Home » Community » Feature this!  » Reusable Espresso Capsule
icon6.gif  Reusable Espresso Capsule [message #16325] Wed, 18 August 2010 13:49 UTC Go to next message
Hey Shapers,
I want to feature an "out of the box" idea of mine..
I bought an Espresso Club Coffee machine with capsules...
just to find out i'm stuck with the tastes and brands my supplier
offers me... not to mention a "life-time" calls from that supplier's
telemarketers to order a new stock of capsules.. Confused
So i thought how about testing new off-the-shelf brands (foreign
or domestic) ? or how about Tea? on my Capsule machine..
I opened my Sketchup and designed a REUSABLE Capsule so
i can pick and choose my own favorite tastes, brands, and Tea !
http://www.shapeways.com/model/137461/espresso_reusable_caps ule.html
index.php?t=getfile&id=4590&private=0
I tested the Black Detail/Transparent material on my machine
and amazingly nothing happened to it with the high temperatures...
I know materials on shapeways are not entirely recommended
as food safe.. still i'm going to test it and see how it goes.
I could try and print it using Stainless Steel or even Gold Plated
but i am not sure yet if the 1mm walls will be accepted for print..
What do you guys think ?
Dizingof
http://www.shapeways.com/shops/dizingof
[Updated on: Wed, 18 August 2010 17:02 UTC]
http://www.3Dizingof.com
Re: Reusable Espresso Capsule [message #16326 is a reply to message #16325 ] Wed, 18 August 2010 14:03 UTC Go to previous messageGo to next message
avatar Tommy_2Tall  is currently offline Tommy_2Tall
Hi!
I'd be a bit cautious and worried if I knew there was a slight chance of plastic residue or support material in my coffee/tea.
A simple tea strainer or tea ball in goldplated stainless might be a nice idea though... and it would probably get the attention of your guests. Smile
But then there's the issue with 3mm wall thickness and possibility of fused holes if you make them too small and useless holes if they get too big... :-S
Are the original capsules ripped/cut open or just punctured? Perhaps it would be simpler to reuse the material at hand?
Re: Reusable Espresso Capsule [message #16329 is a reply to message #16325 ] Wed, 18 August 2010 14:34 UTC Go to previous messageGo to next message
The way my machine works ( i assume its the way for all capsule machines like Nespresso) is you put the capsule in its bay and a metal rod from above punctures the aluminum foil , pushes hot water and sucks it up back to your cup.
This design is a replica in terms of accurate measurements - but i added of course the re-usability function by making it a 2 part capsule that you can close tightly using the 2 nobs.
As for any plastic residue .. you rinse it thoroughly first.
I should email Bart with the STL file and ask if it can be printed in SS.
Though the Transparent or Black Detail is good enough for me.
Dizingof
Re: Reusable Espresso Capsule [message #16330 is a reply to message #16325 ] Wed, 18 August 2010 14:36 UTC Go to previous messageGo to next message
I'd also coat it in a certified food safe resin if I were to try something like this.
Re: Reusable Espresso Capsule [message #16331 is a reply to message #16330 ] Wed, 18 August 2010 14:40 UTC Go to previous messageGo to next message
Youknowwho4eva wrote on Wed, 18 August 2010 14:36
Any link to such food-safe resin? never heard of it.
Re: Reusable Espresso Capsule [message #16332 is a reply to message #16331 ] Wed, 18 August 2010 14:47 UTC Go to previous messageGo to next message
Woah, lab rat Dizingof.
Shocked
How does it taste?
