Home » Support » Bug Reporting » Gallery 3D Viewer
icon4.gif  Gallery 3D Viewer [message #2902] Mon, 09 February 2009 11:27 UTC Go to next message
avatar minisumo  is currently offline minisumo
At home (on Vista Personal) via Crome and Explorer I seem to have a problem with the 3D viewer. It appears to start loading the applet, it asks for a conformation on certificates, there's a flash of a message box then nothing.
Work with Explorer on XP, I see a spinning model...
Does any one know of any Java or Applet version problem on Vista?
Many thanks,
Colin
Re: Gallery 3D Viewer [message #2934 is a reply to message #2902 ] Tue, 10 February 2009 20:41 UTC Go to previous messageGo to next message
We test the code daily with Vista, both IE and Firefox, but not with Chrome or Opera. Macs we use Firefox and Safari, while linux with just Firefox. Our daily development machines are all Vista, so we'd be pretty quick to know if there was a problem with it. If you are able to, can you locate and post the java console messages that are being written out. That may give us a clue as to what is going on.
Re: Gallery 3D Viewer [message #2936 is a reply to message #2934 ] Tue, 10 February 2009 23:31 UTC Go to previous messageGo to next message
avatar loonsbury  is currently offline loonsbury
There are some unimpressive problems with Java in Chrome, so it may not be surmountable until they've fixed it. For too long after the first release, Java would not load at all under any circumstances.
Chrome uses the windows Safari renderer; if you're able to test Safari in Vista, it may help pin down the problem.
Re: Gallery 3D Viewer [message #2959 is a reply to message #2934 ] Thu, 12 February 2009 09:27 UTC Go to previous messageGo to next message
WetMorgoth wrote on Tue, 10 February 2009 20:41
Is this something that will be logged for a user by default, or how would I turn the log on? What's its likely name and location?
I'm happy to help where I can.
Best regards,
Colin
Re: Gallery 3D Viewer [message #2972 is a reply to message #2959 ] Fri, 13 February 2009 21:15 UTC Go to previous messageGo to next message
Hi Colin,
Normally you would have a java icon in your taskbar. If you right click on it you can select the java console.
Best regards,
Robert
Re: Gallery 3D Viewer [message #2974 is a reply to message #2972 ] Sat, 14 February 2009 16:34 UTC Go to previous messageGo to next message
Thanks, found it.
Trouble is I'm just getting the console open when it disappears Shocked
Re: Gallery 3D Viewer [message #2977 is a reply to message #2974 ] Sat, 14 February 2009 23:01 UTC Go to previous messageGo to next message
Ok. That is a challenge. Smile
Another option is to go to Control Panel and select Java. There you can enable the console to appear on startup. That will help.
Best regards,
Robert
Re: Gallery 3D Viewer [message #2990 is a reply to message #2902 ] Sun, 15 February 2009 21:32 UTC Go to previous messageGo to next message
Great, got it. Enabled the log, do you need the trace too?
<?xml version="1.0" encoding="windows-1252" standalone="no"?>
<!DOCTYPE log SYSTEM "logger.dtd">
<log>
<record>
  <date>2009-02-15T19:17:34</date>
  <millis>1234725454689</millis>
  <sequence>0</sequence>
  <logger>sun.plugin</logger>
  <level>FINE</level>
  <class>com.sun.deploy.util.LoggerTraceListener</class>
  <method>print</method>
  <thread>10</thread>
  <message>JNLPAppletLauncher: static initializer
</message>
</record>
<record>
  <millis>1234725454690</millis>
  <sequence>1</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>os.name = windows vista
</message>
</record>
<record>
  <sequence>2</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>nativePrefix =   nativeSuffix = .dll
</message>
</record>
<record>
  <millis>1234725454691</millis>
  <sequence>3</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>tmpRootDir = C:\Users\Colin\AppData\Local\Temp\jnlp-applet\jln25845
</message>
</record>
<record>
  <sequence>4</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>Applet.init
</message>
</record>
<record>
  <sequence>5</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>subapplet.classname = udesign.UDesignApplet
</message>
</record>
<record>
  <sequence>6</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>subapplet.displayname = Shapeways Viewer Applet
</message>
</record>
<record>
  <sequence>7</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>subapplet.image = http://www.shapeways.com/modules/udesign/utils/openfile.php?id=17085&amp;f=17085_applet.jpg
</message>
</record>
<record>
  <millis>1234725454745</millis>
  <sequence>8</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>Applet.start
</message>
</record>
<record>
  <date>2009-02-15T19:17:37</date>
  <millis>1234725457237</millis>
  <sequence>9</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234725457241</millis>
  <sequence>10</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>os.arch = x86
</message>
</record>
<record>
  <millis>1234725457975</millis>
  <sequence>11</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>processNativeJar: using previously cached: C:\Users\Colin\.jnlp-applet\cache\www_shapeways_com\a4e0ac5cd925c1bc48013ed68401901b8feae8fd\jogl-natives-windows-i586.jar
</message>
</record>
<record>
  <millis>1234725457993</millis>
  <sequence>12</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>validateCertificates:
</message>
</record>
<record>
  <millis>1234725457994</millis>
  <sequence>13</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>VALIDATE: jogl.dll
</message>
</record>
<record>
  <date>2009-02-15T19:17:38</date>
  <millis>1234725458049</millis>
  <sequence>14</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>VALIDATE: jogl_awt.dll
</message>
</record>
<record>
  <millis>1234725458050</millis>
  <sequence>15</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>VALIDATE: jogl_cg.dll
</message>
</record>
<record>
  <millis>1234725458054</millis>
  <sequence>16</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>extractNativeLibs:
</message>
</record>
<record>
  <sequence>17</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>EXTRACT: jogl.dll(jogl)
</message>
</record>
<record>
  <millis>1234725458060</millis>
  <sequence>18</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>EXTRACT: jogl_awt.dll(jogl_awt)
</message>
</record>
<record>
  <millis>1234725458063</millis>
  <sequence>19</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>EXTRACT: jogl_cg.dll(jogl_cg)
</message>
</record>
<record>
  <millis>1234725458375</millis>
  <sequence>20</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>processNativeJar: using previously cached: C:\Users\Colin\.jnlp-applet\cache\www_shapeways_com\a4e0ac5cd925c1bc48013ed68401901b8feae8fd\gluegen-rt-natives-windows-i586.jar
</message>
</record>
<record>
  <millis>1234725458426</millis>
  <sequence>21</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>22</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>VALIDATE: gluegen-rt.dll
</message>
</record>
<record>
  <millis>1234725458430</millis>
  <sequence>23</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>24</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>EXTRACT: gluegen-rt.dll(gluegen-rt)
</message>
</record>
<record>
  <date>2009-02-15T19:17:50</date>
  <millis>1234725470384</millis>
