Finally! - SBB L6
Finally! - SBB L6 [message #32903] Thu, 18 August 2011 17:55 UTC Go to next message
avatar JanitorMaster  is currently offline JanitorMaster
My very first 3D printing arrived, and I'm very excited!
It's the SBB L6 I mentioned earlier:
http://h3.abload.de/img/dsc_0543-adfpk.jpg
The coin is 17.2mm (0.68 inches) in diameter.
Re: Finally! - SBB L6 [message #32928 is a reply to message #32903 ] Fri, 19 August 2011 05:14 UTC Go to previous messageGo to next message
Co-Founder
Great! Please post pictures of the finished model. I am very curious how they look!
icon14.gif  Re: Finally! - SBB L6 [message #32929 is a reply to message #32928 ] Fri, 19 August 2011 06:13 UTC Go to previous messageGo to next message
avatar coaster  is currently offline coaster
Awesome
Re: Finally! - SBB L6 [message #32938 is a reply to message #32903 ] Fri, 19 August 2011 08:59 UTC Go to previous messageGo to next message
avatar fx  is currently offline fx
Looks great ! I guess the rivets will only show up once the model is painted.
Re: Finally! - SBB L6 [message #32940 is a reply to message #32938 ] Fri, 19 August 2011 10:41 UTC Go to previous messageGo to next message
fx wrote on Fri, 19 August 2011 08:59
No, they didn't get printed.
After taking the photograph, I cleaned one of the models with acetone and it turned out that there are no rivets at all.
Re: Finally! - SBB L6 [message #33004 is a reply to message #32940 ] Sat, 20 August 2011 18:27 UTC Go to previous messageGo to next message
After removing the wax with acetone and adding a thin layer of primer:
http://www.abload.de/img/edsc_0667tftr.jpg
http://www.abload.de/img/edsc_06306e9i.jpg
http://www.abload.de/img/edsc_06467e3z.jpg
http://www.abload.de/img/edsc_06571ekn.jpg
As you can see on the last picture, there are vertical lines which shouldn't be. The other model was printed correctly.
Re: Finally! - SBB L6 [message #33069 is a reply to message #33004 ] Mon, 22 August 2011 13:24 UTC Go to previous messageGo to next message
Hi JanitorMaster,
So sorry to hear this. I have already sent you a private message. If you please respond to this, I will make sure we will solve this issue for you Wink
Cheers, Ralph
Re: Finally! - SBB L6 [message #50636 is a reply to message #33069 ] Sat, 30 June 2012 01:07 UTC Go to previous messageGo to next message
avatar RolandR  is currently offline RolandR
http://i.imgur.com/03e8W.png
The project is still alive!
I have now modeled the lower part of the model
(I won't print the wheels! These are just for size reference).
Next is painting and then finding someone who can print the markings.
(New username as we can't log in using twitter anymore)
Edit: I guess this would rather belong in the WIP forum...
[Updated on: Sat, 30 June 2012 01:16 UTC]
Re: Finally! - SBB L6 [message #114396 is a reply to message #50636 ] Thu, 23 April 2015 14:32 UTC Go to previous messageGo to next message
It's been a long time since my last post!
I remade the entire model, improving some things.
Here's the latest, painted prototype:
http://rolandrytz.ch/share/img/l6_scaled.jpg
Unfortunately, there still are some problems with support material, as well as mild warping. However, this just seems to be the current quality of FUD.
Re: Finally! - SBB L6 [message #114401 is a reply to message #114396 ] Thu, 23 April 2015 15:42 UTC Go to previous messageGo to next message
avatar sbhunterca  is currently offline sbhunterca
Judging from the massive appearance of the N couplers, this is a very tiny model. Great work, retaining its fine appearance in N despite minimum allowable thicknesses. That's always a challenge.
Have you tried using a hair dryer, or hot water to allow straightening the slight warp? I had to do this with a hair dryer on a car once, I had missed noticing it until everything had been painted (acrylic). I was concerned it would damage the paint, but guessed the hair dryer's dry heat would be less risky than hot water. It worked great, with no damage to the finish.
This little guy might be a great candidate for printing in FXD!
Steve Hunter
Re: Finally! - SBB L6 [message #114402 is a reply to message #114401 ] Thu, 23 April 2015 15:51 UTC Go to previous messageGo to next message
sbhunterca wrote on Thu, 23 April 2015 15:42
Yeah, it is! It's about 5cm in length.
I've heard of the hot water method, I'll have to try it out. I still have some unpainted models.
Did the hair dryer treatment fix the warping permanently?
I already have one on order! ;-)
Re: Finally! - SBB L6 [message #114407 is a reply to message #114402 ] Thu, 23 April 2015 16:59 UTC Go to previous message
Whether you use air or water, you want the temp to get to 150F, then place it in / on / under something to hold it in place while it cools.
There should be no warping after that.
Your model printed in the printer with perfectly flat sides. It was during the cleaning process afterward that the warping occurred. It's "natural state" is flat...
Previous Topic:Ginko in Stainless steel
Next Topic:Doraemon
