Home » Community » General Discussion » material that would last in swimming pool water?
material that would last in swimming pool water? [message #33675] Fri, 02 September 2011 03:51 UTC Go to next message
avatar poolguy  is currently offline poolguy
I am looking for which material to use that would last in swimming pool water? Always underwater and exposed to chemicals and UV. What can you recommend as the correct material that I should be looking at?
Re: material that would last in swimming pool water? [message #33680 is a reply to message #33675 ] Fri, 02 September 2011 07:29 UTC Go to previous messageGo to next message
White, Strong and Flexible(WSF) is probably your best choice. Note that WSF is porous and will discolour over time, but a UV resisant coating would seal & protect. There's a Nylon chemical resistance chart here, but you might find more specific information by searching for Nylon 12.
[Updated on: Fri, 02 September 2011 07:30 UTC]
Re: material that would last in swimming pool water? [message #33703 is a reply to message #33680 ] Fri, 02 September 2011 15:00 UTC Go to previous message
avatar MuseumofSmallThings  is currently offline MuseumofSmallThings
Also the Stainless steel material is bronze infused so is quite similar in composition to marine grade stainless and should last indefinitely underwater with zero issues regarding UV.
Leigh
Previous Topic:FUD Delays
Next Topic:draft prints