  <sequence>25</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>Message: VERSION: 1.2.4
</message>
</record>
<record>
  <date>2009-02-15T19:17:51</date>
  <millis>1234725471081</millis>
  <sequence>26</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>******** Creating mesh editor *
</message>
</record>
<record>
  <millis>1234725471191</millis>
  <sequence>27</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>JNLPAppletLauncher.loadLibrary("jogl")
</message>
</record>
<record>
  <sequence>28</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>    loading: C:\Users\Colin\AppData\Local\Temp\jnlp-applet\jln25845\jln25846\jogl.dll
</message>
</record>
<record>
  <date>2009-02-15T19:17:52</date>
  <millis>1234725472124</millis>
  <sequence>29</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>The selected editor is udesign.editor.mesh.MeshEditor[,0,0,0x0,invalid,layout=java.awt.BorderLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=9,maximumSize=,minimumSize=,preferredSize=]
</message>
</record>
<record>
  <millis>1234725472189</millis>
  <sequence>30</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>JNLPAppletLauncher.loadLibrary("jogl_awt")
</message>
</record>
<record>
  <millis>1234725472190</millis>
  <sequence>31</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>    loading: C:\Users\Colin\AppData\Local\Temp\jnlp-applet\jln25845\jln25846\jogl_awt.dll
</message>
</record>
<record>
  <millis>1234725472566</millis>
  <sequence>32</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>OpenGL details:
</message>
</record>
<record>
  <millis>1234725472567</millis>
  <sequence>33</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>Card vendor: ati technologies inc.
</message>
</record>
<record>
  <sequence>34</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>Spec Version: 2.0.6479 Release
</message>
</record>
<record>
  <sequence>35</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>Renderer: ATI Radeon Xpress 1250
</message>
</record>
<record>
  <sequence>36</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>High-resolution shaders enabled
</message>
</record>
Re: Gallery 3D Viewer [message #3001 is a reply to message #2990 ] Mon, 16 February 2009 21:46 UTC Go to previous messageGo to next message
Hi Minisumo,
Thanks for our patience! This is really helpful!
Yes, we need the trace log also.
Best regards,
Robert
Re: Gallery 3D Viewer [message #3010 is a reply to message #2902 ] Tue, 17 February 2009 18:28 UTC Go to previous messageGo to next message
Another try Smile
regards,
colin
Log File:
<log>
<record>
  <date>2009-02-17T18:13:46</date>
  <millis>1234894426996</millis>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: property package.access value sun.
</message>
</record>
<record>
  <millis>1234894426997</millis>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: property package.access new value sun.,com.sun.javaws
</message>
</record>
<record>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: property package.access value sun.,com.sun.javaws
</message>
</record>
<record>
  <millis>1234894426998</millis>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: property package.access new value sun.,com.sun.javaws,com.sun.deploy
</message>
</record>
<record>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: property package.definition value null
</message>
</record>
<record>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: property package.definition new value com.sun.javaws
</message>
</record>
<record>
  <millis>1234894426999</millis>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: property package.definition value com.sun.javaws
</message>
</record>
<record>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: property package.definition new value com.sun.javaws,com.sun.deploy
</message>
</record>
<record>
  <date>2009-02-17T18:13:47</date>
  <millis>1234894427000</millis>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: property package.definition value com.sun.javaws,com.sun.deploy
</message>
</record>
<record>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: property package.definition new value com.sun.javaws,com.sun.deploy,com.sun.jnlp
</message>
</record>
<record>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: property package.access value sun.,com.sun.javaws,com.sun.deploy
</message>
</record>
<record>
  <millis>1234894427001</millis>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: property package.access new value sun.,com.sun.javaws,com.sun.deploy,org.mozilla.jss
</message>
</record>
<record>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: property package.definition value com.sun.javaws,com.sun.deploy,com.sun.jnlp
</message>
</record>
<record>
  <millis>1234894427002</millis>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: property package.definition new value com.sun.javaws,com.sun.deploy,com.sun.jnlp,org.mozilla.jss
</message>
</record>
<record>
  <level>FINE</level>
  <thread>10</thread>
  <message>basic: Added progress listener: sun.plugin.util.GrayBoxPainter$GrayBoxProgressListener@276af2
</message>
</record>
<record>
  <millis>1234894427003</millis>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Cache entry found [url: http://download.java.net/media/applet-launcher/applet-launcher.jar, version: null]
</message>
</record>
<record>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://download.java.net/media/applet-launcher/applet-launcher.jar with proxy=DIRECT
</message>
</record>
<record>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://download.java.net:80/ with proxy=DIRECT
</message>
</record>
<record>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: ResponseCode for http://download.java.net/media/applet-launcher/applet-launcher.jar : 304
</message>
</record>
<record>
  <millis>1234894427004</millis>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Encoding for http://download.java.net/media/applet-launcher/applet-launcher.jar : null
</message>
</record>
<record>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Disconnect connection to http://download.java.net/media/applet-launcher/applet-launcher.jar
</message>
</record>
<record>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: Accessing keys and certificate in Mozilla user profile: null
</message>
</record>
<record>
  <millis>1234894427005</millis>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: Loading Root CA certificates from C:\Program Files\Java\jre6\lib\security\cacerts
</message>
</record>
<record>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: Loaded Root CA certificates from C:\Program Files\Java\jre6\lib\security\cacerts
</message>
</record>
<record>
  <millis>1234894427006</millis>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: Loading Deployment certificates from C:\Users\Colin\AppData\LocalLow\Sun\Java\Deployment\security\trusted.certs
</message>
</record>
<record>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: Loaded Deployment certificates from C:\Users\Colin\AppData\LocalLow\Sun\Java\Deployment\security\trusted.certs
</message>
</record>
<record>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: Loading certificates from Deployment session certificate store
</message>
</record>
<record>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: Loaded certificates from Deployment session certificate store