Duann Scott
Re: Reusable Espresso Capsule [message #16334 is a reply to message #16325 ] Wed, 18 August 2010 14:50 UTC Go to previous messageGo to next message
While typing in Food Safe Resin, google suggested food safe glue. And I found this. May be useful. http://www.gorillaglue.com/ToughTeam/ToughTeamForum/tabid/15 1/forumid/7/postid/325/scope/posts/Default.aspx
Re: Reusable Espresso Capsule [message #16335 is a reply to message #16329 ] Wed, 18 August 2010 14:55 UTC Go to previous messageGo to next message
avatar fx2  is currently offline fx2
I'd be quite cautious at trying to sell it (in addition to the already mentionned health risk ). Cafe machines and capsules are heavily covered by multiples patents... Nobody can block you to print some for yourself,though and make some cups of " Authentic Arabica & Plastic taste" Smile
[Updated on: Wed, 18 August 2010 14:56 UTC]
Re: Reusable Espresso Capsule [message #16336 is a reply to message #16325 ] Wed, 18 August 2010 14:59 UTC Go to previous messageGo to next message
Haven't tested/tasted it yet.
Local UPS charged me $64 for a $51.9 order which had this capsule ... that's 123% outrages fees !! Shocked
only because of the extra $1.9 above the $50 no-customs/state taxes limit.
I told them where they can push this package.. Twisted Evil
(my lesson here never order above $50 per package.. split it.)
I'll order it again and let you know.
I don't think it's a lab-rat thing ... just thinking out-of-the-box. Cool
Cheers
Dizingof
Re: Reusable Espresso Capsule [message #16590 is a reply to message #16325 ] Tue, 24 August 2010 00:14 UTC Go to previous messageGo to next message
I like the idea, but i would definitely think that SS would be the way to go. Unless you can find out what exactly happens to the plastic at that temperature....
Quite a few plastics do some...well..bad stuff when heated.
Aut Viam Inveniam Aut Faciam
Re: Reusable Espresso Capsule [message #16597 is a reply to message #16336 ] Tue, 24 August 2010 02:20 UTC Go to previous messageGo to next message
avatar photosfromrob  is currently offline photosfromrob
dizingof wrote on Wed, 18 August 2010 14:59
Cheers
Dizingof
Here's another good reason to charge shipping and handling separately. On duty on shipping and handling, I think. How about Shapeways finding ways to decrease duties, etc. Maybe, Treating bulk orders from shop owners differently than normal orders. You could increase your profit if you got more of us selling on our own.
Re: Reusable Espresso Capsule [message #16602 is a reply to message #16325 ] Tue, 24 August 2010 08:26 UTC Go to previous messageGo to next message
@rawkstar320,
Black detail survived the high temperatures of the machine but i too think SS would be far better for this concept.
@photosfromrob,
I don't think that would help... Duty tax + VAT are applied (in my country) on the entire invoice value , including the shipment...
and then there is the UPS fees on top of that..
The solution according to Pete , Shapeways CEO , is us 3d printing using a local Shapeways branch where we live... much like Ponoko franchising across Europe and New Zealand.
I have no doubt it will happen , but it will take some time..
Dizingof
Re: Reusable Espresso Capsule [message #28232 is a reply to message #16331 ] Thu, 26 May 2011 21:41 UTC Go to previous messageGo to next message
avatar sammymatik  is currently offline sammymatik
I am working on a project for a coffee cup and have searched for a food safe (potable water) resin and have found a few. the only problem is, they are not rated for higher temperatures... Not that coffee is that hot but, it exceeds the operating temps for their resin systems. I've contacted several manufacturers and resin suppliers and have not found a system which is safe for this use...
I would think that something like this must exist... and they probably do and are in use, but it seems like the resin companies tend not to test for this application so the resins that do exist are not rated for heat.
I'm a student in a plastics program and I'm stills searching but have not found a suitable epoxy system yet.
if you find out any info, i'd be interested.
Very good idea btw. the other option is to make a piece then produce it via casting/thermoforming.
dizingof wrote on Wed, 18 August 2010 14:40
Re: Reusable Espresso Capsule [message #28238 is a reply to message #16325 ] Thu, 26 May 2011 23:57 UTC Go to previous message
I haven't looked into the food safe resin but perhaps the new glazed ceramics can be a good option..
Previous Topic:Making a PC case with 3D printing!
Next Topic:Wind Vase - Glazed Ceramics
