Polishing Raw WSF?
Polishing Raw WSF? [message #26901] Tue, 03 May 2011 16:28 UTC Go to next message
avatar MrDGWalters72  is currently offline MrDGWalters72
Has anybody tried to polish raw (unpainted) WSF?
I was hoping to be able to do this with a Dremel on a low speed setting in order to smooth out the surface of the material as opposed to using sand/wet sanding paper.
As a matter of interest has anybody had success smoothing unpainted WSF material using papers of a Dremel?
[Updated on: Thu, 14 January 2016 12:57 UTC]
MrDGWalters72
Re: Polishing Raw WSF? [message #26905 is a reply to message #26901 ] Tue, 03 May 2011 16:47 UTC Go to previous messageGo to next message
I've sanded it with ordinary sandpaper. You can get it a lot smoother, the problem I've noticed is that it is hard to keep the surface uniform. After I dye the sanded pieces, you can still see marks from the sanding.
Painting may work better, as far as getting a more uniform look.
Re: Polishing Raw WSF? [message #26997 is a reply to message #26905 ] Thu, 05 May 2011 11:18 UTC Go to previous messageGo to next message
That's really helpful, thank you for the advice.
I will give it a go.
David.
MrDGWalters72
Re: Polishing Raw WSF? [message #27267 is a reply to message #26901 ] Tue, 10 May 2011 19:33 UTC Go to previous messageGo to next message
Hey, I realized I have a rock tumbler. Anybody tried polishing WSF by fulling a rock tumbler with some kind of beads and soapy water? Sort of a do it yourself polished white strong and flexible?
Re: Polishing Raw WSF? [message #27269 is a reply to message #27267 ] Tue, 10 May 2011 20:02 UTC Go to previous messageGo to next message
avatar ana_xyz  is currently offline ana_xyz
I'm assuming you guys haven't yet seen the news about the introduction of Polished WSF?
Or maybe you just really like to do these things yourself? Smile
Community Manager | Shapeways
Re: Polishing Raw WSF? [message #27271 is a reply to message #27269 ] Tue, 10 May 2011 20:10 UTC Go to previous messageGo to next message
ana wrote on Tue, 10 May 2011 20:02
Yes, I want to try the new material. But I also am interested in trying to polish it myself!
[Updated on: Tue, 10 May 2011 20:10 UTC]
Re: Polishing Raw WSF? [message #27292 is a reply to message #27271 ] Wed, 11 May 2011 08:40 UTC Go to previous messageGo to next message
Yes, it's great news!
There is just one thing I wanted to point out - looking at some of the exemplar pictures, the material appears to still be textured, although members testimonials are stating that it is silky smooth.
I am going to try it out anyway.
David.
MrDGWalters72
Re: Polishing Raw WSF? [message #27295 is a reply to message #27292 ] Wed, 11 May 2011 11:08 UTC Go to previous messageGo to next message
WSFP does feel silky smooth, but there is some texturing... the full size image of my Baritone Horn in the examples is about eight to ten times real life size (the smallest pipes are only 1mm diameter)
Re: Polishing Raw WSF? [message #27301 is a reply to message #27295 ] Wed, 11 May 2011 12:28 UTC Go to previous messageGo to next message
Is it likely to be less textured on less intricate larger basic shapes or will the texture remain on whatever is produced using this method?
It certainly looks more appealing than the original WSF and more saleable.
I really didn't like the feel of the original WSF, it just didn't feel like a commerical material.
Thanks for the pic!
[Updated on: Thu, 12 May 2011 07:38 UTC]
MrDGWalters72
Re: Polishing Raw WSF? [message #27348 is a reply to message #27295 ] Wed, 11 May 2011 22:25 UTC Go to previous messageGo to next message
How does it affect build layers? The steps in spherical shapes, for example, are they less obvious? Same?
Re: Polishing Raw WSF? [message #27350 is a reply to message #27348 ] Wed, 11 May 2011 22:37 UTC Go to previous messageGo to next message
The steps in spherical shapes are more to do with the resolution of the triangle size of the model rather than the finish. For comparison, unpolished and polished versions.
Re: Polishing Raw WSF? [message #27354 is a reply to message #27350 ] Wed, 11 May 2011 23:27 UTC Go to previous messageGo to next message
The question is if the polishing manages to hide them, not at all, or partially. The musical instrument has no obvious zones... but a cube with rounded corners seems to (fuzzy photo).