</message>
</record>
<record>
  <millis>1234894427008</millis>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: Validate the certificate chain using CertPath API
</message>
</record>
<record>
  <millis>1234894427009</millis>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: Obtain certificate collection in Root CA certificate store
</message>
</record>
<record>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: The CRL support is disabled
</message>
</record>
<record>
  <millis>1234894427010</millis>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: The OCSP support is disabled
</message>
</record>
<record>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: No timestamping info available
</message>
</record>
<record>
  <millis>1234894427011</millis>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: Checking if certificate is in Deployment denied certificate store
</message>
</record>
<record>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: Checking if certificate is in Deployment permanent certificate store
</message>
</record>
<record>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894427012</millis>
  <sequence>37</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>38</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894427013</millis>
  <sequence>39</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>tmpRootDir = C:\Users\Colin\AppData\Local\Temp\jnlp-applet\jln54101
</message>
</record>
<record>
  <sequence>40</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>basic: Applet loaded.
</message>
</record>
<record>
  <sequence>41</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>basic: Applet resized and added to parent container
</message>
</record>
<record>
  <millis>1234894427014</millis>
  <sequence>42</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>basic: PERF: AppletExecutionRunnable - applet.init() BEGIN ; jvmLaunch dt 1035960 us, pluginInit dt 1513314 us, TotalTime: 2549274 us
</message>
</record>
<record>
  <sequence>43</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894427015</millis>
  <sequence>44</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>45</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>46</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>47</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Cache entry not found [url: http://www.shapeways.com/modules/udesign/utils/openfile.php?id=17085&amp;f=17085_applet.jpg, version: null]
</message>
</record>
<record>
  <millis>1234894427016</millis>
  <sequence>48</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://www.shapeways.com/modules/udesign/utils/openfile.php?id=17085&amp;f=17085_applet.jpg with proxy=DIRECT
</message>
</record>
<record>
  <sequence>49</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://www.shapeways.com:80/ with proxy=DIRECT
</message>
</record>
<record>
  <sequence>50</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://www.shapeways.com/modules/udesign/utils/openfile.php?id=17085&amp;f=17085_applet.jpg with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
</message>
</record>
<record>
  <millis>1234894427017</millis>
  <sequence>51</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>basic: Applet initialized
</message>
</record>
<record>
  <sequence>52</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>basic: Removed progress listener: sun.plugin.util.GrayBoxPainter$GrayBoxProgressListener@276af2
</message>
</record>
<record>
  <sequence>53</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>basic: Applet made visible
</message>
</record>
<record>
  <millis>1234894427018</millis>
  <sequence>54</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>basic: Starting applet
</message>
</record>
<record>
  <sequence>55</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>56</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>basic: Applet started
</message>
</record>
<record>
  <millis>1234894427019</millis>
  <sequence>57</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>basic: Told clients applet is started
</message>
</record>
<record>
  <sequence>58</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Cache entry found [url: http://download.java.net/media/jogl/builds/archive/jsr-231-webstart-current/jogl.jar, version: null]
</message>
</record>
<record>
  <sequence>59</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://download.java.net/media/jogl/builds/archive/jsr-231-webstart-current/jogl.jar with proxy=DIRECT
</message>
</record>
<record>
  <millis>1234894427179</millis>
  <sequence>60</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: ResponseCode for http://download.java.net/media/jogl/builds/archive/jsr-231-webstart-current/jogl.jar : 304
</message>
</record>
<record>
  <millis>1234894427180</millis>
  <sequence>61</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Encoding for http://download.java.net/media/jogl/builds/archive/jsr-231-webstart-current/jogl.jar : null
</message>
</record>
<record>
  <sequence>62</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Disconnect connection to http://download.java.net/media/jogl/builds/archive/jsr-231-webstart-current/jogl.jar
</message>
</record>
<record>
  <millis>1234894427243</millis>
  <sequence>63</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Cache entry found [url: http://download.java.net/media/gluegen/webstart/gluegen-rt.jar, version: null]
</message>
</record>
<record>
  <millis>1234894427250</millis>
  <sequence>64</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://download.java.net/media/gluegen/webstart/gluegen-rt.jar with proxy=DIRECT
</message>
</record>
<record>
  <millis>1234894427452</millis>
  <sequence>65</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: ResponseCode for http://download.java.net/media/gluegen/webstart/gluegen-rt.jar : 304
</message>
</record>
<record>
  <sequence>66</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Encoding for http://download.java.net/media/gluegen/webstart/gluegen-rt.jar : null
</message>
</record>
<record>
  <sequence>67</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Disconnect connection to http://download.java.net/media/gluegen/webstart/gluegen-rt.jar
</message>
</record>
<record>
  <millis>1234894427528</millis>
  <sequence>68</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Cache entry found [url: http://www.shapeways.com/modules/udesign/ext/client/lib/udesign_applet_1.2.4.jar, version: null]
</message>
</record>
<record>
  <millis>1234894427533</millis>
  <sequence>69</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://www.shapeways.com/modules/udesign/ext/client/lib/udesign_applet_1.2.4.jar with proxy=DIRECT
</message>
</record>
<record>
  <millis>1234894427540</millis>
  <sequence>70</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://www.shapeways.com/modules/udesign/ext/client/lib/udesign_applet_1.2.4.jar with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
</message>
</record>
<record>
  <millis>1234894427597</millis>
  <sequence>71</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: ResponseCode for http://www.shapeways.com/modules/udesign/ext/client/lib/udesign_applet_1.2.4.jar : 304
</message>
</record>
<record>
  <millis>1234894427598</millis>
