Why does my shop suddenly look bad?
Why does my shop suddenly look bad? [message #17385] Tue, 07 September 2010 19:45 UTC Go to next message
Hi Shapeways,
My shop suddenly looks bad, see picture below (Internet Explorer). Items overlap. How can I make my shop look right again?
Oskar
P.S. It looks OK in Firefox, but I don't think I can convince my customers to use Firefox from now on.
P.S. The Forum doesn't look good in Firefox either. The buttons on the right ("Edit", "Quote") go over the edge.
index.php?t=getfile&id=4924&private=0
[Updated on: Wed, 08 September 2010 06:40 UTC]
Re: Why does my shop suddenly look bad? [message #17398 is a reply to message #17385 ] Wed, 08 September 2010 01:14 UTC Go to previous messageGo to next message
Hi Oskar,
I will pass this on to the development team,
Hopefully it can be rectified in this Thursday's update.
I had not seen it in any browsers at all?
Duann
Duann Scott
Re: Why does my shop suddenly look bad? [message #17400 is a reply to message #17385 ] Wed, 08 September 2010 01:45 UTC Go to previous messageGo to next message
avatar Drawn-SteelHero  is currently offline Drawn-SteelHero
I hadn't seen this before either; I use Opera most of the time and the shops all look just fine, including yours. Out of curiosity, what browser did you find the problem in?
Andy
Re: Why does my shop suddenly look bad? [message #17401 is a reply to message #17385 ] Wed, 08 September 2010 06:24 UTC Go to previous messageGo to next message
avatar jdjong  is currently offline jdjong
I have more or less the same problem with the forum. see picture
index.php?t=getfile&id=4931&private=0
  • Attachment: ojee.JPG
    (Size: 203.95KB, Downloaded 648 time(s))
[Updated on: Wed, 08 September 2010 06:25 UTC]
Re: Why does my shop suddenly look bad? [message #17403 is a reply to message #17385 ] Wed, 08 September 2010 07:44 UTC Go to previous messageGo to next message
I am not having this problem with my shop, however I have been having the same problem viewing messages in the forum in Internet Explorer 8 for some time. Text doesn't wrap and I can't see buttons that are on the right unless I switch into "Compatibility View" (according to the tooltip: "websites designed for older browsers will often look better, and problems such as out-of-place menus, images, or text will be corrected"). Unfortunately, other features on the Shapeways site (e.g. most of them on the page to edit my shop) don't seem to work properly when I'm in "Compatibility View", so I have to remember to turn it off.
Speaking of editing my shop, it appears that when I move an item on the first page to the right or left by one spot, and its resulting position is anywhere after the first two lines (but still on the first page), when the page is refreshed I am on the second page, so I have to go back to the first page to find and move the item again.
Re: Why does my shop suddenly look bad? [message #17408 is a reply to message #17385 ] Wed, 08 September 2010 12:41 UTC Go to previous messageGo to next message
Appears to be a screen resolution issue.
Re: Why does my shop suddenly look bad? [message #17525 is a reply to message #17385 ] Fri, 10 September 2010 13:59 UTC Go to previous messageGo to next message
avatar ArnoudV  is currently offline ArnoudV
Hi Oskar.
Does the problem still exists? I can't reconstruct the problem. Maybe you can help me by telling what version of IE you have and which operating system you use?
@ GHP
Do you know some other forum pages where this problem occurs, can you send me some links of that?
Re: Why does my shop suddenly look bad? [message #17529 is a reply to message #17525 ] Fri, 10 September 2010 15:46 UTC Go to previous messageGo to next message
Yes, the problem is still there. I use Windows XP and Internext Explorer v7.
Oskar
Re: Why does my shop suddenly look bad? [message #17538 is a reply to message #17385 ] Fri, 10 September 2010 17:07 UTC Go to previous messageGo to next message
Have you tried uping to IE8? what resolution are you running at?
Re: Why does my shop suddenly look bad? [message #17541 is a reply to message #17538 ] Fri, 10 September 2010 17:37 UTC Go to previous messageGo to next message
So your advice is that I should advice all my customers to run IE8 in order to see it looking well? I don't care for the looks for myself, as long as it is functional. I want my customers to see a good-looking professional shop, even if they happen to not have upgraded to IE8.
