| Changes to max cost of a co-creator [message #23027] Tue, 25 January 2011 20:21 UTC |
I'm not sure if I'm doing something wrong but I've tried to change the maximum cost of a co-creator (I had a problem with the code I use to create it that left material where I don't really need it) and I can't.
I've unpublished the template to see if I can change the settings but the one I need (the maximum cost) is still greyed out. Is there a way to fix this?
Thanks for any help...
Chris
| Re: Changes to max cost of a co-creator [message #23033 is a reply to message #23027 ] Tue, 25 January 2011 21:10 UTC |
Did you change the volume?
| Re: Changes to max cost of a co-creator [message #23072 is a reply to message #23033 ] Wed, 26 January 2011 20:47 UTC |
Yes - I've changed the generator code so that any model made with it can now have a slightly lower volume.
I tried updating the model with a new one from the new code and the current volume changes but it doesn't seem to want to allow me to change the maximum value at any point.
| Re: Changes to max cost of a co-creator [message #23073 is a reply to message #23027 ] Wed, 26 January 2011 20:52 UTC |
I'm a little confused, what do you mean by the maximum cost? Can you put up a screen shot of the area you're referring to?
| Re: Changes to max cost of a co-creator [message #23114 is a reply to message #23027 ] Thu, 27 January 2011 20:21 UTC |
Ah, so I figured. I'll inform the powers that be.
| Re: Changes to max cost of a co-creator [message #23154 is a reply to message #23027 ] Fri, 28 January 2011 16:09 UTC |
I'm guessing this is a one-off glitch and not a platform problem, so we'll QA and see what we can find. At the moment I can reassure you that this issue is on our radar!
| Re: Changes to max cost of a co-creator [message #23200 is a reply to message #23154 ] Sun, 30 January 2011 11:19 UTC |
Hi pittance,
On the screenshot you provide, the max volume doesn't appear to be greyed out, nor that you couldn't change it. I tried a random cocreator of myself and it does seem to work ok. Can you tell me the model id or title that seems to be a problem with.
Barry
