| Coloured sandstone resolution [message #31920] Mon, 01 August 2011 12:39 UTC |
Just a quick question for anyone with experience of the coloured sandstone, please.
If I print a small object in coloured sandstone, using white lettering on a black background, how small can I print the lettering before the resolution is lost, taking into account the surface texture of the sandstone itself? How small, before the lettering becomes unreadable?
I will print a test piece first, but I thought someone here might have prior experience of this. Many thanks.
| Re: Coloured sandstone resolution [message #31981 is a reply to message #31920 ] Tue, 02 August 2011 18:50 UTC |
First and very important, in the black vs white ("wheat yellow") battle, the black wins, so white letters over black will need thicker lines than black letters over white. A simple pattern of white and black lines, a 0.4 mm thickness starts to become a problem over a flat surface, and becomes mostly black at half that.
| Re: Coloured sandstone resolution [message #31982 is a reply to message #31920 ] Tue, 02 August 2011 18:54 UTC |
That's brilliant, thanks! Not what I wanted to hear, of course, but saves me printing something that evidently wouldn't have worked. Thanks again, cheers!
| Re: Coloured sandstone resolution [message #32026 is a reply to message #31920 ] Wed, 03 August 2011 18:08 UTC |
Try extruding the text upward to isolate the letters. That will make them stand out better. Raise them around 0.2 - 0.5mm, but don't let the height be more than 50% of the width of the feature. You can get clear letters about 6mm tall doing this.
