What glue to use for WSF to s/steel? [message #30460] Fri, 08 July 2011 11:59 UTC |
Has anyone had any experience gluing WSF (or any other acrylic/plastic) to stainless steel?
Just wondering what would be the best to use for a really strong bond (jewellery use).
Glenn
| Re: What glue to use for WSF to s/steel? [message #30648 is a reply to message #30460 ] Mon, 11 July 2011 20:42 UTC |
Have a hunt for 'Devcon' and 'jewelry' (UK = jewellery), I've seen some of Devcon's clear epoxies are useful for jewellery making - you'd need to scuff up any smooth surfaces for the epoxy to grab to.
| Re: What glue to use for WSF to s/steel? [message #30655 is a reply to message #30649 ] Mon, 11 July 2011 22:10 UTC |
I have never found 2 materials that wouldn't bond well with E-6000.
Make sure you use it in a well ventilation room.
The toxic fumes are how you know it is working.
Seriously though, any hobby store should have it, and it is STRONG!
Lincoln
[Updated on: Mon, 11 July 2011 22:10 UTC] For special discounts and news add us on Facebook: https://www.facebook.com/Craftosterone
www.Craftosterone.com
| Re: What glue to use for WSF to s/steel? [message #30661 is a reply to message #30460 ] Tue, 12 July 2011 01:09 UTC |
Thanks. I was on a jewellery (jewelry!) forum recently and that was mentioned also as a very good choice.
Glenn
| Re: What glue to use for WSF to s/steel? [message #30854 is a reply to message #30661 ] Thu, 14 July 2011 14:55 UTC |
My usual 'go to' resource for questions like this is http://www.thistothat.com/.
They recomend using an epoxy, which I would agree with. The porus nature of WSF will allow the epoxy to 'soak in' to the WSF and get a good solid hold.
Normally I'm a huge fan of E-6000, but I've found that on smooth, hard surfaces it can peel off if subjected to sideways force.
So if your S/Steel surface is nice and smooth I'd use an epoxy, but if it's rough enough to allow E-6000 to get a good grip that may be your better bet.
