Vinyl record wall mount with little birds
Vinyl record wall mount with little birds [message #34104] Sat, 10 September 2011 15:59 UTC Go to next message
avatar Danyboy  is currently offline Danyboy
index.php?t=getfile&id=10955&private=0
My prints arrived a long time ago, but without a proper rotary hammer I wasn't able to drill the necessary holes in the wall. Not so any longer!
index.php?t=getfile&id=10954&private=0
While I'm quite content with the quality of the prints, the quality of the design has some room for improvement. The U-profiles should be a bit bigger/stronger so they flex less.
index.php?t=getfile&id=10953&private=0
The idea for the birds is shamelessly copied from the well known egg-nest-cups. Now that I know the concept of the clips works I can design other bits of 'flair' to add to the next batch of mounts (there's a whole lot of wall still left to fill up!)
index.php?t=getfile&id=10956&private=0
Re: Vinyl record wall mount with little birds [message #34135 is a reply to message #34104 ] Mon, 12 September 2011 06:28 UTC Go to previous messageGo to next message
SWEET!!!!!!!!!!!!!!!!
Duann Scott,
Re: Vinyl record wall mount with little birds [message #34136 is a reply to message #34135 ] Mon, 12 September 2011 07:13 UTC Go to previous messageGo to next message
This is what 3D printing is meant for!
customizing stuff which you really use!
So cool man!
Customer Service Coordinator
Shapeways
Re: Vinyl record wall mount with little birds [message #34581 is a reply to message #34104 ] Mon, 19 September 2011 14:51 UTC Go to previous messageGo to next message
Excellent idea... and there are so many music related icons you could use for the clips.
...I must have about 60 of my old vinyl albums still, but probably not enough space to hang them all!
Glenn
Re: Vinyl record wall mount with little birds [message #38574 is a reply to message #34104 ] Mon, 14 November 2011 22:49 UTC Go to previous message
Slow progress, but I found some time for a second piece of decoration. The print turned out better than I dared expect.
index.php?t=getfile&id=12015&private=0
The model needs a bit of tweaking, because I think one of the notes might have fallen off somewhere in the production process. I hadn't quite taken the flexibility of the 'lines' into account. Furthermore, the whole model needs some pre-bend upwards to compensate the effects of gravity and better match the model to the record behind it.
By combining these small models with some larger orders for work, I can do some cheap but cute home decorating! I really like the print quality of these small items!
  • Attachment: notes1.jpg
    (Size: 219.23KB, Downloaded 422 time(s))
Previous Topic:Very Dissappointed.
Next Topic:Stainless and Fine Detail Septagon
