Model Help
icon9.gif  Model Help [message #34509] Sun, 18 September 2011 01:52 UTC Go to next message
avatar MODbot  is currently offline MODbot
can someone give me some advice? I have a decent amount of experience with 3D modeling. I am able to upload an stl file to your site successfully. However it never looks like it is supposed to in my gallery. I am able to render these models in rhino or 3D max and they look as I want them too but for some reason your site is reading them in a different way. I am not sure what I am doing wrong. see roses bracelet in skosor gallery. Attached is a photo of what it looks like when I render it quickly in Vray. If anyone has any advice, I would greatly appreciate it. thank you.
Re: Model Help [message #34510 is a reply to message #34509 ] Sun, 18 September 2011 02:34 UTC Go to previous messageGo to next message
Can you share the STL? If you'd rather keep it private, just send it via PM .
Re: Model Help [message #34516 is a reply to message #34509 ] Sun, 18 September 2011 07:15 UTC Go to previous messageGo to next message
Shapeways Crew
Hi Skosor and welcome to Shapeways.
Did you try to collapse all the modifier stack? Convert your model to "editable poly" should do the trick.
You can also try to add the STL Check modifier to see if there is no double edge or open edge... (you can remove this modifier before exporting).
Re: Model Help [message #34561 is a reply to message #34516 ] Mon, 19 September 2011 02:18 UTC Go to previous message
I am using rhino. I do not have an option for a editable poly. please advise.
thank you.
Previous Topic:If I print a cone from a 24 sided circle......?
Next Topic:SWF colors
