Sanding/Smoothing WSF...
Sanding/Smoothing WSF... [message #25052] Mon, 21 March 2011 12:23 UTC Go to next message
avatar MrDGWalters72  is currently offline MrDGWalters72
Just wondering if WSF could be sanded quite smooth for using as a tool for vacuum forming.
I don't need to paint the WSF, just sand it smoother.
Any suggestions?
Thanks.
MrDGWalters72
Re: Sanding/Smoothing WSF... [message #47627 is a reply to message #25052 ] Sun, 29 April 2012 00:16 UTC Go to previous messageGo to next message
avatar Malcr001  is currently offline Malcr001
Yes it can be sanded smoother but it takes a lot of time and elbow grease. If you can go for WSF polished go for it because it will save you a lot of time but I know theres a 15x15x15cm size restriction.
[Updated on: Sun, 29 April 2012 00:17 UTC]
Re: Sanding/Smoothing WSF... [message #48832 is a reply to message #25052 ] Thu, 24 May 2012 00:22 UTC Go to previous message
give the model a light sand
then vac form over the model with a buffer sheet
vac form again with second / final sheet
this cuts out alot of noise, but only really works if your not working to tight dimensions
hope this helps
failing that.......car body filler is a lot easier to sand smooth.
piers
EDIT: not sure how the chemicals in CBF react to WSF
[Updated on: Thu, 24 May 2012 00:30 UTC]
boop
Previous Topic:Finishing WSF material with plastic casting?
Next Topic:Inktense Watercolor Pencils on WSF
