| Hyphae Lamps and a new larger Seed Lamp [message #27826] Thu, 19 May 2011 14:14 UTC |
These arrived before ICFF but I didn't have a chance to post until now. Each Hyphae lamp is one of a kind and we will do a series of them. So far we printed two only.
We also created a much larger version of our Seed lamp which we designed last August.
I'm really satisfied with the shadows cast by the lamps. I grabbed this cell phone shot showing the result of the Seed Lamp in our living room.
http://n-e-r-v-o-u-s.com
| Re: Hyphae Lamps and a new larger Seed Lamp [message #27834 is a reply to message #27826 ] Thu, 19 May 2011 16:11 UTC |
Beautiful !
http://www.3Dizingof.com
| Re: Hyphae Lamps and a new larger Seed Lamp [message #27848 is a reply to message #27834 ] Thu, 19 May 2011 17:47 UTC |
Wow!
Looks like you pulled it right out of the ocean and put a light bulb in it, just amazing....
| Re: Hyphae Lamps and a new larger Seed Lamp [message #27859 is a reply to message #27858 ] Thu, 19 May 2011 19:04 UTC |
re: Virtox
It's ~27cm in diameter, original was ~18. The increase in volume is actually quite dramatic
The hyphae lamps are ~
Height 13.3 cm
Width 13.5 cm
Depth 19.0 cm
but use a lot less material
| Re: Hyphae Lamps and a new larger Seed Lamp [message #27884 is a reply to message #27859 ] Fri, 20 May 2011 00:52 UTC |
As always, your work is very impressive!
Lincoln
www.Craftosterone.com
| Re: Hyphae Lamps and a new larger Seed Lamp [message #27894 is a reply to message #27884 ] Fri, 20 May 2011 04:39 UTC |
Those are just gorgeous!
Will you or your lamps be at RAPID next week? I am planning on going, and would love to see these in person.
-Marcus
| Re: Hyphae Lamps and a new larger Seed Lamp [message #27914 is a reply to message #27894 ] Fri, 20 May 2011 14:57 UTC |
thanks for all the positive feedback people!
we are not going to be at RAPID. But it's a pretty fun show, I hope you enjoy it. We'll be at home recovering from ICFF
| Re: Hyphae Lamps and a new larger Seed Lamp [message #29577 is a reply to message #27914 ] Fri, 24 June 2011 00:00 UTC |
Wow these are beautiful!
| Re: Hyphae Lamps and a new larger Seed Lamp [message #29578 is a reply to message #27826 ] Fri, 24 June 2011 00:43 UTC |
Very cool stuff. The seed lamp: it looks like two algorithms run at different scales (one for the large scale wrinkles, and another for the small scale porous structure). Presumably the large scale wrinkles algorithm run before the small scale algorithm?
I'm reminded of some 2d multiscale Turing patterns by Jonathan McCabe:
http://gallery.bridgesmathart.org/single-artist?uid=jonathan mccabe
He runs algorithms at multiple different scales, but not in a fixed order. Instead, at each step it runs at the scale which has the least contrast, the aim being to make all scales have visual interest. He's got a paper about the algorithms here:
http://www.jonathanmccabe.com/Cyclic_Symmetric_Multi-Scale_T uring_Patterns.pdf
I wonder if something like this could be done in 3d, running algorithms simultaneously at different scales?