  <sequence>72</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Encoding for http://www.shapeways.com/modules/udesign/ext/client/lib/udesign_applet_1.2.4.jar : null
</message>
</record>
<record>
  <sequence>73</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Disconnect connection to http://www.shapeways.com/modules/udesign/ext/client/lib/udesign_applet_1.2.4.jar
</message>
</record>
<record>
  <millis>1234894427686</millis>
  <sequence>74</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Cache entry found [url: http://www.shapeways.com/modules/udesign/ext/client/lib/chefx3d_core_2.0.0.jar, version: null]
</message>
</record>
<record>
  <millis>1234894427693</millis>
  <sequence>75</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://www.shapeways.com/modules/udesign/ext/client/lib/chefx3d_core_2.0.0.jar with proxy=DIRECT
</message>
</record>
<record>
  <millis>1234894427695</millis>
  <sequence>76</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://www.shapeways.com/modules/udesign/ext/client/lib/chefx3d_core_2.0.0.jar with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
</message>
</record>
<record>
  <millis>1234894427751</millis>
  <sequence>77</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: ResponseCode for http://www.shapeways.com/modules/udesign/ext/client/lib/chefx3d_core_2.0.0.jar : 304
</message>
</record>
<record>
  <millis>1234894427752</millis>
  <sequence>78</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Encoding for http://www.shapeways.com/modules/udesign/ext/client/lib/chefx3d_core_2.0.0.jar : null
</message>
</record>
<record>
  <sequence>79</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Disconnect connection to http://www.shapeways.com/modules/udesign/ext/client/lib/chefx3d_core_2.0.0.jar
</message>
</record>
<record>
  <millis>1234894427901</millis>
  <sequence>80</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Cache entry found [url: http://www.shapeways.com/modules/udesign/ext/client/lib/xj3d-interchange-loader-av3d_2.0.0.jar, version: null]
</message>
</record>
<record>
  <millis>1234894427910</millis>
  <sequence>81</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://www.shapeways.com/modules/udesign/ext/client/lib/xj3d-interchange-loader-av3d_2.0.0.jar with proxy=DIRECT
</message>
</record>
<record>
  <millis>1234894427912</millis>
  <sequence>82</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://www.shapeways.com/modules/udesign/ext/client/lib/xj3d-interchange-loader-av3d_2.0.0.jar with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
</message>
</record>
<record>
  <millis>1234894427969</millis>
  <sequence>83</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: ResponseCode for http://www.shapeways.com/modules/udesign/ext/client/lib/xj3d-interchange-loader-av3d_2.0.0.jar : 304
</message>
</record>
<record>
  <sequence>84</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Encoding for http://www.shapeways.com/modules/udesign/ext/client/lib/xj3d-interchange-loader-av3d_2.0.0.jar : null
</message>
</record>
<record>
  <sequence>85</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Disconnect connection to http://www.shapeways.com/modules/udesign/ext/client/lib/xj3d-interchange-loader-av3d_2.0.0.jar
</message>
</record>
<record>
  <date>2009-02-17T18:13:48</date>
  <millis>1234894428123</millis>
  <sequence>86</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Cache entry found [url: http://www.shapeways.com/modules/udesign/ext/client/lib/fastinfoset_1.2.2.jar, version: null]
</message>
</record>
<record>
  <millis>1234894428131</millis>
  <sequence>87</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://www.shapeways.com/modules/udesign/ext/client/lib/fastinfoset_1.2.2.jar with proxy=DIRECT
</message>
</record>
<record>
  <millis>1234894428133</millis>
  <sequence>88</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://www.shapeways.com/modules/udesign/ext/client/lib/fastinfoset_1.2.2.jar with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
</message>
</record>
<record>
  <millis>1234894428189</millis>
  <sequence>89</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: ResponseCode for http://www.shapeways.com/modules/udesign/ext/client/lib/fastinfoset_1.2.2.jar : 304
</message>
</record>
<record>
  <millis>1234894428190</millis>
  <sequence>90</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Encoding for http://www.shapeways.com/modules/udesign/ext/client/lib/fastinfoset_1.2.2.jar : null
</message>
</record>
<record>
  <sequence>91</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Disconnect connection to http://www.shapeways.com/modules/udesign/ext/client/lib/fastinfoset_1.2.2.jar
</message>
</record>
<record>
  <millis>1234894428265</millis>
  <sequence>92</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Cache entry found [url: http://www.shapeways.com/modules/udesign/ext/client/lib/aviatrix3d-all_2.0.0.jar, version: null]
</message>
</record>
<record>
  <millis>1234894428273</millis>
  <sequence>93</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://www.shapeways.com/modules/udesign/ext/client/lib/aviatrix3d-all_2.0.0.jar with proxy=DIRECT
</message>
</record>
<record>
  <millis>1234894428281</millis>
  <sequence>94</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894428321</millis>
  <sequence>95</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://www.shapeways.com/modules/udesign/ext/client/lib/aviatrix3d-all_2.0.0.jar with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
</message>
</record>
<record>
  <millis>1234894428378</millis>
  <sequence>96</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: ResponseCode for http://www.shapeways.com/modules/udesign/ext/client/lib/aviatrix3d-all_2.0.0.jar : 304
</message>
</record>
<record>
  <millis>1234894428390</millis>
  <sequence>97</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Encoding for http://www.shapeways.com/modules/udesign/ext/client/lib/aviatrix3d-all_2.0.0.jar : null
</message>
</record>
<record>
  <sequence>98</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Disconnect connection to http://www.shapeways.com/modules/udesign/ext/client/lib/aviatrix3d-all_2.0.0.jar
</message>
</record>
<record>
  <millis>1234894428488</millis>
  <sequence>99</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Cache entry found [url: http://www.shapeways.com/modules/udesign/ext/client/lib/gnu-regexp-1.0.8.jar, version: null]
</message>
</record>
<record>
  <millis>1234894428500</millis>
  <sequence>100</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://www.shapeways.com/modules/udesign/ext/client/lib/gnu-regexp-1.0.8.jar with proxy=DIRECT
</message>
</record>
<record>
  <millis>1234894428502</millis>
  <sequence>101</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://www.shapeways.com/modules/udesign/ext/client/lib/gnu-regexp-1.0.8.jar with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
</message>
</record>
<record>
  <millis>1234894428559</millis>
  <sequence>102</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: ResponseCode for http://www.shapeways.com/modules/udesign/ext/client/lib/gnu-regexp-1.0.8.jar : 304
</message>
</record>
<record>
  <millis>1234894428560</millis>
  <sequence>103</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Encoding for http://www.shapeways.com/modules/udesign/ext/client/lib/gnu-regexp-1.0.8.jar : null
</message>
</record>
<record>
