Question: Do bump maps print?
Question: Do bump maps print? [message #34624] Tue, 20 September 2011 03:00 UTC Go to next message
avatar Joel_Cairo  is currently offline Joel_Cairo
Greetings-
Can some CAD expert tell me, if I apply a bump map to a part drawn in Rhino (for example), will the final printed part have the bump map texture on it?
Thank you-
[Updated on: Tue, 20 September 2011 14:27 UTC]
Re: Question: Do bump maps print? [message #34632 is a reply to message #34624 ] Tue, 20 September 2011 06:39 UTC Go to previous messageGo to next message
No. Any surface features need to be modelled as the printers (arpart from colour sandstone) only print the underlaying mesh.
Re: Question: Do bump maps print? [message #34647 is a reply to message #34632 ] Tue, 20 September 2011 10:35 UTC Go to previous messageGo to next message
avatar phildlight  is currently offline phildlight
Take a look at Zbrush http://www.pixologic.com/home.php
and here: http://www.pixologic.com/zbrush/features/07_brushes/
and here:
http://www.pixologic.com/zbrush/features/Surface-Noise/
You can "paint" bump maps (alpha maps) on geometry which actually modifies the geometry and would print if the surface detail is deep enough.
There are even tutorials in the forum that show you step by step how to export the model for 3d printing.
Philip Light
Re: Question: Do bump maps print? [message #34649 is a reply to message #34647 ] Tue, 20 September 2011 11:17 UTC Go to previous messageGo to next message
There's a feature in 3ds Max to turn the bump map into actual mesh data, but depending on what you need, it may not give sufficient quality.
Kaetemi
Re: Question: Do bump maps print? [message #34682 is a reply to message #34647 ] Tue, 20 September 2011 14:33 UTC Go to previous message
Thanks for the replies. The Zbrush info looks promising. I'll have to see how well it imports a Rhino-created export.
Regards-
Previous Topic:Dice Packs
Next Topic:Puzzled
