| Re: Hollow model and full color sandstone [message #20921 is a reply to message #20917 ] Thu, 25 November 2010 16:25 UTC |
Would like to know this too.
Though, I'm guessing 3mm wall is sufficient for keeping it strong enough at that size.
Also, what size should the holes be so you guys don't have too much trouble cleaning?
Kaetemi
| Re: Hollow model and full color sandstone [message #22529 is a reply to message #20921 ] Wed, 12 January 2011 20:05 UTC |
| Kaetemi wrote on Thu, 25 November 2010 16:25 | Also, what size should the holes be so you guys don't have too much trouble cleaning?
BUMP!
Right, so, I've successfully had this figure here ->
http://www.shapeways.com/model/190101/_santa_girl__figure__f ull_color_.html <-
printed with a wall thickness of 3mm and a hole of 1mm connecting the inside with the outside.
There were no problems with the print, the powder inside is just stuck inside (I assume).
So, I made another figure, and did it exactly the same way, because I'd expect it to be OK to do this way if I didn't have any issues with the previous print.
However, the order this time was canceled with "Non cleanable, Support material can not be removed from model, holes in the bottom of the model are too small" ?!
Well, maybe that's because that was my intention? And I kind of need this by next week...
Unfortunately none of the links in the mail or nowhere on the website does it say how large the holes need to be if you guys really want to get the powder out.
So basically I don't know to what point I have to waste my time here, as you'll probably have me waste my time only to wait more days to have it canceled again, and that's basically not going to get me there in time...
And I have no problem with the powder being stuck inside.
[Updated on: Wed, 12 January 2011 20:26 UTC] Kaetemi
| Re: Hollow model and full color sandstone [message #22533 is a reply to message #22531 ] Wed, 12 January 2011 20:23 UTC |
Was that a color model, and did they get it out trough the 5mm?
I can make it so it can get out trough the legs at 5mm, but then I need to know for sure that they won't cancel it again...
And if they really have a problem with something, then they should've let me know, because I expect to be able to do it the same way again if it worked the way I did it.
Although, the previous figure was delivered only 6 working days after I made the order, so it doesn't seem to me there were any problems.
[Updated on: Wed, 12 January 2011 20:33 UTC] Kaetemi
| Re: Hollow model and full color sandstone [message #22534 is a reply to message #22533 ] Wed, 12 January 2011 20:41 UTC |
I made a screenshot. The green ball is 2mm and the orange one 1mm. But I guess the total shape of the hole is big enough.
I have ordered a white strong and flexible version by mistake, that went well. And a colored version is in the mail now and will arrive tomorrow so I guess that went ok.
Hope this helps
Attachment: exmpl.jpg
(Size: 222.40KB, Downloaded 94 time(s))
See more of my 3D scanning/printing adventures here: http://3dpersons.com/ or statyou.com
| Re: Hollow model and full color sandstone [message #22609 is a reply to message #22608 ] Fri, 14 January 2011 11:16 UTC |
Thats weird... I just received mine. All good. Maybe this needs some actual support. Maybe it is something completely else?
| Re: Hollow model and full color sandstone [message #22617 is a reply to message #22610 ] Fri, 14 January 2011 12:08 UTC |
Maybe it is not the exit hole but one of the interior cavities? Could that be the case?
| Re: Hollow model and full color sandstone [message #22619 is a reply to message #22617 ] Fri, 14 January 2011 12:36 UTC |
They're only complaining about the legs...
Kaetemi
| Re: Hollow model and full color sandstone [message #22621 is a reply to message #22619 ] Fri, 14 January 2011 12:44 UTC |
If you want I can also have a look at it tonight? Just email me the model. Who knows...
| Re: Hollow model and full color sandstone [message #22626 is a reply to message #22621 ] Fri, 14 January 2011 15:13 UTC |
Okay, so now they say 5mm is ok, and I just had to boost some bits of the leg that were apparently about like 2.87mm instead of >3mm.
Kaetemi
| Re: Hollow model and full color sandstone [message #22629 is a reply to message #22626 ] Fri, 14 January 2011 15:21 UTC |
Ah Good! Yeah thought something else was maybe also wrong. Remains a bit of voodoo this 3D printing!
