| Saving to StereoLithography [message #27806] Thu, 19 May 2011 12:23 UTC |
I thought since Stereo Lithography seems to be the simplest format to use with your service, maybe I should write my own software that saves to that format.
Open sourced software seems to be easier to work with but I have a small question re printers at Shapeways.
Would you mind telling me which kinds of CPUs and Printers you have?
Regarding the cpus and printers, are they (check which apply)
1. CR/LF ( PC/DOS ) [ ]
2. LF ( Unix ) [ ]
3. CR ( Macintosh ) [ ]
In case you were wondering, those letters to the left of the system name are the type or character used to go to the next line in a text or ASCII American Standard for Communication Information Interchange file. And might be important to know which format said printers use so that file(s) might be made useable to them from said concept application.
Working at letting development tools be more available to needy and low income households.
| Re: Saving to StereoLithography [message #27808 is a reply to message #27806 ] Thu, 19 May 2011 12:40 UTC |
Justin,
i think the best thing to do is write an email to service@shapeways.com
they can send the email to the person that knows the most about the printers and then reply back to you
| Re: Saving to StereoLithography [message #27812 is a reply to message #27806 ] Thu, 19 May 2011 13:12 UTC |
So you are wanting to write software for Shapeways or for yourself? If it's for yourself the STL format should be universal across platforms.
| Re: Saving to StereoLithography [message #27814 is a reply to message #27812 ] Thu, 19 May 2011 13:19 UTC |
Youknowwho4eva is right; STL is a platform independent file format.
| Re: Saving to StereoLithography [message #27816 is a reply to message #27812 ] Thu, 19 May 2011 13:43 UTC |
I agree that it should be cross platform of options and simplicity, generally speaking but for making aware which format works on shapeways hardware, I can only fathom that would be made through an upload of three kinds of file, each of their own new line character. Unless ofcoarse, the support@shapeways can answer which kind of new line character is accepted at shapeways in the .stl (stereo lithography) file format.
I'll send a quick email.
| Re: Saving to StereoLithography [message #27823 is a reply to message #27818 ] Thu, 19 May 2011 14:08 UTC |
Thanks. I appreciate your help Sir. As I don't have the development suite chosen yet, it may be a while until I upload sample data files.
| Re: Saving to StereoLithography [message #27828 is a reply to message #27806 ] Thu, 19 May 2011 15:33 UTC |
Looking at an STL file in Notepad, it appears not to have any symbolism for line breaks.
The first line denotes SLA format and from which program it was created, and from there it to give the location of every triangle.
Example
facet normal 0.99942089 0.00000000 0.03402766
outer loop
vertex -0.03768646 4.62432798 3.77802887
vertex -0.03768646 4.87316406 3.77802887
vertex -0.03768897 4.87316404 3.77810254
endloop
endfacet
repeated with the coordinates of each face.
Edit, I tried to manually create a cube but looks like I messed up a coordinate. http://www.shapeways.com/model/261126/cube_test.html?gid=ug
It's amazing how much this will hurt your head just to make a cube lol.
[Updated on: Thu, 19 May 2011 15:56 UTC] The Mad Moder
