| K6 Telephone Box - OO (1:76, 4mm) Scale [message #29406] Tue, 21 June 2011 12:27 UTC |
All seven parts laid out - there's seven parts to make painting easier - note the tabs on the sidewalls, these fit into corresponding gaps in the floor and roof.
Large image here
Dry fit - everything fits together quite nicely, and the sides are straight after a soak in some hot water then laid on a flat surface.
Large image here
Detail - The door handle has come out real good considering how small it is.
Large image here
More photos over the next few days when the model is painted and assembled.
My K8 phone box also arrived with the K6, but unfortunately there was a part missing
| Re: K6 Telephone Box - OO (1:76, 4mm) Scale [message #29439 is a reply to message #29432 ] Wed, 22 June 2011 01:41 UTC |
Yes, well done. It is amazing how small it is yet it looks perfect. Is this printed in Ultra detail material?
http://www.shapeways.com/shops/most
| Re: K6 Telephone Box - OO (1:76, 4mm) Scale [message #29463 is a reply to message #29439 ] Wed, 22 June 2011 08:54 UTC |
Thanks ana & MoST.
Yes, the model is in FUD, the material is probably just about perfect for 1:76 scale modelling.
@ana, with FUD, I've found that if model parts fit together on the screen, they'll fit together once printed.
I also modelled the 1926 K2 phone box which is in the process of being painted (the inside is nearly finished).
[Updated on: Wed, 22 June 2011 08:55 UTC]
| Re: K6 Telephone Box - OO (1:76, 4mm) Scale [message #29558 is a reply to message #29463 ] Thu, 23 June 2011 18:58 UTC |
@Paul, if you're able to get a pic up of the phone booth assembled against a black background I'd love to feature it in Friday Finds tomorrow
Community Manager | Shapeways
| Re: K6 Telephone Box - OO (1:76, 4mm) Scale [message #29561 is a reply to message #29558 ] Thu, 23 June 2011 19:08 UTC |
I already started the painting process, but I can do an assembled model coated with with grey primer if that's ok?
| Re: K6 Telephone Box - OO (1:76, 4mm) Scale [message #29562 is a reply to message #29561 ] Thu, 23 June 2011 19:12 UTC |
That's fine. it'd be great to send the model some love, but I don't want to cause a lot of hassle for you in the process. If it's doable, go for it!
| Re: K6 Telephone Box - OO (1:76, 4mm) Scale [message #29975 is a reply to message #29568 ] Thu, 30 June 2011 17:38 UTC |
Now you just need the model of Superman jumping out of the booth in his tights ready to go!
If that is mm on the ruler then it is 35mm top to bottom?
| Re: K6 Telephone Box - OO (1:76, 4mm) Scale [message #29980 is a reply to message #29975 ] Thu, 30 June 2011 18:05 UTC |
Yep, that's mm on the ruler, all in all, the model is a tad under 35mm tall.
The painting side of things is going slow though.