  <millis>1234894428561</millis>
  <sequence>104</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Disconnect connection to http://www.shapeways.com/modules/udesign/ext/client/lib/gnu-regexp-1.0.8.jar
</message>
</record>
<record>
  <millis>1234894428635</millis>
  <sequence>105</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Cache entry found [url: http://www.shapeways.com/modules/udesign/ext/client/lib/j3d-org-all_0.9.0.jar, version: null]
</message>
</record>
<record>
  <millis>1234894428642</millis>
  <sequence>106</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://www.shapeways.com/modules/udesign/ext/client/lib/j3d-org-all_0.9.0.jar with proxy=DIRECT
</message>
</record>
<record>
  <millis>1234894428644</millis>
  <sequence>107</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://www.shapeways.com/modules/udesign/ext/client/lib/j3d-org-all_0.9.0.jar with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
</message>
</record>
<record>
  <millis>1234894428701</millis>
  <sequence>108</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: ResponseCode for http://www.shapeways.com/modules/udesign/ext/client/lib/j3d-org-all_0.9.0.jar : 304
</message>
</record>
<record>
  <sequence>109</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Encoding for http://www.shapeways.com/modules/udesign/ext/client/lib/j3d-org-all_0.9.0.jar : null
</message>
</record>
<record>
  <sequence>110</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Disconnect connection to http://www.shapeways.com/modules/udesign/ext/client/lib/j3d-org-all_0.9.0.jar
</message>
</record>
<record>
  <millis>1234894428765</millis>
  <sequence>111</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Cache entry found [url: http://www.shapeways.com/modules/udesign/ext/client/lib/jutils.jar, version: null]
</message>
</record>
<record>
  <millis>1234894428773</millis>
  <sequence>112</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://www.shapeways.com/modules/udesign/ext/client/lib/jutils.jar with proxy=DIRECT
</message>
</record>
<record>
  <millis>1234894428774</millis>
  <sequence>113</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://www.shapeways.com/modules/udesign/ext/client/lib/jutils.jar with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
</message>
</record>
<record>
  <millis>1234894428830</millis>
  <sequence>114</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: ResponseCode for http://www.shapeways.com/modules/udesign/ext/client/lib/jutils.jar : 304
</message>
</record>
<record>
  <sequence>115</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Encoding for http://www.shapeways.com/modules/udesign/ext/client/lib/jutils.jar : null
</message>
</record>
<record>
  <millis>1234894428831</millis>
  <sequence>116</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Disconnect connection to http://www.shapeways.com/modules/udesign/ext/client/lib/jutils.jar
</message>
</record>
<record>
  <millis>1234894428883</millis>
  <sequence>117</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Cache entry found [url: http://www.shapeways.com/modules/udesign/ext/client/lib/uri.jar, version: null]
</message>
</record>
<record>
  <millis>1234894428892</millis>
  <sequence>118</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://www.shapeways.com/modules/udesign/ext/client/lib/uri.jar with proxy=DIRECT
</message>
</record>
<record>
  <millis>1234894428894</millis>
  <sequence>119</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://www.shapeways.com/modules/udesign/ext/client/lib/uri.jar with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
</message>
</record>
<record>
  <millis>1234894428951</millis>
  <sequence>120</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: ResponseCode for http://www.shapeways.com/modules/udesign/ext/client/lib/uri.jar : 304
</message>
</record>
<record>
  <millis>1234894428952</millis>
  <sequence>121</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Encoding for http://www.shapeways.com/modules/udesign/ext/client/lib/uri.jar : null
</message>
</record>
<record>
  <sequence>122</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Disconnect connection to http://www.shapeways.com/modules/udesign/ext/client/lib/uri.jar
</message>
</record>
<record>
  <millis>1234894428996</millis>
  <sequence>123</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Cache entry found [url: http://www.shapeways.com/modules/udesign/ext/client/lib/vecmath.jar, version: null]
</message>
</record>
<record>
  <date>2009-02-17T18:13:49</date>
  <millis>1234894429001</millis>
  <sequence>124</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://www.shapeways.com/modules/udesign/ext/client/lib/vecmath.jar with proxy=DIRECT
</message>
</record>
<record>
  <millis>1234894429007</millis>
  <sequence>125</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894429049</millis>
  <sequence>126</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://www.shapeways.com/modules/udesign/ext/client/lib/vecmath.jar with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
</message>
</record>
<record>
  <millis>1234894429104</millis>
  <sequence>127</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: ResponseCode for http://www.shapeways.com/modules/udesign/ext/client/lib/vecmath.jar : 304
</message>
</record>
<record>
  <sequence>128</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Encoding for http://www.shapeways.com/modules/udesign/ext/client/lib/vecmath.jar : null
</message>
</record>
<record>
  <millis>1234894429105</millis>
  <sequence>129</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Disconnect connection to http://www.shapeways.com/modules/udesign/ext/client/lib/vecmath.jar
</message>
</record>
<record>
  <millis>1234894429167</millis>
  <sequence>130</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Cache entry found [url: http://www.shapeways.com/modules/udesign/ext/client/lib/vlc_uri.jar, version: null]
</message>
</record>
<record>
  <millis>1234894429174</millis>
  <sequence>131</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://www.shapeways.com/modules/udesign/ext/client/lib/vlc_uri.jar with proxy=DIRECT
</message>
</record>
<record>
  <millis>1234894429178</millis>
  <sequence>132</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://www.shapeways.com/modules/udesign/ext/client/lib/vlc_uri.jar with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
</message>
</record>
<record>
  <millis>1234894429234</millis>
  <sequence>133</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: ResponseCode for http://www.shapeways.com/modules/udesign/ext/client/lib/vlc_uri.jar : 304
</message>
</record>
<record>
  <millis>1234894429235</millis>
  <sequence>134</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Encoding for http://www.shapeways.com/modules/udesign/ext/client/lib/vlc_uri.jar : null
</message>
</record>
<record>
  <sequence>135</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Disconnect connection to http://www.shapeways.com/modules/udesign/ext/client/lib/vlc_uri.jar
</message>
</record>
<record>
  <millis>1234894429263</millis>
  <sequence>136</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894429264</millis>
  <sequence>137</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894429269</millis>