Oskar
Re: Why does my shop suddenly look bad? [message #17543 is a reply to message #17385 ] Fri, 10 September 2010 17:43 UTC Go to previous messageGo to next message
Not at all, are your customers having the same problem? I'm just trying to find a solution and hopefully what's causing the issue.
Re: Why does my shop suddenly look bad? [message #17544 is a reply to message #17543 ] Fri, 10 September 2010 17:52 UTC Go to previous messageGo to next message
Yes, at IE8, it seems to look OK.
Re: Why does my shop suddenly look bad? [message #17553 is a reply to message #17544 ] Fri, 10 September 2010 21:20 UTC Go to previous messageGo to next message
I noticed a similar issue with the forums. posts with large images caused all of the text on the page to go off the right of the page with no option to scroll sideways. I'm using IE8 with all the newest updates... the solution I found was to click on the compatibility button to the right of the address bar.
Re: Why does my shop suddenly look bad? [message #17555 is a reply to message #17525 ] Fri, 10 September 2010 21:51 UTC Go to previous messageGo to next message
ArnoudV wrote on Fri, 10 September 2010 13:59
Sorry, I just noticed your question. It happens pretty much all the time on all the forum pages, any time anyone enters text long enough to go all the way across my screen. See the snapshot:
My screen resolution is 1024x768 pixels, by the way.
GHP.
[Updated on: Fri, 10 September 2010 21:54 UTC]
Re: Why does my shop suddenly look bad? [message #17624 is a reply to message #17541 ] Mon, 13 September 2010 08:52 UTC Go to previous messageGo to next message
Oskar_van_Deventer wrote on Fri, 10 September 2010 17:37
Oskar
No, it should look OK in every browser, unregarding how many people use it. Design may differ slightly but it has to look proffesionally so I agree.
Thanks for your replies, it really helps to track it easier. We're still looking into this so I'll keep you guys informed through this topics.
Re: Why does my shop suddenly look bad? [message #17762 is a reply to message #17385 ] Wed, 15 September 2010 11:18 UTC Go to previous messageGo to next message
We fixed the forum width bug. It's not tested entirely but it seems OK. Please give a shout if there's any problem.
We're still locating the shop bug, I'll come back on that.
Re: Why does my shop suddenly look bad? [message #17964 is a reply to message #17762 ] Fri, 17 September 2010 14:44 UTC Go to previous messageGo to next message
ArnoudV wrote on Wed, 15 September 2010 11:18
Forums look good now , cheers Thumbs Up
Re: Why does my shop suddenly look bad? [message #24012 is a reply to message #17964 ] Fri, 18 February 2011 10:54 UTC Go to previous messageGo to next message
Hi Shapeways,
I found another (minor?) problem. On my shop page there are occasionally strange characters, like "&nbsp" and "$lt", see below.
Can you do something to make then not show?
Thank you.
Oskar
index.php?t=getfile&id=7190&private=0
[Updated on: Fri, 18 February 2011 10:58 UTC]
Re: Why does my shop suddenly look bad? [message #24013 is a reply to message #24012 ] Fri, 18 February 2011 10:56 UTC Go to previous messageGo to next message
Plus one more screen shot.
Oskar
P.S. Why do I need to wait one minute to make this second upload? And why can I upload only one picture per post?
index.php?t=getfile&id=7189&private=0
Re: Why does my shop suddenly look bad? [message #24017 is a reply to message #24013 ] Fri, 18 February 2011 13:18 UTC Go to previous messageGo to next message
Thanks Oskar,'
Will pass it &lton to the YET&nesb Developers... Rolling Eyes
How was NYC??????????????????????????????????????
Re: Why does my shop suddenly look bad? [message #24195 is a reply to message #24017 ] Thu, 24 February 2011 13:03 UTC Go to previous message
avatar barrys  is currently offline barrys
The problems with those html characters showing up in the listview should be gone.
Barry
Previous Topic:Updating an item that's been ordered
Next Topic:Missing materials
