Home » Community » Work in progress » Breakable Egg
Breakable Egg [message #34940] Fri, 23 September 2011 06:45 UTC Go to next message
We were speaking in another thread about breaking Full Color Sandstone models for testing purpose, and this gave me an idea: what about a model you actually had to break?
For instance an egg. You would do that to discover a hidden message inside.
Here is the concept:
index.php?t=getfile&id=11108&private=0
The shell has a lot of little holes that make the structure more fragile and easy to break. Because of the new rule I had to make a bigger hole on the bottom to allow the support material to go out, but this ruins a little bit the concept because the secret message could be read without breaking the egg (although I tried to write the message around the hole).
If it works, I will do it as a co-creator, but I still have to think about how to hide better the message without making it difficult to remove the support material...
What do you think?
[Updated on: Fri, 23 September 2011 06:48 UTC]
Re: Breakable Egg [message #34949 is a reply to message #34940 ] Fri, 23 September 2011 09:04 UTC Go to previous messageGo to next message
I thought about it: if I make the bottom of the egg with a thickness larger than the diameter of the hole, the message should be hidden.
Re: Breakable Egg [message #34950 is a reply to message #34940 ] Fri, 23 September 2011 09:12 UTC Go to previous messageGo to next message
Very cool! Smile
You could also add a sort of chimney cap on the inside to let powder out, but no peeking in
Re: Breakable Egg [message #34963 is a reply to message #34950 ] Fri, 23 September 2011 12:19 UTC Go to previous messageGo to next message
i am sure they will change the rule or give you an exception. those smaller holes should allow for good drainage since there are so many.
Re: Breakable Egg [message #34974 is a reply to message #34940 ] Fri, 23 September 2011 13:03 UTC Go to previous messageGo to next message
The rule has changed, the more holes the smaller they can be. I'd email Nancy with the number and size of the holes just to be sure.
Re: Breakable Egg [message #34990 is a reply to message #34940 ] Fri, 23 September 2011 15:37 UTC Go to previous messageGo to next message
Nice one!
You could scramble the message Rolling Eyes
Re: Breakable Egg [message #35018 is a reply to message #34990 ] Fri, 23 September 2011 21:25 UTC Go to previous message
Thank you all. Smile
Here is the new version:
index.php?t=getfile&id=11126&private=0
With a thicker bottom, you can hardly see anything written in the lower part (lower than the small holes).
And the lower inertia center should make the egg stand vertically.
I still have to figure out how to save properly the texture coordinates in the WRL though... Sad
[Updated on: Fri, 23 September 2011 21:27 UTC]
Previous Topic:Coffee not Included
Next Topic:Question. Interlocking pieces tolerance?
