| Re: Roof tiles on HO Scale Building [message #31653 is a reply to message #31651 ] Wed, 27 July 2011 14:34 UTC |
Interesting, has anyone used anything like this? It seems to be just a shingle print with adhesive backing, but I'm wondering if that would be the best option?
| Re: Roof tiles on HO Scale Building [message #31654 is a reply to message #31653 ] Wed, 27 July 2011 15:50 UTC |
I just used the Rusty Stumps roofing shingles last weekend and love them. I've been using them for a while. I was actually going to suggest that you model the roof with no detail and instruct/let the buyer use their favorite roofing material.
Nice model and kudos for the blender usage!
Philip Light
| Re: Roof tiles on HO Scale Building [message #31657 is a reply to message #31654 ] Wed, 27 July 2011 17:02 UTC |
Excellent. Thanks so much for the suggestion!
I also noticed that some people were recommending a program called Netfabb to check for additional errors. I've used it and found several red areas, but it's still identifying some errors that I can't for the life of me find.
I don't suppose anyone would be able to take the attached .obj (exported from Blender) and help me find any errors? It takes days for me to find out from the Shapeways team that there's a problem that won't allow it to be printed, and this is to be a gift for my father on his birthday for his model railroad layout.
| Re: Roof tiles on HO Scale Building [message #31658 is a reply to message #31657 ] Wed, 27 July 2011 17:07 UTC |
Yeah, something is wrong. I'm attaching a screen grab from 3ds max when I import your obj. I didn't flip the xy direction, so ignore the object orientation.
If you post the blend file I'll look at it for you. or PM me if you want me to look at it w/ out posting it publicly.
Attachment: ooops.jpg
(Size: 391.49KB, Downloaded 59 time(s))
[Updated on: Wed, 27 July 2011 17:07 UTC]
Philip Light
| Re: Roof tiles on HO Scale Building [message #31662 is a reply to message #31659 ] Wed, 27 July 2011 17:31 UTC |
Hi Kepardue,
I just ran some checks on your .obj file using a combination of Accutrans3D and NetFabb Basic.
Using Accutrans at first, it reported 3 or more edges per vertice. Using NetFabb's analysis tool, it shows over 300 holes and more than 2000 flipped triangles. Using Netfabb to repair and export the model results in a manifold mesh, but with odd surfaces across windows.
I'm thinking, you need to go back and check the geometry of the window frames and make sure that they are all closed shells or that they are properly closed/merged with the walls of you (cool) model house.
Send me a PM if you need help getting things sorted.
| Re: Roof tiles on HO Scale Building [message #31667 is a reply to message #31665 ] Wed, 27 July 2011 18:54 UTC |
edited. I found that you can fix the stl directly from blender with netfabb.
Export to binary stl from blender.
Open the stl in netfabb studio.
Go to extras and choose repair part. On the right side, click automatic repair. Use default. On the right repair pane, choose apply repair.
Go to part>export>stl. use the default repair on export.
[Updated on: Wed, 27 July 2011 19:19 UTC]
Philip Light
