Led candle
Led candle [message #33225] Wed, 24 August 2011 13:04 UTC Go to next message
avatar julspower  is currently offline julspower
Hi
Im looking to build an E-Candle
something that looks like
http://www.hero-ledstore.com/images/categories/Original-Cand le-Replacement.jpg
3d printing seem the way to go to build it
the interior will hold the battery and a control pcb
I would like to have mostly the flame illuminated
But im not very good in cad (only did some 123D)
so here are my questions:
1. what material should be used?
2. is it possible to use different matirial for the base and for the flame? (must have 2 different part?)
3. is there anyone who would like to help me up with cad (or start a project for it)?
Thanks guys
Re: Led candle [message #33277 is a reply to message #33225 ] Thu, 25 August 2011 01:19 UTC Go to previous messageGo to next message
Do you just need help learning to the CAD to create the Candle or are you looking to hire someone to design the candle for you?
If you are looking for a designer, I am your guy. Shoot me a PM if your interested and check out my website (http://JakeDrews.Com) and my Shapeways Shop (http://wondrouswidgets.com) in the meantime!
Jake
Aut Viam Inveniam Aut Faciam
Re: Led candle [message #33279 is a reply to message #33225 ] Thu, 25 August 2011 01:31 UTC Go to previous messageGo to next message
Hi
idealy help on learning
atm im using 123D
I can create a symetric drop
but Im not able to move the top to make like look a little more as a flame
And also answer to my questions would be appreciated
[Updated on: Thu, 25 August 2011 01:32 UTC]
Re: Led candle [message #33282 is a reply to message #33225 ] Thu, 25 August 2011 02:46 UTC Go to previous messageGo to next message
I see, I do not have any experience with 123D (although it looks interesting...)
But you CAN use different materials, they would have to be 2 different parts though. I recomend using the WSF material, since its cheaper...however, you could use the Sandstone material for the body and WSF or Transparent Detail for the flame. This is deffinitely something that you will have to try out and play with a little bit.
Good luck!
Let me know if I can help you with anything
Jake
Re: Led candle [message #33284 is a reply to message #33225 ] Thu, 25 August 2011 03:01 UTC Go to previous message
i tough of wfs for body and glass for the flame since its matte it could give cute results
thank you for confirming on the 2 part
Previous Topic:3D Modeler Needed To Design Lego Helmet
Next Topic:I need someone to make me a lego ARC helmet
