id=ug
Re: 3ds Max texture export problem [message #35238 is a reply to message #35237 ] Tue, 27 September 2011 09:38 UTC Go to previous messageGo to next message
For sure, you can use vertex/face coloring as well. But as sevensheaven was referring to a texture map reference I figured the problem was related to texturemapping Wink
Re: 3ds Max texture export problem [message #35239 is a reply to message #35238 ] Tue, 27 September 2011 09:44 UTC Go to previous messageGo to next message
I figured the same, but as 'baked in' is mentioned, I'm thinking that the sevensheaven's colouring is per face.
@sevensheaven - more info is needed please Smile
Re: 3ds Max texture export problem [message #35242 is a reply to message #35239 ] Tue, 27 September 2011 11:24 UTC Go to previous messageGo to next message
Many thanks for your replies!
I tried importing the Max-exported VRML97 file in Meshlab first, but it indicates no presence of a texture. When I export it from Meshlab, there's no texture entry in the resulting WRL file, because the texture reference is already missing in the 3ds Max WRL export.
In 3ds Max itself (Standard material with diffuse map) the texture is showing correctly on the model. I have followed the instructions in this page, but used the mesh's own UV coordinates for baking the texture in stead of an unwrap method, otherwise the texture became mangled on the model.
But somehow the texture reference isn't saved along in the 3ds Max VRML97 export. The Max-exported VRML97 file + texture can be downloaded here, and here's the Max file + texture.
[Updated on: Tue, 27 September 2011 11:26 UTC]
Re: 3ds Max texture export problem [message #35243 is a reply to message #35242 ] Tue, 27 September 2011 11:45 UTC Go to previous messageGo to next message
Hi Martin,
Have you checked the export settings of the file in 3ds max?
Maybe one of the check boxes is marked as yes but should be no?
Re: 3ds Max texture export problem [message #35246 is a reply to message #35234 ] Tue, 27 September 2011 13:15 UTC Go to previous messageGo to next message
I'd be happy to take a look, can you save a legacy max (2010) file ?
Re: 3ds Max texture export problem [message #35249 is a reply to message #35246 ] Tue, 27 September 2011 13:45 UTC Go to previous messageGo to next message
Thanks again for your feedback guys, much appreciated.
Virtox, it'd be great if you could take a look. Here's a Max 2010 version of the file, including the texture.
Many thanks in advance. You can also reach me at metin [at] sevensheaven [dot] nl
[Updated on: Tue, 27 September 2011 13:45 UTC]
Re: 3ds Max texture export problem [message #35251 is a reply to message #35234 ] Tue, 27 September 2011 14:11 UTC Go to previous messageGo to next message
The material currently assigned to the object is a "shell" material, which is not compatible with the wrl exporter and is thus ignored.
If I assign the medit material, or one of the submaterials of the shell, the texture gets exported mostly correct.
Only the base is somehow mapped wrong, which I can't explain (yet)
Hint: the file will be twice as large if exported ok, because it will contain texture coordinates Smile
I am not sure how to fix the base, probably best to collapse the whole object and reapply mapping for the base only.
Re: 3ds Max texture export problem [message #35255 is a reply to message #35251 ] Tue, 27 September 2011 14:52 UTC Go to previous messageGo to next message
Thanks a lot Virtox!
You're right, when I reassign the Material Editor's material a bitmap path appears in the VRML97 export. Weird, as the same material should have already been assigned to the mesh.
Maybe the baking process caused a different material to become active on the mesh. I hadn't used baking before.
Going to reupload the mesh and texture now, hope it works, and thanks again!
Re: 3ds Max texture export problem [message #35256 is a reply to message #35255 ] Tue, 27 September 2011 14:55 UTC Go to previous messageGo to next message
Your welcome, btw you can use meshlab (freeware->google) to check how things look quickly Smile
Re: 3ds Max texture export problem [message #35257 is a reply to message #35256 ] Tue, 27 September 2011 14:59 UTC Go to previous message
It looks good in Meshlab! You da man, Virtox! ☺
Previous Topic:Vectorworks 2010. Anyone using it?
Next Topic:Lightwave thickness checking scripts
