Home » Community » General Discussion » Stainless steel material not available?
Stainless steel material not available? [message #33888] Tue, 06 September 2011 20:16 UTC Go to next message
avatar Hoaxi  is currently offline Hoaxi
I uploaded a model and everything went ok it was accepted... I'd like to order it in stainless steel but I don't have the option available.. Why?
Re: Stainless steel material not available? [message #33889 is a reply to message #33888 ] Tue, 06 September 2011 20:19 UTC Go to previous messageGo to next message
What was the size (down the right side it will tell you the bounding box size) If it's larger than 100cmx45cmx25cm, that it can't be printed in stainless. But it may be possible to re-orient you drawing so that it will fit.
Re: Stainless steel material not available? [message #33890 is a reply to message #33889 ] Tue, 06 September 2011 20:27 UTC Go to previous messageGo to next message
Hmm, it says 0.4x0.4x0.1 in centimeters...
That's weird, I made it 4x4x1 cm in max.. Should I make it 40x40 for it to be correct?
Re: Stainless steel material not available? [message #34369 is a reply to message #33888 ] Fri, 16 September 2011 14:54 UTC Go to previous message
Make sure you have checked off the correct button when uploading it - i.e. inches, millimetres, etc.
Glenn
Previous Topic:White Strong and Flexible POLISHED
Next Topic:'Beta version' - What does this mean.
