| 15mm Gaming Miniatures in Colour Sandstone [message #32750] Mon, 15 August 2011 18:53 UTC |
I'm trying to create some small scale gaming miniatures, but I'm worried about scaling legs and such.
I'm already aware that the arms will have to be positioned to merge with the body, the ones shown here are representative only.
CS has a minimum wall thickness of 3mm, the Captain's legs only barely approach that thickness (at their thinnest). Will I have to arrange for some sort of pedestal under the figure to support it?
The base of the figure is a 15x15x3mm plinth.
Help and suggestions are what I'd like here, please.
| Re: 15mm Gaming Miniatures in Colour Sandstone [message #32754 is a reply to message #32750 ] Mon, 15 August 2011 20:08 UTC |
Have you done color prints before? Do you know the material?
I'm not sure whether it's suitable for gaming pieces. It is brittle even at more than 3mm and the pieces may not survive very long. 15mm is pretty tiny for that material.
Also, at Shapeways, they infuse the pieces with a strange yellowish wax. The surface remains pretty rough and catches scratches very easily, e.g. from your finger nails. These white scratches are not easy to remove.
Seems you might be better off with WSF, dyed in yellow and the eyes and mouth painted.
| Re: 15mm Gaming Miniatures in Colour Sandstone [message #32755 is a reply to message #32754 ] Mon, 15 August 2011 20:16 UTC |
I was beginning to suspect WSF would be a better idea, but I was attracted to CS for its affordability.
I'm getting some other figures printed in CS to see how they'll turn out, but otherwise, yeah, this is my first colour print.
| Re: 15mm Gaming Miniatures in Colour Sandstone [message #32780 is a reply to message #32755 ] Tue, 16 August 2011 06:38 UTC |
Your model is a prime candidate for hollowing. Follow the steps at
https://sites.google.com/site/3dprintfaq/workflows/hollowing -a-model
and the volume for WSF will go down by +-60% and price will be lower than color.
Make a tiny escape hole such that the inner material remains trapped in the model and makes it sturdy and a little heavier.
[Updated on: Tue, 16 August 2011 06:51 UTC]
| Re: 15mm Gaming Miniatures in Colour Sandstone [message #32789 is a reply to message #32780 ] Tue, 16 August 2011 08:28 UTC |
Thanks, I'm aware of the advantages of hollowing (from my other models) - I was more interested in experiences in how to use and consider CS as a material.
| Re: 15mm Gaming Miniatures in Colour Sandstone [message #32849 is a reply to message #32789 ] Wed, 17 August 2011 15:31 UTC |
pssst... when making holes for hollowing out model interiors, You actually want to make 2 holes (they can be close to each other, thats ok) so they can blast into one hole, and the excess material can blast out thru the other!
Thanks for listening,
-Lefty
www.shapeways.com/shops/lefty