  <sequence>138</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Cache entry found [url: http://download.java.net/media/jogl/builds/archive/jsr-231-webstart-current/jogl.jnlp, version: null]
</message>
</record>
<record>
  <millis>1234894429275</millis>
  <sequence>139</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://download.java.net/media/jogl/builds/archive/jsr-231-webstart-current/jogl.jnlp with proxy=DIRECT
</message>
</record>
<record>
  <millis>1234894429470</millis>
  <sequence>140</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: ResponseCode for http://download.java.net/media/jogl/builds/archive/jsr-231-webstart-current/jogl.jnlp : 304
</message>
</record>
<record>
  <sequence>141</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Encoding for http://download.java.net/media/jogl/builds/archive/jsr-231-webstart-current/jogl.jnlp : null
</message>
</record>
<record>
  <millis>1234894429471</millis>
  <sequence>142</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Disconnect connection to http://download.java.net/media/jogl/builds/archive/jsr-231-webstart-current/jogl.jnlp
</message>
</record>
<record>
  <millis>1234894429565</millis>
  <sequence>143</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Cache entry found [url: http://download.java.net/media/gluegen/webstart/gluegen-rt.jnlp, version: null]
</message>
</record>
<record>
  <millis>1234894429573</millis>
  <sequence>144</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://download.java.net/media/gluegen/webstart/gluegen-rt.jnlp with proxy=DIRECT
</message>
</record>
<record>
  <millis>1234894429768</millis>
  <sequence>145</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: ResponseCode for http://download.java.net/media/gluegen/webstart/gluegen-rt.jnlp : 304
</message>
</record>
<record>
  <millis>1234894429784</millis>
  <sequence>146</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Encoding for http://download.java.net/media/gluegen/webstart/gluegen-rt.jnlp : null
</message>
</record>
<record>
  <millis>1234894429785</millis>
  <sequence>147</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Disconnect connection to http://download.java.net/media/gluegen/webstart/gluegen-rt.jnlp
</message>
</record>
<record>
  <millis>1234894429825</millis>
  <sequence>148</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Cache entry found [url: http://download.java.net/media/jogl/builds/archive/jsr-231-webstart-current/jogl-natives-windows-i586.jar, version: null]
</message>
</record>
<record>
  <millis>1234894429831</millis>
  <sequence>149</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://download.java.net/media/jogl/builds/archive/jsr-231-webstart-current/jogl-natives-windows-i586.jar with proxy=DIRECT
</message>
</record>
<record>
  <date>2009-02-17T18:13:50</date>
  <millis>1234894430027</millis>
  <sequence>150</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: ResponseCode for http://download.java.net/media/jogl/builds/archive/jsr-231-webstart-current/jogl-natives-windows-i586.jar : 304
</message>
</record>
<record>
  <millis>1234894430028</millis>
  <sequence>151</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Encoding for http://download.java.net/media/jogl/builds/archive/jsr-231-webstart-current/jogl-natives-windows-i586.jar : null
</message>
</record>
<record>
  <millis>1234894430029</millis>
  <sequence>152</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Disconnect connection to http://download.java.net/media/jogl/builds/archive/jsr-231-webstart-current/jogl-natives-windows-i586.jar
</message>
</record>
<record>
  <millis>1234894430069</millis>
  <sequence>153</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894430084</millis>
  <sequence>154</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>155</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894430136</millis>
  <sequence>156</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894430138</millis>
  <sequence>157</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894430143</millis>
  <sequence>158</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>159</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894430154</millis>
  <sequence>160</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894430156</millis>
  <sequence>161</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894430168</millis>
  <sequence>162</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Cache entry found [url: http://download.java.net/media/gluegen/webstart/gluegen-rt-natives-windows-i586.jar, version: null]
</message>
</record>
<record>
  <millis>1234894430175</millis>
  <sequence>163</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://download.java.net/media/gluegen/webstart/gluegen-rt-natives-windows-i586.jar with proxy=DIRECT
</message>
</record>
<record>
  <millis>1234894430372</millis>
  <sequence>164</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: ResponseCode for http://download.java.net/media/gluegen/webstart/gluegen-rt-natives-windows-i586.jar : 304
</message>
</record>
<record>
  <millis>1234894430462</millis>
  <sequence>165</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Encoding for http://download.java.net/media/gluegen/webstart/gluegen-rt-natives-windows-i586.jar : null
</message>
</record>
<record>
  <sequence>166</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Disconnect connection to http://download.java.net/media/gluegen/webstart/gluegen-rt-natives-windows-i586.jar
</message>
</record>
<record>
  <millis>1234894430466</millis>
  <sequence>167</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894430506</millis>
  <sequence>168</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894430507</millis>
  <sequence>169</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894430513</millis>
  <sequence>170</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>171</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894430520</millis>
  <sequence>172</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>173</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894430521</millis>
  <sequence>174</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>175</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>176</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894430527</millis>
  <sequence>177</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>178</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>179</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894430528</millis>
  <sequence>180</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>181</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>182</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>183</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: Checking if certificate is in Deployment session certificate store
</message>
</record>
<record>
  <date>2009-02-17T18:13:59</date>
  <millis>1234894439986</millis>
  <sequence>184</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: User has granted the priviledges to the code forever
</message>
</record>
<record>
  <millis>1234894439999</millis>
  <sequence>185</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>186</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <date>2009-02-17T18:14:00</date>
  <millis>1234894440000</millis>
