| Re: Silver Casting [message #8194 is a reply to message #7931 ] Thu, 10 December 2009 11:13 UTC |
Very interesting Zorink!
To tell you the truth, I was thinking of doing the same thing, by giving the WSF (White Stong and Flexible... am I right?) material to a foundry.
Do you think it will work?
Again, great work!
http://shpws.me/DWg
| Re: Silver Casting [message #8224 is a reply to message #8194 ] Thu, 10 December 2009 21:50 UTC |
It worked very well, I just had to burn out the molds hotter and longer than usual. Investment casting typically uses a special wax that is meant to burn out cleanly, so you really have to crank up the oven on the WSF for a good mold. Just be aware that your casting will have the same texture as the WSF (you can see it in my pic) and will take quite a bit of work if you want your final model to be smooth metal.
| Re: Silver Casting [message #8268 is a reply to message #8224 ] Sat, 12 December 2009 16:25 UTC |
Hi guys,
for now, why don't you use the details materials (black or white)?
They burn easier and are much smoother than WS&F.
regards,
Peter
PS: Make sure you have plenty of ventilation. The fumes aren't exactly healthy!
[Updated on: Sun, 13 December 2009 14:46 UTC]
| Re: Silver Casting [message #8292 is a reply to message #8268 ] Sat, 12 December 2009 22:16 UTC |
Thanks for the tip - Now I have to go buy some more models!
| Re: Silver Casting [message #22979 is a reply to message #7931 ] Mon, 24 January 2011 20:10 UTC |
My WS&F is already produced by a foundry to test. Haven't seen it yet, but as the person said, this is a small loss.
http://shpws.me/DWg
| Re: Silver Casting [message #23475 is a reply to message #22980 ] Sun, 06 February 2011 12:36 UTC |
Wow. that's fantastic. good to know, good to know.
| Re: Silver Casting [message #23479 is a reply to message #8268 ] Sun, 06 February 2011 13:33 UTC |
| pete wrote on Sat, 12 December 2009 16:25 | Hi guys,
regards,
Peter
Hi, Pete
Do you know if transparent detail works the same as black detail and white detail materials?