Re: Polishing Raw WSF? [message #27357 is a reply to message #27354 ] Wed, 11 May 2011 23:47 UTC Go to previous messageGo to next message
My horn had no stepping to start with, so none to polish off.
I don't know how that rounded corner cube was 3d modelled, but it looks like the flat face has succumbed to some 'down-skin' droop. The rounded corners look fine, but there is a definate ridge around the square flat face. Looking at the model page, I'm guesstimating the ridge is in the order of 0.1-0.2mm (the square face being about 16mm accross from what i figure).
I suppose, a model is needed with varying triangle resolution in a number of curves and flat planes to give a true all round picture.
Re: Polishing Raw WSF? [message #27365 is a reply to message #27357 ] Thu, 12 May 2011 05:59 UTC Go to previous messageGo to next message
Are we talking about the same concept? A "tube" with 32 side quads and 3 mm diameter had steppings just where the faces were near parallel to the build layers (it was built on its side, not with the axis up). And the sides, where one face covers 0.3mm of height all by itself, is rounder.
Maybe worth sending yet another testing shape in next order.
Re: Polishing Raw WSF? [message #27368 is a reply to message #27365 ] Thu, 12 May 2011 06:40 UTC Go to previous messageGo to next message
I'm sure we're talking about the same concept. The way I look at designing for WSF is to make the triangle size smaller than the minimum detail for smooth rounded areas... flat areas seem to have a mind of their own and often have a ridge or indent depending which side is up or down in the print plane.
My theory is that if the triangle resolution is bigger than the print resolution, the printer approimates from one vertex to the next causing stepping. So far, with WSF, I get nice round smooth corners using triangles smaller than 0.1mm.
Re: Polishing Raw WSF? [message #27370 is a reply to message #27368 ] Thu, 12 May 2011 07:37 UTC Go to previous messageGo to next message
Would the polish (tumbling) process make WSFP easier to paint and not so porous as normal WSF?
[Updated on: Thu, 12 May 2011 11:06 UTC]
MrDGWalters72
Re: Polishing Raw WSF? [message #27377 is a reply to message #27370 ] Thu, 12 May 2011 09:00 UTC Go to previous messageGo to next message
I just tested using diluted artists acrylic, brushed on, the paint goes on evenly and rinses off under running water without leaving paint residue in the surface. From that, I'd concluded that the surface is sealed and not at all porous.
Re: Polishing Raw WSF? [message #27378 is a reply to message #27377 ] Thu, 12 May 2011 09:55 UTC Go to previous messageGo to next message
Regarding triangulation and/or (stair)-stepping:
I have found no correlation between the two.
Large models with lots of curves and many many small triangles (smaller than print resolution) can still show stepping on the near level (bottom) surfaces.
And models with bigger triangles, just tend to show the triangles, I have noticed no increased stepping from this, just visible polygonization, which can be quite smooth.
As far as I can tell the stepping is mostly depended on the print resolution and what the bottom side in the printer is.
Re: Polishing Raw WSF? [message #27381 is a reply to message #27378 ] Thu, 12 May 2011 11:07 UTC Go to previous messageGo to next message
That is great news, thank you for confirming!
MrDGWalters72
Re: Polishing Raw WSF? [message #27386 is a reply to message #27377 ] Thu, 12 May 2011 13:42 UTC Go to previous messageGo to next message
stop4stuff wrote on Thu, 12 May 2011 09:00
What about dyeing? "Not at all porus" sounds bad for dyeing ... can it still be dyed?
[Updated on: Thu, 12 May 2011 13:43 UTC]
Re: Polishing Raw WSF? [message #27400 is a reply to message #27386 ] Thu, 12 May 2011 16:42 UTC Go to previous messageGo to next message
I'm not sure of the chemistry involved, but acid dyes e.g. Rit work fine with fabrics consisting of non-porous strands of nylon (polyamide), no reason why the same technique wouldn't work with polished WSF.
Re: Polishing Raw WSF? [message #27401 is a reply to message #27400 ] Thu, 12 May 2011 16:59 UTC Go to previous message
I will test it out ... but first I need to order some of my stuff in this new material.
I'm surprised by the lack of lines in your WSF horn. I've seen lots of print lines in my models where high curvature surfaces are involved. I don't think it has anything to do with the triangulation ...
Previous Topic:Wanted: freelance painter/airbrusher
Next Topic:Making rubber molds from Sandstone
