Home » Community » Feature this!  »
Interactions Vase & Bowl for Glazed Ceramics
Interactions Vase & Bowl for Glazed Ceramics [message #27831] Thu, 19 May 2011 15:56 UTC Go to next message
Hey All,
My latest designs for Glazed Ceramics:
Interactions Vase
http://i1080.photobucket.com/albums/j322/dizingof/InteractionsVase776.jpg
http://i1080.photobucket.com/albums/j322/dizingof/InteractionsVase777.jpg
http://i1080.photobucket.com/albums/j322/dizingof/InteractionsVase779.jpg
http://i1080.photobucket.com/albums/j322/dizingof/InteractionsVase783.jpg
http://i1080.photobucket.com/albums/j322/dizingof/InteractionsVase-anigif.gif
Interactions Bowl
http://i1080.photobucket.com/albums/j322/dizingof/InteractionsBowl793.jpg
http://i1080.photobucket.com/albums/j322/dizingof/InteractionsBowl794.jpg
http://i1080.photobucket.com/albums/j322/dizingof/InteractionsBowl790.jpg
http://i1080.photobucket.com/albums/j322/dizingof/InteractionsBowl797.jpg
http://i1080.photobucket.com/albums/j322/dizingof/InteractionsBowl-anigif.gif
Wall thickness - exact 3mm all over.
Surface details >2mm.
Logo - 2mm Wink
http://www.3Dizingof.com
Re: Interactions Vase & Bowl for Glazed Ceramics [message #27860 is a reply to message #27831 ] Thu, 19 May 2011 19:12 UTC Go to previous messageGo to next message
Kerplunk anyone?
Seroiusly, Dizingof, you're really craking off some nice designs for ceramics, keep it up!
Re: Interactions Vase & Bowl for Glazed Ceramics [message #27881 is a reply to message #27860 ] Fri, 20 May 2011 00:09 UTC Go to previous messageGo to next message
you should make the inside smooth instead of having the constant wall thickness would drastically reduce the cost and make easier to clean.
Re: Interactions Vase & Bowl for Glazed Ceramics [message #27891 is a reply to message #27831 ] Fri, 20 May 2011 03:01 UTC Go to previous messageGo to next message
You need to balance between a reasonable wall thickness and a smooth surface - if i were to Boolean a ball or a cylinder on the above models to smooth their inner surface i would cut a lot on the printing cost BUT i doubt shapeways will allow it for printing with wall thickness that exceeds 3mm by as much as twice or 3 times...
After extensive testings i came out with a balanced solution - instead of hollowing out a ceramics model with 0.2 surface detail - as i usually been doing in the past years to cut material cost - i went for 3mm
- that smoothed most of the bumps and "valleys" of the inner surface yet kept the wall thickness just a little over 3mm.
For the following new model, i managed to cut printing cost by 35% (thou it's still pricey..)
Fire Vase
http://i1080.photobucket.com/albums/j322/dizingof/FireVase829.jpg
http://i1080.photobucket.com/albums/j322/dizingof/FireVase828.jpg
http://i1080.photobucket.com/albums/j322/dizingof/FireVase831.jpg
http://i1080.photobucket.com/albums/j322/dizingof/FireVase830.jpg
I will thou, asks CS to check a test model with full inner wall surface to see if they accept a 5 or 10mm wall thickness ..
Re: Interactions Vase & Bowl for Glazed Ceramics [message #27893 is a reply to message #27891 ] Fri, 20 May 2011 03:23 UTC Go to previous messageGo to next message
i read some where max thickness is 15mm.
Re: Interactions Vase & Bowl for Glazed Ceramics [message #27895 is a reply to message #27831 ] Fri, 20 May 2011 05:36 UTC Go to previous message
Interaction Vase was redesigned smoothed and size increased with a 10+mm thick walls.
Printing cost reduced by 35%.
Previous Topic:My little robot, at last!
Next Topic:12mm Mini 3x3x3 Rubik's Cube - printed assembled