  <sequence>187</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: Adding certificate in Deployment permanent certificate store
</message>
</record>
<record>
  <sequence>188</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: Removing certificate in Deployment permanent certificate store
</message>
</record>
<record>
  <sequence>189</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: Removed certificate in Deployment permanent certificate store as alias deploymentusercert$tsflag-1132515482805396946
</message>
</record>
<record>
  <sequence>190</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: Added certificate in Deployment permanent certificate store as alias deploymentusercert-4681638541804420869
</message>
</record>
<record>
  <millis>1234894440001</millis>
  <sequence>191</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: Saving Deployment certificates in C:\Users\Colin\AppData\LocalLow\Sun\Java\Deployment\security\trusted.certs
</message>
</record>
<record>
  <sequence>192</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>security: Saved Deployment certificates in C:\Users\Colin\AppData\LocalLow\Sun\Java\Deployment\security\trusted.certs
</message>
</record>
<record>
  <sequence>193</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>194</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894440002</millis>
  <sequence>195</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>196</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>197</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894440003</millis>
  <sequence>198</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>199</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>200</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>201</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894440004</millis>
  <sequence>202</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>203</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>204</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>205</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894440037</millis>
  <sequence>206</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894440438</millis>
  <sequence>207</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>208</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894440439</millis>
  <sequence>209</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>210</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>211</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894440442</millis>
  <sequence>212</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894440443</millis>
  <sequence>213</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>214</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>215</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894440444</millis>
  <sequence>216</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>217</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894440510</millis>
  <sequence>218</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894440511</millis>
  <sequence>219</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>220</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>221</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>222</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894440512</millis>
  <sequence>223</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>224</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894440513</millis>
  <sequence>225</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>226</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>227</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>228</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894440544</millis>
  <sequence>229</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>230</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>231</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894440545</millis>
  <sequence>232</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>233</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>234</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>235</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894440549</millis>
  <sequence>236</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>237</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894440575</millis>
  <sequence>238</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894440576</millis>
  <sequence>239</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894440585</millis>
  <sequence>240</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>241</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>242</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894440586</millis>
  <sequence>243</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>244</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>245</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894440587</millis>
  <sequence>246</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>247</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>248</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>249</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894440588</millis>
  <sequence>250</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894440668</millis>
  <sequence>251</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894440669</millis>
  <sequence>252</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>253</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894440673</millis>
  <sequence>254</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894440674</millis>
  <sequence>255</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>256</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>257</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>258</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894440675</millis>
  <sequence>259</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>260</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894440683</millis>
  <sequence>261</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894440684</millis>
  <sequence>262</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>    loading: C:\Users\Colin\AppData\Local\Temp\jnlp-applet\jln54101\jln54102\jogl.dll
</message>
</record>
<record>
  <date>2009-02-17T18:14:01</date>
  <millis>1234894441571</millis>
  <sequence>263</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894441576</millis>
  <sequence>264</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894441577</millis>
  <sequence>265</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>266</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>267</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>268</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894441578</millis>
  <sequence>269</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>270</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>271</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>272</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894441579</millis>
  <sequence>273</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894441791</millis>
  <sequence>274</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894441861</millis>
  <sequence>275</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894441862</millis>
