How to Correct The Geometry?
How to Correct The Geometry? [message #27835] Thu, 19 May 2011 16:12 UTC Go to next message
avatar shry  is currently offline shry
Hello everyone,
Can someone here please tell me how to create geometry so that when I export it in .STL file, it doesn't appear like number 2 instead of number 1 (please see attached image below)?
Thank you
  • Attachment: STL.PNG
    (Size: 20.96KB, Downloaded 124 time(s))
Re: How to Correct The Geometry? [message #27838 is a reply to message #27835 ] Thu, 19 May 2011 16:47 UTC Go to previous messageGo to next message
You can't. STL can only approximate non-planar surfaces by dividing them in to many separate polygons. If you set the resolution higher when exporting you will get a file that looks more like 1, but it's never possible to get it completely smooth, though. But usually the resolution of the printers is lower than the resolution of the file so it doesn't matter that much.
Re: How to Correct The Geometry? [message #27845 is a reply to message #27835 ] Thu, 19 May 2011 17:32 UTC Go to previous messageGo to next message
Shapeways does now support OBJ which is common and I believe nurb based (Allows rounded faces)
Re: How to Correct The Geometry? [message #27876 is a reply to message #27845 ] Thu, 19 May 2011 22:38 UTC Go to previous message
Youknowwho4eva wrote on Thu, 19 May 2011 17:32
Do you know how that works out when converted to the printer file format?
(second time i've seen nurb mentioned in as many days - i gotta do some research into this and catch up with modern stuff)
@srirg60 - for smooth printed round shapes, I aim for triangles with 0.1mm or less between vertices, which works for me Smile
[Updated on: Thu, 19 May 2011 22:38 UTC]
Previous Topic:Saving to StereoLithography
Next Topic:How to check and fix STL files
