basic model component ok?
basic model component ok? [message #29304] Sun, 19 June 2011 04:28 UTC Go to next message
avatar barborak  is currently offline barborak
I'm just hoping someone with experience using Shapeways could let me know if the attached Sketchup model seems fine? I'm just wondering if the concept is fine before spending too much time pursuing this model. I'm wondering if it's printable and also if the cubes are 1" on a side and the connector is 1/12" thick if it will be at all durable printed in white plastic.
Here's a screenshot which may be all you need to judge the model. Basically it's 2 cubes with sockets held together by a rod with balls at each end.
http://barborak.com/apps/model.png
Mike
  • Attachment: arch.skp
    (Size: 294.45KB, Downloaded 70 time(s))
Re: basic model component ok? [message #29332 is a reply to message #29304 ] Mon, 20 June 2011 04:04 UTC Go to previous messageGo to next message
The connecting post seems a little thin for the mass of the cubes...it might work but I'd make it bigger diameter if possible. I'd also be concerned about getting the support material out from inside the socket joints at only ~0.5mm clearance.
One last thing, it would be best to reverse the faces on the connecting rod so they are white like the cubes.
Hope that helps!
[Updated on: Mon, 20 June 2011 04:05 UTC]
Re: basic model component ok? [message #29354 is a reply to message #29332 ] Mon, 20 June 2011 14:07 UTC Go to previous messageGo to next message
Thanks, I'll rework the model to make the posts thicker. And I'll make sure my face normals are pointed in the right direction. And I'll make the clearance in the socket joints wider. Any intuition about how wide it should be or is the concern more about the geometry?
And your mention of cleaning out the support material was a real revelation. I'll admit that I had been scratching my head wondering how this was going to be printed and now it's been made clear - it's printed with a construction material and a support material. Duh. So then when I get the printed model it's up to me to remove the support material. Obviously I haven't found the right documentation for this task. Is there something I should read with pointers and caveats about building models and removing the support material?
Mike
Re: basic model component ok? [message #29362 is a reply to message #29354 ] Mon, 20 June 2011 18:21 UTC Go to previous messageGo to next message
For WSF, the support material is the same as the construction material, it just remains as powder, but you still have to get it out. In your design, you only have tiny bit of room for the powder to escape. Have you seen the tutorial section? Specifically these ones:
http://www.shapeways.com/tutorials/designing_mechanical_part s_for_3d_printing
http://www.shapeways.com/tutorials/designing_mechanical_part s_3d_printing_the_whoosh There are lots of good tips in the forum as well, perhaps search for "hinges" to hone in on relevant posts.
Re: basic model component ok? [message #29363 is a reply to message #29362 ] Mon, 20 June 2011 18:29 UTC Go to previous messageGo to next message
I have seen it now. Thanks so much for the guidance.
Re: basic model component ok? [message #29364 is a reply to message #29363 ] Mon, 20 June 2011 18:34 UTC Go to previous messageGo to next message
No problem, I hope you'll share your experience with us when you do order the part Smile
Re: basic model component ok? [message #30878 is a reply to message #29364 ] Fri, 15 July 2011 00:35 UTC Go to previous messageGo to next message
I completed a small experiment and uploaded it here:
http://www.shapeways.com/model/294913/
First, I created the model in Sketchup8. I created it in Sketchup using centimeters as my unit measure. In Sketchup, the cube edges are 25 centimeters long. In Shapeways, I'm hoping to print these as 25 millimeters long.
Then I exported the model as a Collada DAE file. I imported into MeshLab from which I exported as STL. I did this so I could check for water tightness in AccuTrans 3D.
Everything checked out so I uploaded the model you see above and set the units of the uploaded model to millimeters.
So I'm having two problems. First, all the letter i's and the one dash in the text were removed. These are all visible in the 3 programs I mentioned above.
Second, the size of the model is shown as height 1.0cm x width 3.1 cm x depth 2.4cm. It should be height 6.0cm x width 7.8cm x depth 2.5cm. The scale factor of about 2.5 seems to be suspiciously close to the ratio of centimeters to inches.
Any ideas as to what might have gone wrong? Or other things I should try?
Mike
Re: basic model component ok? [message #30879 is a reply to message #30878 ] Fri, 15 July 2011 01:03 UTC Go to previous message
Never mind - I scaled it to the proper size in Sketchup, exported as a DAE file, uploaded that and it fixed all the issues.
[Updated on: Fri, 15 July 2011 01:14 UTC]
Previous Topic:Prime Dice
Next Topic:watch making blog