  <sequence>276</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>    loading: C:\Users\Colin\AppData\Local\Temp\jnlp-applet\jln54101\jln54102\jogl_awt.dll
</message>
</record>
<record>
  <millis>1234894441939</millis>
  <sequence>277</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://www.shapeways.com/modules/udesign/webservice/soap.php with proxy=DIRECT
</message>
</record>
<record>
  <millis>1234894441947</millis>
  <sequence>278</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>279</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894441987</millis>
  <sequence>280</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://www.shapeways.com/modules/udesign/webservice/soap.php with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
</message>
</record>
<record>
  <date>2009-02-17T18:14:02</date>
  <millis>1234894442210</millis>
  <sequence>281</sequence>
  <logger>sun.plugin</logger>
  <level>FINE</level>
  <class>com.sun.deploy.util.LoggerTraceListener</class>
  <method>print</method>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>282</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894442211</millis>
  <sequence>283</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>284</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>285</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894442508</millis>
  <sequence>286</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Cache entry not found [url: http://www.shapeways.com/modules/udesign/webservice/getmodel.php?session_id=qstn09r495m4k12qsi99bm3vb6&amp;model_id=17085, version: null]
</message>
</record>
<record>
  <millis>1234894442517</millis>
  <sequence>287</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://www.shapeways.com/modules/udesign/webservice/getmodel.php?session_id=qstn09r495m4k12qsi99bm3vb6&amp;model_id=17085 with proxy=DIRECT
</message>
</record>
<record>
  <millis>1234894442519</millis>
  <sequence>288</sequence>
  <level>FINE</level>
  <thread>10</thread>
  <message>network: Connecting http://www.shapeways.com/modules/udesign/webservice/getmodel.php?session_id=qstn09r495m4k12qsi99bm3vb6&amp;model_id=17085 with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
</message>
</record>
<record>
  <date>2009-02-17T18:14:03</date>
  <millis>1234894443026</millis>
  <sequence>289</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894443028</millis>
  <sequence>290</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894443029</millis>
  <sequence>291</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>292</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>293</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>294</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894443030</millis>
  <sequence>295</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>296</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>297</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>298</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894443031</millis>
  <sequence>299</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894443190</millis>
  <sequence>300</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>301</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894443191</millis>
  <sequence>302</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>303</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894443192</millis>
  <sequence>304</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>305</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>306</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894443193</millis>
  <sequence>307</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>308</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <sequence>309</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
<record>
  <millis>1234894443194</millis>
  <sequence>310</sequence>
  <level>FINE</level>
  <thread>10</thread>
</message>
</record>
Trace File
JNLPAppletLauncher: static initializer
os.name = windows vista
nativePrefix =   nativeSuffix = .dll
Applet.init
subapplet.classname = udesign.UDesignApplet
subapplet.displayname = Shapeways Viewer Applet
subapplet.image = http://www.shapeways.com/modules/udesign/utils/openfile.php?id=17085&f=17085_applet.jpg
network: Cache entry not found [url: http://www.shapeways.com/modules/udesign/utils/openfile.php?id=17085&f=17085_applet.jpg, version: null]
network: Connecting http://www.shapeways.com/modules/udesign/utils/openfile.php?id=17085&f=17085_applet.jpg with proxy=DIRECT
network: Connecting http://www.shapeways.com/modules/udesign/utils/openfile.php?id=17085&f=17085_applet.jpg with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
Applet.start
os.arch = x86
processNativeJar: using previously cached: C:\Users\Colin\.jnlp-applet\cache\www_shapeways_com\a4e0ac5cd925c1bc48013ed68401901b8feae8fd\jogl-natives-windows-i586.jar
validateCertificates:
VALIDATE: jogl.dll
VALIDATE: jogl_awt.dll
VALIDATE: jogl_cg.dll
extractNativeLibs:
EXTRACT: jogl.dll(jogl)
EXTRACT: jogl_awt.dll(jogl_awt)
EXTRACT: jogl_cg.dll(jogl_cg)
processNativeJar: using previously cached: C:\Users\Colin\.jnlp-applet\cache\www_shapeways_com\a4e0ac5cd925c1bc48013ed68401901b8feae8fd\gluegen-rt-natives-windows-i586.jar
VALIDATE: gluegen-rt.dll
extractNativeLibs:
EXTRACT: gluegen-rt.dll(gluegen-rt)
Message: VERSION: 1.2.4
******** Creating mesh editor *
JNLPAppletLauncher.loadLibrary("jogl")
The selected editor is udesign.editor.mesh.MeshEditor[,0,0,0x0,invalid,layout=java.awt.BorderLayout,alignmentX=0.0,alignmentY=0.0,border=,flags=9,maximumSize=,minimumSize=,preferredSize=]
JNLPAppletLauncher.loadLibrary("jogl_awt")
OpenGL details:
Card vendor: ati technologies inc.
Spec Version: 2.0.6479 Release
Renderer: ATI Radeon Xpress 1250
High-resolution shaders enabled
network: Cache entry not found [url: http://www.shapeways.com/modules/udesign/webservice/getmodel.php?session_id=qstn09r495m4k12qsi99bm3vb6&model_id=17085, version: null]
network: Connecting http://www.shapeways.com/modules/udesign/webservice/getmodel.php?session_id=qstn09r495m4k12qsi99bm3vb6&model_id=17085 with proxy=DIRECT
network: Connecting http://www.shapeways.com/modules/udesign/webservice/getmodel.php?session_id=qstn09r495m4k12qsi99bm3vb6&model_id=17085 with cookie "udesign_guest=d4fc43b53b6698774ab258ad39a48cb9e409abdb; __utmz=20557562.1234005773.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); udesign_user=17452; udesign_hash=b5fb9d32f1db3e56a325303f0b2d6be9caeacff1; iep=qstn09r495m4k12qsi99bm3vb6; sifrFetch=true; __utma=20557562.4547825788262925000.1234005773.1234811460.1234894277.35; __utmc=20557562; __utmb=20557562.8.10.1234894277"
Re: Gallery 3D Viewer [message #3027 is a reply to message #3010 ] Wed, 18 February 2009 21:36 UTC Go to previous messageGo to next message
I have sent over to the development guys to take a look into it.
Cheers!
Robert
icon14.gif  Re: Gallery 3D Viewer [message #4041 is a reply to message #3027 ] Fri, 24 April 2009 16:18 UTC Go to previous message
avatar minisumo  is currently offline minisumo
Thanks guys!
Just had a note from Arno, rechecked the 3D viewer and all is fine now!
Sounds like a Vista 3D tools issue, sorted in a recent patch. Nice to see a company that doesn't forget it's users issues.
Very Happy
best regards,
Colin
Previous Topic:Printed models by our community
Next Topic:How can We Avoid Problems Like These?
