| Problem with scales using zbrush [message #25177] Wed, 23 March 2011 17:01 UTC |
Ive try create object in zbrush, I want it to be 4cm talls, but shapeway said its 400cm.. Ive try scale it down to 0.04... but its still wrong scale.
What should I need to check? what did I missed?
| Re: Problem with scales using zbrush [message #25335 is a reply to message #25177 ] Sun, 27 March 2011 23:25 UTC |
Hi, can you share your file with us?
| Re: Problem with scales using zbrush [message #25435 is a reply to message #25335 ] Wed, 30 March 2011 14:48 UTC |
Hi, sorry it took me so long to get back on internet..
here a test files. I want to find out about scales which I don't.
you will see there wrong scales.
I did make up scale it to very small scales ( 0.01 mm in zbrush) and its seem fine to me.. but Its wasted my time to keeping upload and look at scales then upload again with smaller scales... and going on until I got to that point..
| Re: Problem with scales using zbrush [message #25459 is a reply to message #25435 ] Wed, 30 March 2011 20:16 UTC |
Your file, me downloading and then uploading to Shapeways gives a printable model with Height 4.1cm, Width 2.9cm and Depth 0.7cm - looks like you got the scaling right?
| Re: Problem with scales using zbrush [message #25468 is a reply to message #25459 ] Wed, 30 March 2011 23:52 UTC |
that was my "Blind manual scaling" its my 4th or 5th attempt after check shapesway's scales. don't want do that with rest of my model..
there a raw zbrush importing with 2.0 x 2.0 x 2.0 inch cube.
tell me if that right scales?
in shapesway showed in email ;
| Quote: | Unfortunately, we were not able to process and thus print your product. The error message was:
Your object has not the correct size.
The size is 200.00 x 200.00 x 200.00 cm / 78.74 x 78.74 x 78.74 inch.
We can only produce designs from 0.25 x 0.25 x 0.25 cm / 0.098 x 0.098 x 0.098 inch up to 70.00 x 38.00 x 58.00 cm / 27.56 x 14.96 x 22.83 inch (h x w x d).
Please rescale it.
| Re: Problem with scales using zbrush [message #25479 is a reply to message #25468 ] Thu, 31 March 2011 06:32 UTC |
The easiest way for you to scale your model would be to use trompevenlo's handy tip VRML, sizing and scaling substituting 0.001 (meters to mm) with 0.0254 (meters to inches) - maybe not the Zbrush solution you were hoping for, but a useful and easy workaround.
| Re: Problem with scales using zbrush [message #25480 is a reply to message #25479 ] Thu, 31 March 2011 09:06 UTC |
that make a scene. Thank!
look at that shapeway "moans"
| Quote: | The size is 200.00 x 200.00 x 200.00 cm / 78.74 x 78.74 x 78.74 inch.
Ive put 2.0 inch in zbrush.. so that mean Ive put 2 meter in VRML!
Ill imaged an meter in "inch"
I better try it out. that mean if I need 2 inch talls = 0.05 inch in zbrush.
let me try it out..
will updated here when Ive upload 2x2x2 inch cube..
[EDIT]
yippyaaa!!! well. close enough.. I cannot get 0.5 inch in zbrush.. only 0.4 / 0.6, I pick 0.6 inch so that 6cm. Thank for explains. what a annoy. heh,
| Quote: | Height 6.0 cm
Width 6.0 cm
Depth 6.0 cm
Volume 215.66 cm³
[Updated on: Thu, 31 March 2011 09:15 UTC]
