Home » Support » 3D Design » Inverted normals? Where?
icon5.gif  Inverted normals? Where? [message #3164] Sun, 01 March 2009 19:34 UTC Go to next message
avatar bradjensen68  is currently offline bradjensen68
Ok, I am posting my first design to Shapeways (attached) and Joris is telling me that I have inverted normals, however when I run Rhino's CheckMesh, it says:
This is a good mesh.
General information about this mesh:
Mesh does not have any degenerate faces.
Mesh does not have any zero length edges.
Mesh does not have any non manifold edges.
Mesh does not have any naked edges.
Mesh does not have any duplicate faces.
Mesh does not have any faces that could make it better if their directions were flipped.
Mesh does not have any disjoint pieces.
Mesh does not have any unused vertices.
Layer name: Default
Render Material:
source = from layer
index = -1
Attribute UserData:
UserData ID: B0EE2168-8EC6-42ed-A962-26DEB8CC8F9A
Plug-in: Rhino Render
description: Rhino Renderable Object UserData
saved in file: no
copy count: 1
Geometry:
Valid mesh.
Closed polygon mesh: 3204 vertices, 1068 polygons with normals
bounding box: (-4.9841,-5.37043,-2.53855) to (4.44205,4.49075,2.3198)
How do I fix this if my software says there is nothing to fix???
  • Attachment: hex.stl
    (Size: 349.05KB, Downloaded 122 time(s))
Re: Inverted normals? Where? [message #3166 is a reply to message #3164 ] Sun, 01 March 2009 20:27 UTC Go to previous messageGo to next message
avatar daddymack  is currently offline daddymack
Hmm... dunno what's going wrong Brad, I checked it here and it upped fine (imported to max and exported as .dae)
It worked here
http://www.shapeways.com/model/19782/hex_test.html
  • Attachment: hex.DAE
    (Size: 149.91KB, Downloaded 115 time(s))
Re: Inverted normals? Where? [message #3171 is a reply to message #3164 ] Sun, 01 March 2009 23:25 UTC Go to previous messageGo to next message
Cool, thanks. Does it only work in DAE? I was trying to upload it directly in STL and then I tried it in VRML and neither worked.
I will give it a try in DAE. Hopefully, I can get the scaling right because the part that you successfully uploaded is much smaller than was intended.
-- Brad
Re: Inverted normals? Where? [message #3174 is a reply to message #3164 ] Mon, 02 March 2009 00:04 UTC Go to previous messageGo to next message
Heh heh. I figured it out. Wrong units (millimeters instead of inches). Embarassed
Re: Inverted normals? Where? [message #3175 is a reply to message #3164 ] Mon, 02 March 2009 00:50 UTC Go to previous messageGo to next message
I use accutrans for final output to .dae usually because you can adjust the final output size when saving.
There is a tut on how to do the basics in accutrans somewhere in the blog
Good luck;)
Re: Inverted normals? Where? [message #3178 is a reply to message #3164 ] Mon, 02 March 2009 01:48 UTC Go to previous messageGo to next message
Thanks, that is what I did (Accutrans) and it worked out fine, but now I have a new problem. My model is rather big and would cost me over $2000 to print! I think if I hollow it out, I can reduce the price. Since the final product is supposed to be weight bearing, this obviously will only work as a prototype, but at least it will get me one step further. The other option is to build a smaller scale prototype.
Oh well, back to work on the model....
Re: Inverted normals? Where? [message #3209 is a reply to message #3178 ] Mon, 02 March 2009 22:34 UTC Go to previous messageGo to next message
avatar PeterHermans  is currently offline PeterHermans
I'm having the same problem, Shapeways validation check gives me the message that there are inverted normals. But, according to magics, there aren't any (not even intersecting or overlapping polys).
Now, my model has some extremely small features (.1mm or even smaller) but I am expecting these to 'wash out' in the printing, that's ok - manually taking out the detail would take forever.
But I suspect that these small features are picked up by the different tolerances in the Shapeways validator as errors.
I tried uploading a number of different stl files and I also used accutrans to convert to .dae. All generate the same result.
I e-mailed Joris already, I hope they can fix the issue (or at least tell me what exactly is wrong with my model).
Edit: I just did a mini-test and I found out that Magics does not detect non-manifold issue #2; shared edges (as shown here: http://www.shapeways.com/tutorials/errors) as an error - it just sees it as two separate shells. Although the validation check should give me a different error than flipped normals it is strange that magics does not detect this.
Come to think of it, why would this be an issue for printing? So what if it is very thin and might break - if that was the way it was modeled
[Updated on: Mon, 02 March 2009 22:43 UTC]
Re: Inverted normals? Where? [message #3301 is a reply to message #3209 ] Tue, 10 March 2009 22:24 UTC Go to previous messageGo to next message
avatar AO  is currently offline AO
Hi Peter.
I think meshlab solves the problems with the double features. Try to open the magics stl in Meshlab ( it will ask you to delete teh doubles ) and save it again as a stl.
And it will be printable.
I also have problems with the scaling. I have to figure out how to solve that too. If you know have. I would be happy if you could post it here. I tried also accutrans but it doesn't work always.
Greetings AO
Re: Inverted normals? Where? [message #3305 is a reply to message #3301 ] Wed, 11 March 2009 02:24 UTC Go to previous messageGo to next message
In Accutrans
Click on Adjust Object Property
Then choose "Units"
Choose the appropriate units for "Import Units" and "Export Units"
Click "Ok"
Click "Scale"
Re: Inverted normals? Where? [message #3361 is a reply to message #3301 ] Fri, 13 March 2009 21:56 UTC Go to previous messageGo to next message
AO wrote on Tue, 10 March 2009 22:24
Hi Peter.
Greetings AO
I tried it and meshlab does remove vertices (points). Taken it back into magics: no errors. Upload to shapeways: inverted normals error!
Scaled it 5x as big (so small details might be less of a problem: same error.
I'm lost on this one. Crying or Very Sad
Re: Inverted normals? Where? [message #3362 is a reply to message #3164 ] Sat, 14 March 2009 00:30 UTC Go to previous messageGo to next message
Hi AO, feel free to send it to me and I'll run it thru my tests... mack3d at hotmail dot com
Re: Inverted normals? Where? [message #3365 is a reply to message #3362 ] Sat, 14 March 2009 09:41 UTC Go to previous messageGo to next message
Hi Daddymack,
Thanks for offering your help.
But its Peter who needs a hand. A bit weird because he's using a very sofisticated softwaretool to prepare his files.
I'm impressed about your proffesional skills as an artist and modeler and offcoarse also you being prepared to help others.
I showed your work to Didier Francini of Papo in France.
He's convinced that they way you work its the future in modeling. Feel free to contact him and mention my name ( Arjan Moors ).
Thanks again. Greetings AO
Re: Inverted normals? Where? [message #3367 is a reply to message #3164 ] Sat, 14 March 2009 10:44 UTC Go to previous message
Daddymack, I sent you an e-mail Smile. Thanks for your help. Hope you can figure out what's wrong.
Previous Topic:0073 Sunglasses Degma Carrara + 3DS
Next Topic:Normals and Rhino 4
