| Color? [message #2332] Mon, 29 December 2008 22:51 UTC |
I noticed one thing on this site: all models are nice and white. So I assume the printer isn't a color 3D printer?
Well, okay... That would mean that I'd have to paint a model myself. Any advise about the best paints to use for the material of the model?
| Re: Color? [message #2333 is a reply to message #2332 ] Mon, 29 December 2008 23:18 UTC |
I had some really awesome results with RIT fabric dye. It comes in all colours. A word to the wise ... do a few tests on some small cheap pieces.
I used a quarter packet mixed in 2 cups of kettle boiled water. The best results came from a 1/4 packet of dye mixed in 2 cups of hot water (from the kettle), and I dunked the small items in for 5-10 seconds only. Any more than that and the purple I used showed up almost black.
Do your own tests, and I think you will like the dye method. It soaks in, so it wont chip off like paint.
-Whystler
| Re: Color? [message #2336 is a reply to message #2333 ] Tue, 30 December 2008 01:42 UTC |
For painting, I've found that plastikote spray primer adheres well, as does krylon crystal clear and krylon fusion and regular spraypaints. For transparent detail at least, I had to do many coats of krylon before the surface texture was covered and it became smooth, so I recommend priming first.
Whystler, which materials did you try dying, strong/white/flexible? Any idea how the detail materials handle it?
| Re: Color? [message #2340 is a reply to message #2336 ] Tue, 30 December 2008 15:33 UTC |
Hey Bvicarious,
I died cream robust, white detail, transparent detail, and SWF.
The SWF took the dye most deeply, and the cream robust took it most lightly.
I used purple RIT dye.
On the first try, I actually boiled the dye bath on the stove and kept it boiling while dunking the pieces for 2 minutes. The result was:
-cream robust nice purple
-white detail black
-transparent detail black
-SWF black
I tried various other tests, until my final try, which used only hot water from a kettle. I did not keep this dye boiling on the stove. It sat in a plastic cup on the counter and had hot water in it only. In this final test, I dunked the items for 5 seconds only! And this was the result:
-transparent detail nice dark purple
-white detail nice dark purple
-SWF nice purple
I assume the results will vary depending on the colour and size.. for example, I used very small test models, and a baby blue will probably have slightly different results
-Whystler
[Updated on: Tue, 30 December 2008 15:35 UTC] Check out my website: http://tshawnjohnson.wordpress.com/
